FOB not working - 2nd Gen
Discussion in 'Lighting' started by Les7311, Nov 13, 2017.
  1. Nov 13, 2017 at 9:12 AM
    Les7311
    Les7311 [OP] Look up, what do you see
    2008 Blue Tundra TRD 4x4
    changed our the Interior lights to LED last night, now the Remote FOB not working.
    Replaced the battery and no luck.
    Is there a particular fuse I need to check?
    When installing the LEDs, I did not replace those dome lights metal plates.
    Any suggestions?
  2. Nov 13, 2017 at 9:42 AM
    Check the fuse block under the hood. I forget if that fuse is in there or under the one by the driver side kick panel
  3. Nov 13, 2017 at 10:27 AM
    Les7311
    Ok. I did last night but must have looked at the wrong fuse.
    Any more for details...i.e. fuse 20a etc?
  4. Nov 13, 2017 at 10:32 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Magnuson Magnum TVS 2650 S/C Sniv's Speed Shop 70mm pulley RCF Throttle Body TRD PRO BBS Wheels TRD Front Sway Bar TRD Rear Sway Bar Fox TRD Pro Shocks Limited mirrors (auto darkening/backup camera/power fold/puddle lights) Limited Grill Mod Automatic Climate Controls Mod Automatic Headlamp Mod Sequoia Transfer Case Mod Sequoia Leather Steering Wheel Mod Sequoia Limited Gage Cluster Mod Sequoia LED Headlamp Upgrade Window Tint 15/70% Fake Manual Transmission Mod 10" BAMufflers Stainless Catback Valhalla Catalytic Converter Shields Engine Block Heater Illuminated Ignition Key Ring Mod Deck Rail System w/cleats Solid Offroad Engine Mounts
    Put the old bulbs back in and see if the fob works again.
  5. Nov 13, 2017 at 10:45 AM
    Les7311
    Gggrrrrrrrrr. Do I have to?
    What’s the purpose of that metal plate in the domes?
  6. Nov 13, 2017 at 11:13 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Lol, of course not, but it was the last electrical change that you made before the fob stopped working, right? It's a very logical troubleshooting step. I'm not sure what metal plate you're meaning, I've never had my domes apart, my truck is a Standard Cab and my domes may be different from yours. I could speculate that it's a reflector to direct light.
    Mountun Goat likes this.
  7. Nov 13, 2017 at 11:23 AM
    Les7311
    Reinstalling the old bulbs is like connecting butterfly antanae on a 60inch TV. Lol
    I do believe those plates are for reflective , but I read somewhere that the fob circuitry is in the dome
  8. Nov 13, 2017 at 11:24 AM
    Les7311
    Can someone pull their manual and identify the FOB fuse and where?
    Didn’t get a manual feom Stealership
  9. Nov 13, 2017 at 11:25 AM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    Those fobs suck anyways. Get a new keyless /remote start. Just got a Compustar and freaking love it
  10. Nov 13, 2017 at 11:35 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Sausage fingers? The metal piece may serve as an antenna, put the fob right up to the dome area and see if that gets a response I guess. Okay, I've got a few, I'll go out and see what my dome looks like. I'd be surprised if the manual shows a fuse for the fob though, oftentimes multiple circuits are fused by the same fuse and the fuse is just given one name to reference. I won't be able to test my fob though, aftermarket remote start and the receiver antenna is in the A-pillar on my truck.
    Les7311[QUOTED][OP] likes this.
  11. Nov 13, 2017 at 11:55 AM
    speckmon
    Thornton, CO
    stealing this
    Wynnded[QUOTED] likes this.
  12. Nov 13, 2017 at 11:57 AM
    Les7311
    Hhhhmmmmmm. Am going to run through the fuses again - still don’t know which one is assigned
  13. Nov 13, 2017 at 11:58 AM
    Les7311
    Can you peep in your manual to tell the fuse and location?
  14. Nov 13, 2017 at 12:11 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Took my overhead console out. Metal pieces are light reflectors. I didn't see anything suggesting that the factory fob antenna is there, doesn't mean that it isn't tucked up in the headliner someplace though. Perusing my manual, fuses that may have anything to do with stuff in the overhead console are #s 23 and 24 under the hood, and #s 24 and 25 under the dash. All are 7.5amp.
    I think he's referring to where I hid the antenna for my aftermarket remote start.
  15. Nov 13, 2017 at 12:17 PM
    Les7311
    Thank you Wynn. Checking out ina few.
    Them LED is worth my sticking the key in to open the door, vs going back to them Jurassic bulbs!!!!
  16. Nov 13, 2017 at 12:20 PM
    Les7311
  17. Nov 13, 2017 at 12:27 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Jurassic bulbs...lol.
    I prefer the dimmer bulbs in my truck so that I'm not blinded when they come on, besides, I'm not reading the paper in there.
    Les7311[OP] likes this.
  18. Nov 13, 2017 at 12:57 PM
    Les7311
    So the plot thickens
    Now the VSC light is flashing, and the traction light stays lit.
    Ggggrrrrrrr
  19. Nov 13, 2017 at 1:49 PM
    Sounds like an ABS wheel sensor to me. They break easily.
  20. Nov 13, 2017 at 2:03 PM
    Les7311
    Not from changing bulbs!!! Truck driving perfect until I changed the bulbs.
    So changing bulbs lead to remote not working and VSC light flashing.
    A fuse is the culprit but where????
  21. Nov 15, 2017 at 6:26 PM
    Les7311
    Found it
    The ECU fuse was blown.
    Resolved
    Wynnded likes this.
  22. Nov 12, 2020 at 9:52 AM
    Ghoulx
    Ghoulx New Member
    Having identical issue. Can you confirm what ecu fuse was blown? My diagram shows afew ECU fuses... thank you.
  23. Jul 15, 2022 at 6:18 PM
    TLopez333
    TLopez333 New Member
    ECU ACC
