FOAM CANNONS ?
Discussion in 'Detailing' started by 2010bigdog, Nov 18, 2018.
  1. Nov 18, 2018 at 3:23 PM
    2010bigdog
    2010bigdog [OP] New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    What foam cannons are you guys using ? Looking to buy one but there are so many out there to choose from on Amazon
  2. Nov 18, 2018 at 3:45 PM
    SteyrM40A1
    SteyrM40A1 New Member
    Gregg
    2018 Toyota Tundra Crew Max SR5 TRD Sport, Magnetic Grey
    Air flow accelerator mod, charcoal filter delete. LED interior lights.
    I bought one on ebay for under $20. You can spend a lot more money on them, but I thought Id try this out first. It works great, produces a bunch of foam that clings well. I also ended up buying me an electric pressure washer to use with it from Lowes. So far im really liking it. It allows me to clean the fender wells and underneath the truck. Also I didnt buy any special soap for it, Right now im using black magic wet-n-wash ( i think thats what its called). But Ill probably buy Meguiars Gold class next.
    classiccat likes this.
  3. Nov 18, 2018 at 3:58 PM
    fisherman951
    fisherman951 New Member
    Tony
    Riverside
    2017 crewmax 4x4
    Amazon 17 dollar one works good for me
    War Machine and SteyrM40A1 like this.
  4. Nov 18, 2018 at 4:09 PM
    dawgfan706
    dawgfan706 New Member
    Using the Trinova one from Amazon. Think it was $35
  5. Nov 18, 2018 at 4:36 PM
    classiccat
    classiccat New Member
    2017 Tundra Limited SuperWhite
    MTM PF22 is my main cannon. It's a little spendy but I like the build quality, consistency and versatility over the "no-namer" that I was using previously.
    For winter washing, I just picked-up an IK 9 foam sprayer; no pressure washer required.
  6. Nov 18, 2018 at 4:46 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    How much was it ?
  7. Nov 18, 2018 at 4:51 PM
    classiccat
    The MTM is $85 on Amazon ($100 on the chemical guys website).
    You can get the IK 9 from $90-$100.
  8. Nov 19, 2018 at 6:16 AM
    dawgfan706
    You can get on youtube and there are several reviews of different ones.
  9. Nov 19, 2018 at 7:00 AM
    War Machine
    War Machine Premium Elite Member
    Houston, Texas
    2017 Black Crewmax SR5 Blaaaack
    I use this one:
    MATCC Adjustable Foam Cannon 1 Liter Bottle Snow Foam Lance With 1/4" Quick Connector Foam Blaster for Pressure Washer Gun https://www.amazon.com/dp/B01CE78VO8/ref=cm_sw_r_cp_tai_B-S8Bb2RS5DG7
    It’s cheap, and works great. I’m not sure where any improvement can be had by spending more money.
    I also have this one. It cost twice as much, and doesn’t work nearly as well in my opinon:
    McKillans Foam Cannon Professional Grade Adjustable Lance Pressure Washer Jet Wash with 1/4” Quick Connector https://www.amazon.com/dp/B07D6KPV3G/ref=cm_sw_r_cp_tai_U.S8Bb4QQ4VH3
  10. Nov 19, 2018 at 8:48 AM
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    I bought the MATCC cannon as well, cheap and it works great.
  11. Nov 19, 2018 at 9:59 AM
    KirthGersen
    KirthGersen New Member
    So Calif
    2018 SR5 Crewmax
    The jars on most foam cannons have a very narrow neck opening. This makes it hard to rinse out the jar, or to pour in the very thick detergents, like Meguiars "Gold Class Car Wash".
    I found a wide-mouth foam cannon at Amazon , holds 1.5 liters (often enough for 2 cars without refill), and the wide base resists tipping over.
    https://www.amazon.com/gp/product/B07CGG67PY/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    "Twinkle Star Cannon"
    about $17
    War Machine likes this.
  12. Jan 7, 2019 at 11:03 AM
    TundraAllTheWay
    TundraAllTheWay New Member
    2018 Cement Grey Toyota Tundra SR5 TRD Off-Road
    I bought a Simonoz pressure washer, and it comes with a foam cannon. There are foam guns, and foam cannons. I believe foam cannons work better.
  13. Jan 8, 2019 at 6:44 PM
    tundracap
    tundracap New Member
    NC
    2017 CM Limited 4x4 Silver Sky Metallic
    I suspect you're correct, but I don't want to have to break out the pressure washer every time I want to wash the truck, so looking at the guns as well as cannons.
  14. Jan 14, 2019 at 8:49 AM
    briarpatch
    briarpatch New Member
    So...I have the 20.00 Amazon 'no name' foam cannon, and it works pretty well. For Christmas, I got an MTM PF22 cannon. There's no comparison in the build quality, and it does indeed foam better than the Amazon one. Is it worth the additional money?....that would be up to you. I keep my Amazon one for pre-wash solution, and will likely get another one should I start using Griots Poly Gloss. Both are fitted with the smaller 1.1mm orifice, as I'm using a SunJoe SPX3000 pressure washer, which is rated at 2030 psi and 1.76 gpm.
  15. Jan 14, 2019 at 9:49 AM
    MGMTundra251
    MGMTundra251 New Member
    Bob
    19 MGM Tundra Platinum 4x4
    Baja Squadron Pro Fogs
    I did the Griots garage prewash with the PF22 cannon and got a ton of foam but got half of the foam using the Poly gloss. The poly gloss didn’t seem to work as good as the prewash for some reason.
  16. Jan 14, 2019 at 10:59 AM
    briarpatch
    I'm not surprised.....they're two very different products with very different applications.
