Fix it or don't? (Answer: FIX IT)
Discussion in '2.5 Gen Tundras (2014-2021)' started by PixelPusher, Dec 2, 2020.
  1. Dec 2, 2020 at 8:39 AM
    PixelPusher
    PixelPusher [OP] New Member
    New Hampshire
    2020 Tundra Limited, Super White
    [Edit: Decision has been made to fix]
    So... I haven't even put 3000 miles on my DC and I managed to get into a accident. :frusty:
    Full disclosure... Totally my fault and thankfully everyone involved is unharmed.
    The truck took the impact to the front drivers hinge pillar and to the front wheel. Needless to say, the door and front fender are smoked. Additionally, the wheel and suspension were also damaged. This all adds up to be a pricey repair.
    To add to it, the shop called me to inform me that they found additional damage, and this is the subject I am asking about. Turns out, the forward bushing for the upper control arm kissed the flange of the timing chain cover and snapped a tab off. My question is should I have this repaired or just leave it.
    My gut tells me that everything will be fine with this if I just leave it alone. However, I'm not sure if I'm missing something. Having this repaired will increase the cost, and more important to me is the time it will take to get my truck back. If I leave it alone, I am likely to get my truck back at the end of next week.
    Here is a better illustration of where on the cover the damage is.
    Thank you for any and all opinions on this matter.
  2. Dec 2, 2020 at 8:49 AM
    Gene5253
    Gene5253 New Member
    Gene
    Boise ID
    2020 Tundra CM Limited
    Wow sorry that happened. Additional cost and time?? Really sucks .
    PixelPusher[OP] likes this.
  3. Dec 2, 2020 at 8:50 AM
    TheBeast The Beach
    do you have GAP insurance on your truck ? if totaled you will get a new truck :)
  4. Dec 2, 2020 at 8:54 AM
    PixelPusher
    New Hampshire
    If I am to have the timing chain cover repaired, it would mean that the body shop would finish their work, then the truck would be taken to Toyota to have the cover replaced.
    I don't have a number as of yet, but I have a good idea that would NOT be a cheap fix. Insurance will cover the cost, but I would be with out my truck for longer, and the added cost of the repair would add to my increased premiums after this is all said and done.
    As it stands, the the current estimate for repair (without the timing cover) is upwards of $14k.
  5. Dec 2, 2020 at 8:56 AM
    PixelPusher
    New Hampshire
    They have no intention of totaling it. Even with the cover repair. I am just trying to figure out if the tab being broken of the cover is something I should worry about.
  6. Dec 2, 2020 at 9:17 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    My concern with leaving it would be some possibility of future leaking or problems. Hard call. I think that I would want everything fixed personally.
  7. Dec 2, 2020 at 9:21 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    ^^^ agreed
  8. Dec 2, 2020 at 9:25 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I would say that tab is there for a reason, even if it is not any significant reason. I would have it repaired if it was mine. I doubt your insurance premium increase will be any different with or without this repair.
  9. Dec 2, 2020 at 9:26 AM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    X3
    Your premium is going to go up anyway. I would want everything repaired completely.
  10. Dec 2, 2020 at 9:27 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    I'd say fix it, 100 percent. If you pass on it now and end up with problems later down the road due to the crack....you're gonna be on the hook.
  11. Dec 2, 2020 at 9:27 AM
    18" TRD Off Road Wheels
    No reason your truck with less than 3k miles should be missing parts. I'd opt for a full fix. To speed it up I'd contact your Toyota dealership and see if they can have somebody head to the body shop to take a look and get parts ordered sooner. Just a thought.
  12. Dec 2, 2020 at 9:39 AM
    PixelPusher
    New Hampshire
    Y'all are probably right. I needed to just balance getting the truck back next week or after Toyota would be done with it. At the end of next week, I'll have been without my truck for almost a month and I really want to get it back. Plus, my rental coverage runs out pretty close to that as well.
    I think the risk is low leaving it, but I do agree that if there is a problem due to this, I would be better to catch it now.
    One stupid move has made for a whole world of suck.
    Boerseun likes this.
  13. Dec 2, 2020 at 9:48 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Sorry that happened, glad to hear no one was hurt! I would also fix it.
    GODZILLA and PixelPusher[OP] like this.
  14. Dec 2, 2020 at 10:04 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Usually I am very picky about this type of stuff. I fix everything. But... but I would leave it unless it is significantly cheaper to do the repair now vs later.
    At very worst if a leak , you can spend the same amount of money later to fix the leak. Right now it's only cosmetic.
  15. Dec 2, 2020 at 10:10 AM
    41bigdawg
    41bigdawg Let the BIG DAWG Eat
    Robert
    Tennessee
    2013 Tundra DC 5.7
    Magnum front, Iron Cross rear bumpers, SB Cold air intake and Gibson Metal Mulisha exhaust, Fender flares, Tow mirrors, 18" Outlaw wheels, 12k Smitty X2O winch, Tech 12v auto start, Firestone Air Bags, Pedal Commander, Devil Horns, etc...
    I would get everything fixed to avoid potential problems down the road.
  16. Dec 2, 2020 at 11:00 AM
    Quattroa4m
    Quattroa4m New Member
    Without pulling the cover, you'll never know if there is additional concealed damage. If there is, unfortunately you'll own it later on down the road.
  17. Dec 2, 2020 at 11:14 AM
    PixelPusher
    New Hampshire
    Thank you all for your responses. I decided to get it fixed. I'll be without the truck for at least an additional week. My body shop it making arrangements with the local Toyota shop to have the parts and a timeslot arranged to minimize the time it will take to finalize the repair.
    More over, I'll be happy to know that there won't be any hidden damage.
    Maybe I'll have my truck back by Christmas.
    GODZILLA and Boerseun like this.
  18. Dec 2, 2020 at 11:19 AM
    attillatundra
    attillatundra New Member
    I would get it fixed. No way to know if something hidden is damaged which can come back to haunt you later.
  19. Dec 2, 2020 at 11:24 AM
    Boerseun
    Ferdie
    Sarasota Florida
    Now the insurance will pay for it, later OP will have to pay for it out of pocket.
  20. Dec 2, 2020 at 11:28 AM
    maziv52
    maziv52 New Member
    I’m a Doctor. Fix it.
  21. Dec 2, 2020 at 11:53 AM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    As previously stated, your premium is going to up, regardless of the repair to the damaged tab. Just get it done and give yourself piece of mind.
    300BLK and PixelPusher[OP] like this.
  22. Dec 2, 2020 at 12:18 PM
    mountainpete
    Is it confirmed the insurance will pay for it? If yes, then why is it even a question?
    Edit - I see it now. Insurance is covering it. I completely change my opinion. Fix it.
  23. Dec 2, 2020 at 12:26 PM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    You made the right call. If it did leak down the road, that cost is on you and you’ll still be out the same amount of time.
    I’ve been down this road a few times now. My wife is an extremely aggressive and oblivious driver with the insurance payment to validate it. In all fairnesss though she’s a lot better these last few years haha.
  24. Dec 2, 2020 at 12:30 PM
    ItsNickROFL
    ItsNickROFL New Member
    Nick
    2020 SR5 Tundra CrewMax
    Intake, exhaust, interior
    If insurance is buying absolutely. See if you can get a copy of how much it was to fix this. Reason being after they fix the timing cover take a good hard look at that number. Keep in mind if it failed it could potentially cause more components to fail and then you’d have to fix that as well. Get that number in your head and think insurance covered this now so I didn’t have to pay this later lol
    10TundraSR5 and PixelPusher[OP] like this.
  25. Dec 2, 2020 at 12:46 PM
    PixelPusher
    New Hampshire
    There were more than a few that stated this very thing. That is exactly what made me make the decision to fix it.
    Thank you all for your help in making the decision.
    Boerseun and ItsNickROFL[QUOTED] like this.
  26. Jan 7, 2021 at 6:57 PM
    PixelPusher
    New Hampshire
    It "only" took 54 days, but she's finally is back in the driveway. The shop did an incredible job. Other than the smell of fresh paint, you'd never know it happened.
  27. Jan 8, 2021 at 4:37 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Looks good glad it’s back on the road. How did the body shop do? Finding a good body shop is sometimes hard to do.
  28. Jan 8, 2021 at 4:41 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    Looks good and glad you got it back. FWIW, I think you did the smart move by getting it all fixed.
  29. Jan 8, 2021 at 5:13 AM
    attillatundra
    Looks great in that pic. It's amazing what a good body shop can do these days. Glad you finally have it back.
  30. Jan 8, 2021 at 5:55 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    What body shop did the work? Looks great btw..
