Fitting Nerf Bar on 2018 Tundra CrewMax
Discussion in 'General Tundra Discussion' started by Hchadb, Jan 21, 2018.
  1. Jan 21, 2018 at 6:15 AM
    Hchadb
    Hchadb [OP] New Member
    Chad
    2020 Tundra Crew Max Limited 2WD
    Running boards, bed cover, wireless cell charger in center console
    I’ve got a 2018 Tundra CrewMax and had bought a set of running boards/nerf bars off Amazon that claimed to fit, however once received the truck mount areas didn’t line up with board/bar predrilled area.
    Did the mount spacing change on 2018? How can I make for sure my next purchase will fit, because it seems everyone states they will fit 2007-2018 models?
    4Runner likes this.
  2. Jan 21, 2018 at 6:49 AM
    Diverguy
    Diverguy Breathes under water
    Leon
    PA, USA
    2018 Tundra Limited TRD Offroad-Inferno
    Windows tinted, window visors. Bedrug, led bedlights, Nfab nerf step bars, Lund toneau cover, Evo One remote start, BAMufflers 8"
    I got Nfabs, and they lined up perfectly. Sometimes, it pays to spend the extra money upfront.
    TXRailRoadBandit73 and Tony v like this.
  3. Jan 21, 2018 at 8:54 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    They fit from 07-18 as long as the cab length is the same.
    Double cab and Crewmax do not interchange.
  4. Jan 21, 2018 at 9:47 AM
    Hchadb
    Chad
    Thanks MotoTundra, I was aware Double and Crew required different but there seem to be vendors stating it fits 07-18 CrewMax but it doesn’t. Outside of buying from Toyota dealer, wasn’t sure if there was a way or a vendor to make sure when I do get the order it will fit.
    MotoTundra likes this.
  5. Jan 21, 2018 at 9:51 AM
    hartebreak
    hartebreak New Member
    2017 Tundra Doublecab
    N-Fab here, they lined up exactly. As stated above, check that they didnt send you bars for the wrong cab length.
  6. Jan 21, 2018 at 10:01 AM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    675F3CBF-43F8-44E4-B55C-5044F43DFF36.jpg If you got the nerf for your truck as described, then you having the same problem as I did.
    Half of the brackets face forward, other half faces backwards
    From the tip of your bar, find shorter of the bolt hole. This will be your nerf front.
    Place bar on two jack stands and start fitting the front or rear facing brackets.
    This job took me 4 hours - should have Ben 30 minutes
    I cussed eBay seller and had to apologize After
    Post up
  7. Jan 21, 2018 at 11:40 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Gotcha. Maybe like @Les7311 said, try flipping them around?
  8. Jan 21, 2018 at 12:07 PM
    Les7311
    Yup @MotoTundra
    Also grab the tape measure Will need
  9. Feb 22, 2018 at 9:38 PM
    Tony v
    Tony v Member
    2017 SR5 CrewMax
    What’s up with the holes on the bars?
  10. Feb 22, 2018 at 9:45 PM
    Got me some Nfabs coming my way soon!!!!
