First long trip - pretty happy with mpg
Discussion in '2.5 Gen Tundras (2014-2021)' started by YankeeRon, Dec 2, 2021.
  1. Dec 2, 2021 at 6:49 PM
    YankeeRon
    YankeeRon [OP] New Member
    Ron
    East Windsor, CT
    2021 SR Long Bed
    Cat Security shield, rear headliner molding, BlackVue dash cam, DS grab handle, rear under seat storage, door edge molding, cal trend seat covers, sway bars, hard bed cover, rubber bed mat, intermittent wipers
    So after listening to the 10,000th video that exclaimed what a gas pig the Tundra was, I was eager to see what it would do on a longer road trip. CT to NC and back over T-giving weekend and got this for milage - pretty dang pleased. No, I didn't drive it like I stole it, but also no, I didn't really baby it either. It was all highway, of course, and there are a bunch of hills in VA and WVA that brought it down somewhat, but overall I think I can live with this :)
  2. Dec 2, 2021 at 6:55 PM
    szabo101
    szabo101 New Member
    ED
    2018 MGM Platinum 4WD
    Wow, that's pretty impressive on that leg. At 55-60 mph I think you'll get the best return of MPGs on just about any truck.
    Saltyhero13 and GODZILLA like this.
  3. Dec 2, 2021 at 6:56 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    How did those numbers compare with filling it back up and dividing those numbers by the miles traveled?
    I like that method better for tank to tank fuel efficiency comparison purposes....some vehicles are right on the money, others not so much.
  4. Dec 2, 2021 at 6:58 PM
    YankeeRon
    Ron
    East Windsor, CT
    2021 SR Long Bed
    I didn't actually check it manually, but plan to do that on my next trip (Tx this time).
    GODZILLA likes this.
  5. Dec 3, 2021 at 4:05 AM
    ezdog
    ezdog New Member
    Gateway To The West
    The Computer wants you to think it is your friend.
    The Computer is rarely your friend.
    Saltyhero13 and Gunship Guy like this.
  6. Dec 3, 2021 at 5:23 AM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    I would expect your mpg figures are from an overly optimestic computer. I have got 18.9 mpg on a trip, both the computer and my hand calculation were the same. However I think usually the computer will show higher than actual mpg.
    Hoff likes this.
  7. Dec 3, 2021 at 5:40 AM
    YankeeRon
    Ron
    East Windsor, CT
    2021 SR Long Bed
    So I should curb my enthusiasm until I calculate it by hand - got it. Just to clarify, I took that photo at a small section that was 55 mph but the large majority of the trip was 65-70....
    OR...
    I could take the blue pill and continue to let the computer lie to me so I can feel good .... decisions, decisions. :)
    Ron
  8. Dec 3, 2021 at 5:47 AM
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    My computer is off by as much as a rounding error. As in, if the math says 17.1 mpg, the computer might read 17.3. None of this computer saying 20+mpg when the math at the pump says 17, that's ridiculous.
    Either you guys are doing math wrong or you're running 37" tires lol
    bjp and Jaypown like this.
  9. Dec 3, 2021 at 5:53 AM
    LML 3500HD
    My Tundra always did well on long trips until I replaced the front axle. 18 to high 19’s was common and the trip computer was pretty accurate.
  10. Dec 3, 2021 at 6:30 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    tundras that are unlifted and running stock size SL load tires can get respectable highway MPG. I have seen a hair over 19MPG on trips, hand calculated. Installing 33.4 E load tires changed that!
  11. Dec 3, 2021 at 12:25 PM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    How much would you say you lost with the bigger tires, is your truck still stock lift?
  12. Dec 3, 2021 at 12:29 PM
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    Don’t bother tracking mpg. Ignorance is bliss.
  13. Dec 3, 2021 at 12:31 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    My digital readout is normally within 1mpg to my hand calculation. Sometimes it's .2 difference.
    My guess that 21.3 readout was probably closer to 20. Maybe 19.7 or so if hand calculated. Either way, those numbers are still good.
  14. Dec 3, 2021 at 12:50 PM
    frichco228
    Yes, still stock suspension. Tires are 275/70-18 E load Wildpeaks, 33.4 tall. When I saw 19mpg it was the stock 32 inch tires in standard load and I really drove it like a grampa on a trip. My truck MPG ratings are 13/17, so 19 was certainly on the high end. MPG with the larger and heavier tires dropped about 1-1.5.
    Now, driving the way I normally do I get around 12-13 city, 15-16 highway. Im sure I could get better if a paid more attention and/or kept highway speeds at 70 or below but Ill take the 1mpg hit and drive the way I want. What really KILLs MPG with a Tundra is highway speeds over 70 (its is a big brick) and ANY idling. Even idling 3-5 minutes each morning when it is cold will bring down the tank average by 1MPG.
    Jaypown likes this.
  15. Dec 3, 2021 at 2:24 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    That's good, even for a 55 MPH speed.
  16. Dec 3, 2021 at 3:37 PM
    YankeeRon
    Ron
    East Windsor, CT
    2021 SR Long Bed
    Most of it was actually between 65 and 70 but the section where I took the pick was 55.....
  17. Dec 3, 2021 at 3:58 PM
    Rocko9999
    Rocko9999 New Member
    That must be downhill, engine off, on a flatbed trailer.
    YankeeRon[OP] likes this.
  18. Dec 4, 2021 at 6:02 AM
    Toxicbanana
    Toxicbanana New Member
    2021 Tundra Crewmax
    Going 68mph I get about 19mpg. The city driving is what kills me at 13 mpg.
  19. Dec 4, 2021 at 8:19 AM
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    My truck can see pretty wild fluctuations based on conditions. Hills, headwinds/tailwinds, loaded weight, ethanol free gas, speed, all move the needle quite noticeably (good or bad). I dread the day I'm loaded heavy, in hills, with a headwind, running 70. :eek:
  20. Dec 4, 2021 at 8:28 AM
    BayRunner
    2017 Tundra Platinum
    Just completed a 1600 mile trip towing a few thousand pounds over a couple of mountain ranges. Have no idea what the computer displayed since I don't pay attention to it, but manually calculated 11.5 mpg.
  21. Dec 6, 2021 at 7:19 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    That is really decent gas mileage while towing. I had Ford 3.5 EB and Ram Hemi trucks and that is what they got towing, they did a little better than the Tundra I owned when not towing (maybe +2 or +3 MPGs).
