First detail new black tundra
Discussion in 'Detailing' started by soobaroo, Mar 9, 2019.
  1. Mar 9, 2019 at 5:31 PM
    soobaroo
    soobaroo [OP] New Member
    Gene
    2019 Tundra SR5
    I’m unsure how to detail new paint. I was planning on using a claybar and going from there. If there isn’t anything that needs correcting I was going to use Klasse All In One to get the paint clean and follow up with Wolfgang polymer sealant. If It looks like it needs some correcting work then a final polish before sealant. I was told to use iron x as a first step but unsure if that’s necessary. Any suggestions of what I should or shouldn’t do. I’ve done a lot on older paint but not brand new vehicles. Don’t want to do something I’ll regret. Thanks.
    Pinay likes this.
  2. Mar 9, 2019 at 5:33 PM
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    All I’ll say is avoid circular motions!
    15whtrd likes this.
  3. Mar 9, 2019 at 6:10 PM
    15whtrd
    15whtrd Mr. Blonde
    You should my ways and I go front to back now.
  4. Mar 12, 2019 at 11:14 AM
    briarpatch
    briarpatch New Member
    Iron decontamination is a good idea, even if it's a new vehicle. You will be surprised at what runs off your truck.
  5. Mar 12, 2019 at 3:34 PM
    soobaroo
    Gene
    2019 Tundra SR5
    That seems to be the advice I’m getting. Also considering using Pinnacle jeweling wax for a good cleaning. Can you skip the claybar with iron x or still a must?
    Pinay likes this.
  6. Mar 12, 2019 at 5:28 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I would definitely use IronX and then clay, not a bar though, get a nanoskin mitt. If you have ever used a clay bar, you'll thank me once you try the nanoskin.
    Pinay likes this.
  7. Mar 12, 2019 at 5:54 PM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    Best practice on any dark color is to use an orbital
  8. Mar 12, 2019 at 6:46 PM
    soobaroo
    Gene
    2019 Tundra SR5
    I’ve used clay and dropped it on the garage floor more than once. Probably will try the nanoskin this time. Thanks.
    Pudge[QUOTED] likes this.
  9. Mar 12, 2019 at 6:49 PM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    When i use a clay bar i put it in the middle of a damp chamois. This way you dont have to spray detail spray and you wont drop it either. I can clay my vehicle in 10 min.
    Pinay likes this.
  10. Mar 12, 2019 at 6:52 PM
    soobaroo
    Gene
    2019 Tundra SR5
    I have a Porter Cable DA. I used to apply wax and sealants by hand with my little F150 but the Tundra is too big to waste time like that. A regular cab stepside looks small compared to a double cab.
    Buildn[QUOTED], Pinay and Pudge like this.
  11. Mar 12, 2019 at 6:54 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
  12. Mar 12, 2019 at 6:55 PM
    soobaroo
    Gene
    2019 Tundra SR5
    Good tip. You can get some type of holder for the bars too. I think I’ve seen them sold together.
    Faht Nocker[QUOTED] likes this.
  13. Mar 12, 2019 at 7:00 PM
    Faht Nocker
    Woody
    Milky Way
    If i were you ...i would start with a light polish. For example , I use meguiars 205. Then examine to see if you need to actually correct the paint. My $.02
    Pinay likes this.
  14. Mar 12, 2019 at 7:48 PM
    soobaroo
    Gene
    2019 Tundra SR5
    That’s why I was thinking Klasse AIO since it has no abrasives but cleans well. That’s if there is nothing to correct. Otherwise I have Griots final polish if it needs it. I don’t want to be using something as abrasive as a swirl remover on a new truck but this is my first black vehicle. I don’t know what it’s going to take to keep the paint looking good other than staying out of the car wash. I stick to Optimum no rinse as often as possible.
  15. Mar 12, 2019 at 7:50 PM
    Pudge
    CT
    I would seriously look into a ceramic coating and/or some paint protection film. You seem to be pretty knowledgeable as far as detailing goes. You could ceramic coat your own truck for a couple hundred bucks, the sooner the better, especially with black
    War Machine likes this.
  16. Mar 13, 2019 at 4:53 AM
    War Machine
    War Machine SSEM # 5 3MW
    Thanks for the plug, Monet!
    @soobaroo this is what has gotten me the best results on my black Tundra. The only thing that has made it look better is a really expensive wax that I wouldn’t recommend due to price and lack of durability. There’s a shopping list in there somewhere.
    Like @Pudge said, ceramic coating is a great idea, though time consuming, and possibly expensive. To be completely honest, if I’d paid full price for it, I’d be disappointed. Though it lasts longer, I really don’t think it looks better than anything else I’ve done to it. The true benefit was the paint correction.
    Pudge and Pinay[QUOTED] like this.
  17. Mar 13, 2019 at 4:44 PM
    soobaroo
    Gene
    2019 Tundra SR5
    You’re referring to Beadmaker? I watched a couple of videos about it and it looks interesting. I like that you can put it over wax or sealants if I understood correctly. Looks like a good way to extend the life of whatever else you use plus it looks good. It’s on my must try list.
  18. Mar 31, 2019 at 9:59 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    That's what I use on my black Avalon and my Tundra. Porter Cable. Also use Pinnacle products!
    Buildn[QUOTED] likes this.
  19. Mar 31, 2019 at 10:07 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    I've always been afraid of burning through the paint with a orbital.
  20. Apr 1, 2019 at 6:25 AM
    soobaroo
    Gene
    2019 Tundra SR5
    The Porter Cable will stop spinning with just a little too much pressure. You’d have to try really hard to damage your paint with one. A rotary is a different story, better know what you are doing.
    Buildn likes this.
  21. Apr 1, 2019 at 6:28 AM
    soobaroo
    Gene
    2019 Tundra SR5
    I’m going to try Blackfire One Step to get it clean and then top that with Pinnacle Sovereign liquid.
    r1-superstar[QUOTED] likes this.
  22. Apr 1, 2019 at 6:38 AM
    r1-superstar
    DB
    UTAH
    The Porter Cable is AWESOME!!! I'd have to use sandpaper on my pad to scratch or burn the paint.
  23. Apr 1, 2019 at 8:44 AM
    briarpatch
    For someone new to machine polishing, make sure the orbital you choose is free spinning, like the Porter Cable or the Griots Garage 6" DA. Flex, on the other hand, makes a forced rotation orbital, which is more like a rotary.
