Finally No More Rubbing
Discussion in '1st Gen Tundras (2000-2006)' started by Wilk95, Jan 10, 2026.
  1. Jan 10, 2026 at 7:48 PM
    Wilk95
    Wilk95 [OP] New Member
    2004 Limited DC 4x4
    Suspension: Leveled with SPC UCAs, Bilstein 5100s, OME springs, Suspension Maxx links. 2013 OEM 4Runner wheels, 1 in wheel spacers, 34x10.5x17 Toyo AT3 Audio: Alpine ILX W650, Morel Maximo Ultra 602 MKII in the front, Morel Maximo 6 in the rear, 2x Audison APS 8R Prima subwoofers, Audison SR 5.600 amplifier
    IMG_0010.jpg IMG_0011.jpg Recently replaced my wheel setup with some older 4Runner wheels and 34x10.5x17 wheels. Already had a ~2inch level in the front with SPC uppers but this set up rubbed due to the fairly large positive offset on the wheels. Added 1 inch wheel spacers with some minor trimming and everything is clearing great now. Just wanted to post showing skinny 34s will fit with some minor trimming. I’m guessing spacers wouldn’t be needed with a more aggressive offset
    mayan, bmf4069, Corndog123 and 2 others like this.
  2. Jan 10, 2026 at 7:56 PM
    bing5
    bing5 Fight the powah
    New Mexico
    2004 DC SR5 4WD V8
    Nice DC! Oh, and welcome from NM!
    Wilk95[QUOTED][OP] likes this.
  3. Jan 10, 2026 at 8:03 PM
    Wilk95
    2004 Limited DC 4x4
    Thank you!
  4. Jan 10, 2026 at 8:11 PM
    Casper421
    In the woods
    06 DC
    Adding some positive caster would give you more room against the pinch weld. Tire looks pretty far back in your wheel well.
    Wilk95[OP] and PNW15 like this.
  5. Jan 11, 2026 at 5:07 AM
    Corndog123
    Corndog123 Knife creator.
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Great looking truck!! Welcome from TN!!
  6. Jan 11, 2026 at 9:29 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    Is 34x10.5x17 the size on the tire? Tirerack only shows 2 in that size and neither of them are true 34s. They’re both 33.5 tall. I’m planning on going 255/80/17 here soon, I thought that size was limited but dang. 33.1 vs 33.5, that .4” isn’t worth the entry fee.
    PNW15 likes this.
  7. Jan 11, 2026 at 9:35 AM
    Casper421
    In the woods
    06 DC
    If you want a true 34(33.8-34.1) and an 11-11.2 isn’t too wide, I’d recommend looking at 285/75r17’s.
    Tlar25 and FrenchToasty like this.
  8. Jan 11, 2026 at 1:11 PM
    Elevatorguy
    James
    I don’t want it that tall, just curious what the real size is the op is referring to.
  9. Jan 11, 2026 at 1:39 PM
    shifty` Got patience on my neck like a cold, cold knife
    34x10.5r17, not sure what brand/model he's got there, but here's an example in the BFG KO3: https://www.tirerack.com/tires/tires.jsp?tireMake=BFGoodrich&tireModel=All-Terrain+T/A+KO2&partnum=405R7KO2RWL&GCID=C13674x012-tire
    It just looks weird because he left out the "r", or maybe because the first two digits are the diameter in inches versus the width in millimeters
  10. Jan 11, 2026 at 6:13 PM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    What tire you got on this truck op?
  11. Jan 11, 2026 at 6:25 PM
    Wilk95
    2004 Limited DC 4x4
  12. Jan 12, 2026 at 10:28 AM
    bmf4069
    bmf4069 Scored 4 touchdowns vs Andrew Johnson High School
    Beau
    TX
    02 AC sr5 4wd v8
    Well now I've got more decisions to make. I was looking at 255/85r17s not realizing 34x10.5x17 was a thing. They're both about the same price.
  13. Jan 12, 2026 at 2:44 PM
    Elevatorguy
    James
    Well TR lists 1 in the 255/85 and 2 choices for 34x10.5. With that huge selection to choose from how would one choose!? Atleast the 255/85 measures 34.6”.
