Falken Wildpeak ATs
Discussion in 'Wheels & Tires' started by Alex261, May 5, 2021.
  1. May 5, 2021 at 2:29 PM
    Alex261
    Alex261 [OP] New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    Anyone know how the Wildpeaks are on the highway? Are they smooth? I’m looking to go with the slightly bigger size 275/60/20 over the stock Bridgestones which are great on the highway. I do a lot of highway driving, no towing, and minor off roading. I noticed on the website that I can choose between load range “sl” or “d” and I was wondering if the “sl” would be a better tire for what I do. I’m not sure what load rating I have with the stock tires. Thoughts would be appreciated
  2. May 5, 2021 at 2:35 PM
    Wallygator
    Mine are pretty smooth but probably not as smooth as the load ranges you listed because I have load range E Wildpeaks. So far they have been great tires and are wearing well. Good in the snow also.
    Your stock tires are most likely P rated. Atleast mine were and that is why I got rid of them for the E rated Wildpeaks
  3. May 5, 2021 at 2:36 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Stock tundra tires are SL-standard load. I run 275/70-18 wildpeaks, load E. Wildpeaks are great, ride well, quiet and look beefy.
  4. May 5, 2021 at 2:37 PM
    frichco228
    And as far as load, SL tires will ride best- best if softer feel is what you like. D and E load ride firmer, especially on a half ton truck.
    Wallygator likes this.
  5. May 5, 2021 at 2:37 PM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    I have been running the Wildpeaks for over a year now and love them. Actually the size you are looking at. I think they do fine on the highway and i can't really hear them. But i do have the TRD dual exhaust so that's probably why, lol.
  6. May 5, 2021 at 2:39 PM
    Alex261
    Alex
    Boston, Ma
    What load range do you use
  7. May 5, 2021 at 2:47 PM
    DUKFVR
    DUKFVR New Member
    Houston & Young County TX
    2020 Cement Tundra DC SR5, Stage 1 Icon kit, LT75/60/20 Toyo AT III, Ranch Hand Midnight Bumper Replacement
    My son has a set on his tundra. Quiet nice ride for an A/T.
  8. May 5, 2021 at 2:48 PM
    Sitting Sideways
    Sitting Sideways Probably stuck somewhere
    Beaverton, Oregon
    2021 White CM Tundra TRD Off Road
    Icon IR Coilovers, Icon Delta Joint tubular upper control arms, Icon PB CDC rear shocks, Icon Expansion Pack, Icon Hydraulic Bump Stops, Durobumps front bump stops, TRD dual exhaust black tips, TRD pro skid plate, TRD cold air intake system, TRD pro shift knob, TRD Pro Wheels, Falken Wildpeak AT3W tires, TRD radiator cap, ESP under seat storage, spray in bed liner, bed rail system, SDHQ abs guards, black tundra letter inserts, center console wireless charger, center console organizer/tray, charcoal filter removal, whistle screen removed, RCI Transmission/Transfer case skid plate, and ICON neoprene shock wraps
    I am running 285/75r18 wildpeaks load E. Truck rides a bit stiffer than the stock SL but the truck handles way better. The load E tires don’t flex as much in corners and I don’t feel like I am going to roll the tire off the bead in a hard corner or evasive maneuver.
  9. May 5, 2021 at 2:50 PM
    ezdog
    ezdog New Member
    Gateway To The West
    I have them in the stock 18" size and SL rating and am shocked still at how quiet and smooth riding they are but while still being great in bad weather and Snow too.
    It is an unusual combination in an aggressive looking tire on a full size truck in my experience too.
    I also have had several sets of Bridgestone Revo on my 2001 Tundra and they are almost the same amazing performance and quiet but they look like they would be quiet but not perform too,but they do!
  10. May 5, 2021 at 2:55 PM
    1/68AR Ventre A Terra
    1/68AR Ventre A Terra New Member
    2019 Platinum
    Viking Heaven Cat Shields and SR5 Rims
    I was wondering about Wildpeak AT3 myself. I want to go 285/60/20 since the width only adds about 2/10th of an inch on the inside wall. When I looked at a link about tires on here, it reads you can go to 65 diameter but not wider. Anyone know if that is true? I have a 19 platinum
  11. May 5, 2021 at 3:53 PM
    COElkHunter
    COElkHunter New Member
    Jeremy
    2012 Silver Tundra TRD limited Crewmax 4x4
    3" OME lift w/ UCAs. ARE overland shell w/ ARE roof rack. 34" Falken Wildpeaks. ARB awning. Road shower. Wilco Offroad Hitchgate Solo High Clearance. LED lighting upgrades. Lockerdown console safe. Weathertech floormats. Duluth deluxe rear seat cover to go under the offroad approved car seats.... :P
    I have the 275/60 r20 Wildpeaks in a load range E. Love them. Ride nice and smooth, although I haven't had a truck with anything but AT tires for years, so my perspective is probably skewed. They seem quieter than the BFG KO2 ATs I have on my LX470 and work truck, and are definitely noticeably better in the snow than the BFGs. (Which says a lot, because the BFGs are pretty damn good.)
  12. May 5, 2021 at 3:54 PM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    I had 275/70/18 Es and they were very impressive on the Highway and off-road.
    That is when they were $170 a tire so they were pretty much the best deal around. Now they are $270 a tire and you can do better for cheaper.
  13. May 11, 2021 at 7:25 PM
    farm&forest
    farm&forest New Member
    2021 Tundra SR5 TRD-Off Road Double Cab
    Dobinsons 2-3" Complete Suspension Kit w/ medium Dobs Leafs, Decked Drawer System, Leitner Forged ACS Rack, Line-Xed bed and Line-Xed Tyger Blade Steps, Wet Okole seat covers, VLED lighting, soon to add Swith Pro and auxillary lights
    I'm considering a set of these in E to replace my OEM Michelins...thinking of sticking to stock size 275/65r18...
    Can anyone speak to their experience with these in snow and rain?
  14. May 11, 2021 at 8:17 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    They worked well in my first winter with them here in the snow capital of the world.....Winnipeg. No issues in rain either, but I haven't done any serious rain driving with them, just daily driving.
    I'm running 275/70/18.
  15. May 11, 2021 at 9:34 PM
    BrunoTheRescuePup
    BrunoTheRescuePup New Member
    SW Portland Metro
    2021 MGM Limited TRD
    Eibach Pro-Truck 2.0, Coachbuilder +1, Undercover Flex, Tyger Star Armor, TRD Rear Sway Bar, DD SS3 Max, MisoCustoms
    Sorry, what is better for cheaper?
    Not trying to be a smart ass... in the same boat as others and am curious as to what you would recommend.
    thanks in advance.
  16. May 11, 2021 at 10:29 PM
    COElkHunter
    Jeremy
    They are awesome in the snow and rain. I live at 8200' and drive a steep mountain road 80 miles round trip daily with either my work truck with BFG KO2s or my personal truck with the Falkens. I rarely even put it in 4wd with the Falkens unless its really nasty, they definitely grip better than the BFGs, which I'm much quicker to hit 4wd on. Both trucks probably carrying 500lbs in the back daily, although the shell on the Tundra probably keeps the weight a little further back over the axle than the toolbox on my Dodge.
  17. May 11, 2021 at 11:19 PM
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    We live in the mountains with a lot of snow, rain and mud. I have had Michelins, BF Goodrich ATs, Bridgestone and the Falken Wildpeak made under a different name (Open Range AT) for Les Schwab. The Wildpeak is the best tire I have ever had. We have them on both of the 4Runners and the F250 but we don't have them on the Tundra yet. I am not going to put them on the Tundra until I do the lift. Then it will get new wheels and Wildpeaks. The Wildpeaks are cheaper at Discount than the Open Range AT at Les Schwab.
    Great traction and super smooth and quiet comparatively.
  18. May 12, 2021 at 3:07 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    0424211438.jpg I'm running the Wildpeaks AT3 in a 295/70/18s on a 3/1.5 Toytec Coilovers lift and the tires fit the whole combination well... Beefy looking, great AT looks, both on road and off road versatility , plus highway quietness. All in one... Great tire.
    Wallygator and farm&forest like this.
  19. May 12, 2021 at 3:23 AM
    Black
    Copper Discover
    AT3 4s
    AT3 XLT
    ST Maxx
    ST Pro
    All are cheaper or right about the same price.
    The new Cooper Discoverer Rugged Trek looks awesome and very likely will be my next tire but they have only been out about a month so we’ll see how folks like them.
    I have become a really big Cooper fan. Great tires, great prices, lots of options in the 275/70/18 size.
    And they are made in the USA. I really hope the new Goodyear buyout does not screw any of that up.
    I had the Falkens and they are a really good tire and they used to be super cheap which made them an absolute must buy. Now they have gone way up in price.
    I’ll spend less money on a tire just as good if not better and made in the states now.
    farm&forest likes this.
  20. May 12, 2021 at 5:43 AM
    Dan_Gleesac14
    Dan_Gleesac14 New Member
    2023 Tundra SR5;2018 Tundra Platinum (SOLD)
    I recently threw some 295/70/18 Wildpeaks on some new FN wheels and have put about 4,500 miles on them, 2,000 of those miles last week on a roadtrip to Kentucky. I honestly have no complaints. I'm due for a rotation soon so I'll check tire wear a little more than me sticking my head between the fender lol. As far as road noise, nothing crazy or too noticeable. This is my first truck and A/T tires so nothing to really compare to, but I was very comfortable as the driver and passenger with these tires.
  21. May 12, 2021 at 5:49 AM
    Classy63
    Classy63 Valhalla’s Shield guy
    Tyler
    Cypress Texas
    15 platinum Barcelona red
    Toytec Aluma 2.0 front and rear, Toytec shackles, Toytec add a leaf pack, Tuff Country UCA’s, Firestone bags with daystar cups. JBA long tubes, w/3” cats, Dirty Deeds TRD replacement, DAP tune, AFE filter
    I don’t have them on my truck yet, but they are on my trailer
  22. May 12, 2021 at 5:55 AM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    20210217_063120.jpg Screenshot_20210126-135915_Video Player.jpg 20200824_190851.jpg
    I'm running the P rated 275/60R20 Wildpeak AT3W on all kinds of terrain and love them. Ive had them on a little over a year and 12k miles with zero complaints. I don't tow heavy stuff so P rated is fine with me. I have pics of them on stock Platinum wheels too if you want to see them.
  23. May 12, 2021 at 5:56 AM
    Alex261
    Alex
    Boston, Ma
    Yes pleas send on stock wheels. P Ratex means SL rated?
  24. May 12, 2021 at 5:58 AM
    TNTundra16
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    Here ya go. Stock height with all mudflaps on.
  25. May 12, 2021 at 5:59 AM
    TNTundra16
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    Yes the standard load
  26. May 12, 2021 at 6:05 AM
    TNTundra16
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
  27. May 12, 2021 at 6:55 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    Quiet is a relative term. They are definitely louder than an HT tire. They ride harsher than an HT tire. But you get more grip off road and in the snow than the typical HT tire. They look fantastic though. I put the Falkens on last summer. Truth be told, if I had to do it over again, I'd probably go with the Cooper AT3 4S or the Yoko Geolander AT. I believe both of those are closer to an HT tire than the Falkens in terms of road noise and ride quality. But I don't have any complaints about the Falkens.
