Failing rear Diff at 54k!? 2004 Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by zachdudeboat, Nov 27, 2021.
  1. Nov 27, 2021 at 10:58 AM
    zachdudeboat
    zachdudeboat [OP] New Member
    Zach
    2004 Tundra Limited
    What's up everybody! This is my first post here and I am desperate lol. I bought a 2004 Tundra, Limited, double cab with an LSD, two owner. It has 54,000 miles on it and is FLAWLESS but the lsd is making a moaning and slight grinding noise and I am devastated after paying $24,000 for the truck. The truck has been sitting in a garage for a few months after the owner passed away and the owners son is who sold it to me. I have been in contact with him about the issue and he has no idea what it could be. I think it has gotten worse since the test drive and 5hr drive home considering I barely noticed anything on the test drive. I drained the fluid and the magnetic plug had one metal chunk but the rest was very fine metal build up. I put castrol 80-90W GL-5 lsd fluid in the diff with no change. greased U-joints as well. it doesn't seem to be wheel bearing considering I can put the truck in neutral and the noise goes away. Carrier bearing has some play but is making no noise with the truck on jack stands and the wheels spining with the truck in drive. I also filmed the carrier bearing with the truck up to speed and it had no wobble and made no noise. its definitely coming from the dif and I can FEEL the NOISE with my hand the best if I put it up to the back of the casing (opposite side of drive shaft). The noise is more of a whine up to speed (30 - 70 MPH) and more of a growl/deep grind and low speeds.
  2. Nov 27, 2021 at 11:12 AM
    zachdudeboat
    Zach
    2004 Tundra Limited
  3. Nov 27, 2021 at 11:30 AM
    RainMan_PNW
    RainMan_PNW SSEM #82 RGBA #4 “That Guy” Vendor
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    First: welcome!
    Second: how they hell did you find an ‘04 with only 54k miles?! Unicorns apparently are real! (And congrats)
    Third: I’m not the guy to help trouble shoot this one, but @empty_lord and @shifty` and @daveeasa all might have some good insight
    zachdudeboat[OP] likes this.
  4. Nov 27, 2021 at 11:33 AM
    04DCTundraMan
    04DCTundraMan Crimedog McGriff
    Ryan
    2004 Salsa Red Tundra Limited DC
    Sony Head Unit, Pioneer Speakers, Back up camera, Blacked out Emblems, SPC Control Arms, OME 2.5" front lift, 1.5" rear spacer, Flowmaster Super 44 muffler, LineX bedliner
    Tagging along cuz I’m curious but I hear it…also, you have brass balls for getting under in front of the rear tires while it’s going sir!
    zachdudeboat[OP], BTBAKER and TTund16 like this.
  5. Nov 27, 2021 at 11:55 AM
    shifty` Our private little trip to hell
    Gearing isn't my thing, electrical, plumbing, and engine diags are my stronger suits. But maybe @empty_lord can provide some input?
    Edit to say: If LSD, that oil looks awfully light for fluid in that pic. Is it possible PO put non-LSD fluid in LSD rear-end? I'd expect heavier.
  6. Nov 27, 2021 at 12:03 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Looks like a bad day man. I’m guessing your diff is toast. Thankfully, a 3rd member swap is pretty easy. Just remove the wheels, drums and rear brake lines, the 4 axle bolts on each side, slide the axles out, and unbolt all 10 3rd member bolts and the diff will pop out. Do the reverse to install the new/used one.
  7. Nov 27, 2021 at 12:52 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Could be why its only got 54k.
    Chunk could be from the Ring & Pinion and/or bearings. Time for a new 3rd member. Definitely a bad diff.
  8. Nov 27, 2021 at 1:46 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Sounds like a shot diff.
  9. Nov 27, 2021 at 2:13 PM
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    I wonder what would cause one to fail at such a low mileage.
    OP- when you replace the diff, I would add the diff breather mod. You can search it on here or Google it.
    zachdudeboat[OP] and dinosaur like this.
  10. Nov 27, 2021 at 2:57 PM
    empty_lord
    05 rollover special
    My 05 had its diff replaced under warranty at 50k due to a growl. It happens. Could be the fluid that was put in it over its life
    zachdudeboat[OP], dinosaur and lsaami like this.
  11. Nov 27, 2021 at 5:31 PM
    I'd be super pissed if I spent that much coin on a truck just to have this happen right after. I paid about half that for mine and it only had less than 10k more miles.
    Hell, I was frothing pissed off because the alternator burned up - literally caught fire - less than 2k miles after I bought my truck.
  12. Nov 27, 2021 at 6:09 PM
    sn_85
    sn_85 New Member
    Boise
    2006 DC Tundra 4WD, 2013 Land Cruiser, 2022 RAM 2500 Bighorn
    Sucks to hear that but you still have a unicorn of a vehicle for a good price. Gears are a replaceable part. At least it's not the engine or transmission. FYI, Nitro Gears is having a 25% off sale through the 29th. You might want to jump on that while you can.
  13. Nov 27, 2021 at 6:42 PM
    zachdudeboat
    Zach
    2004 Tundra Limited
    Wow thank you guys so much for the quick responses I am blown away! you guys have some sick looking trucks. This has been so helpful and comforting, I have been a bit devastated. So as far as replacing the diff, what exactly do I need to get and where is the best place/parts? I had a sprinter van before this truck so i am a suppppper noob to these trucks. I cannot thank you guys enough and I am so stoked to be on this forum with yall! I'll be looking for other threads that may entail a diff replacement. I will be checking out the sale on Nitro Gears for sure
    Leo's first, Platinum714 and BTBAKER like this.
  14. Nov 27, 2021 at 6:49 PM
    Totally OT, but are you in FL by chance?
  15. Nov 27, 2021 at 7:16 PM
    zachdudeboat
    Zach
    2004 Tundra Limited
    I am in Carolina Beach NC!
    shifty`[QUOTED] likes this.
  16. Nov 27, 2021 at 7:40 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    If those are the stock 18" 'BBS' wheels that came on the Darrell Waltrip Edition . . . that's your problem . . . you'll need to take those off and send them to me In So Cal so I can send you mine off my 2006 (Split 5-spoke models in excellent shape) in exchange. . . that should clear-up the problem !
    If it doesn't... you may need a new 3rd member ! LOL. . . .Kidding aside, while that sucks, if you can get a decent price on a new one and drop it in, you'll be good to go for a VERY long time . . . unless there's some weird voodoo going on with the axles etc. which is unlikely. Sounds like just a stroke of bad luck . . . hang in there & keep us posted. Good Luck.
    TXTundra2722 likes this.
  17. Nov 27, 2021 at 7:44 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Depends on if you want to re-gear, swap LSD or do a locker and if it's a 4x4 you'd need to swap the front too.
    Easiest way is to get another 3rd member with the same ratio (center portion of the diff) and swap it.
  18. Nov 28, 2021 at 3:58 AM
    zachdudeboat
    Zach
    2004 Tundra Limited
    HAHAHA you a funyyyy guy... yeah the first owner got these BBS wheels as an upgrade we he bought the truck new. I really hope there is no voodoo going on that is what I fear the most right now lol. really hoping once i swap this diff it will be smooth sailing
    HBTundra[QUOTED] likes this.
  19. Nov 28, 2021 at 4:50 AM
    zachdudeboat
    Zach
    2004 Tundra Limited
    So this is the diff i've been looking at, its not an LSD and its expensive https://www.nationaldifferential.com/products/2000-2006-toyota-tundra-rear-third-member.html
    just an option, says it come with axles, hubs, baking plate and a 3 year warranty. It would be sick to find a used one for cheap but everything else on the truck is so new and has only 54,000 miles so a new one would be ideal. May reach out to the toyota dealership here in Wilmington to see what they have to say!
    Gear ratio should be 4.10 since I have a V8, double cab, 4X4 2004 model based off this -
    dinosaur likes this.
  20. Nov 28, 2021 at 5:38 AM
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
  21. Nov 28, 2021 at 5:55 AM
    zachdudeboat
    Zach
    2004 Tundra Limited
  22. Nov 28, 2021 at 5:57 AM
    FirstGenVol
    East TN
    2002 AC
    If you are having to go through the cost and work of replacing I would do a LSD or rear locker. Locker would be sweet.
    speedtre, ColoradoTJ and dinosaur like this.
  23. Nov 28, 2021 at 6:51 AM
    dinosaur
    dinosaur New Member
    Dave
    2004 DC Tundra 4x4
  24. Nov 28, 2021 at 7:17 AM
    Punk1974
    J.P.
    free and contactless delivery and you will still have $ to buy beer after the job -J.P.
  25. Nov 28, 2021 at 8:41 AM
    zachdudeboat
    Zach
    2004 Tundra Limited
    I think I am about to send it on one from these guys. They have a 5 year warranty and a super fair core charge system. Thank you so much for showing me this! They also hook it up with gear oil for 40$ so I don't have to go to the auto parts store... Until I don't have a tool I need of course LOL
    Edit - Part is ordered!! I'll let y'all know how it goes. So excited for it to get here, really looking forward to having this truck right for trips out west to go snowboarding.
  26. Nov 28, 2021 at 9:28 AM
    LML 3500HD
    ECGS has always been really good quality and stands behind their work. They might be a little more, but you pay for quality.
  27. Nov 28, 2021 at 9:42 AM
    empty_lord
    05 rollover special
    ZUK does quality work too if you can afford to be down the truck long enough to send him the diff.
    FrenchToasty and dinosaur like this.
  28. Nov 28, 2021 at 11:09 AM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    All the 1st gen Sequoias are also 4.10 and the diff is the exact same. Easier to source. You'd just need someone to swap the LSD (maybe rebuild it) and set backlash correctly.
    FrenchToasty likes this.
  29. Nov 28, 2021 at 5:51 PM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    Believe first gen Sequoia's also have disc brakes instead of drums. That would be a sweet upgrade, but not a direct swap or for the faint of heart. It's been done here before. You could just rob the third member out though.
  30. Nov 28, 2021 at 5:53 PM
    empty_lord
    05 rollover special
    If you can weld, you can put leaf spring perches and shock mounts on a sequoia axle. Then you do indeed have rear disk
