Factory Tow package light Receptacle
Discussion in 'New Member Introductions' started by cappy1075, Oct 3, 2021.
  1. Oct 3, 2021 at 1:39 PM
    cappy1075
    cappy1075 [OP] New Member
    Greetings to all. I'm new to the site and recent owner of a 2011 TRD Rock Warrior. Hooked up a trailer today and I only have running lights. I tested the truck side front and back pins of the receptacle and it shows power to only Charging pin and Running lights. No flashers no signals no brake or Back up lights. I checked both fuse boxes Engine compartment numbers 6, 11, 14, 17 all were good checked side panel fuse box numbers 20 and 22 they were good. I inspected the harness and no damage its in great shape and well protected. I'm at my wits end traveling out of state and have to get this thing working properly. Any suggestions? am I missing a relay or a fusible link in the harness? Not sure how to proceed.
  2. Oct 3, 2021 at 3:33 PM
    Try one of these maybe? https://www.homedepot.com/p/CURT-7-Way-RV-Blade-Connector-Tester-58270/205632731
  3. Oct 3, 2021 at 3:52 PM
    2mchfun
    Does the truck have brake and turn? Did you try to unplug the harness and check the pins behind the bumper? Look for rodent damages? You could also run some temporary wires for your trip. Battery powered wireless magnetic light set works by plugging transmitter in inside the cab.
  4. Oct 3, 2021 at 5:21 PM
    cappy1075
    Yes I tested the pins behind the bumper and at the Y. Only running lights nothing else testing positive. Wondering where the tow light relay is? I can only find fuse schematic
  5. Oct 3, 2021 at 5:32 PM
    2mchfun
    Are you having someone push the pedal when your testing for brake?
  6. Oct 3, 2021 at 6:25 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Have you checked the wiring coming into the rear bumper for damage? There have been a lot of people with rodent damage to their wiring. Welcome to the site from LA (Lower Alabama)!
  7. Oct 3, 2021 at 6:32 PM
    cappy1075
    Thanks and yes I checked the wiring it looks to be fine the factory corregated sleeve is over it and intact.
  8. Oct 3, 2021 at 7:13 PM
    ^^This^^
    Welcome from NY.
  9. Oct 3, 2021 at 7:55 PM
    Welcome from Ohio
  10. Oct 3, 2021 at 8:39 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  11. Oct 4, 2021 at 6:32 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    If you haven't already, I would trace it all the way back to the fuse box. Those little demons with teeth can squeeze in anywhere.
  12. Oct 4, 2021 at 10:04 AM
    cappy1075
    Thanks for all the greetings and the replies. Problem solved turned out fuse #14 in engine compartment was missing. New problem a rose while trying to find the issue. Rear camera in the mirror doesn't come up. Only gets blue screen for a few seconds then off
    2mchfun likes this.
  13. Oct 4, 2021 at 10:35 AM
    2mchfun
    The good news is you have trailer lights. Many of us lived for a long time without cameras in vehicles, in my opinion just more crap to go bad, guess my opinion just became fact.
    cappy1075[OP] likes this.
