Factory Back Up Camera Replacement
Discussion in '2nd Gen Tundras (2007-2013)' started by tallguy240, Jun 5, 2025.
  1. Jun 5, 2025 at 10:07 AM
    tallguy240
    tallguy240 [OP] New Member
    Patrick
    2009 Grey Tundra Limited
    Projector Style headlights, leveling system, LED Fog Lights, LED interior lighting, Toyota emblem projector door/puddle lamps, LED puddle lights in rear view mirrors, Tonneau Cover, Bed LED lighting, 3 inch lift, trailer braking system, and aftermarket audio system.
    I have a 2009 Limited with the factory backup cam in the tailgate. I recently got a new head unit with a 10in. screen and the view from the backup cam is passable but I would like one with better resolution. Has anyone changed their factory BU cam to a newer one and if so what issues did you run into? Anyone have a 'How To' or walkthrough of the process? If I need to take it to an install place I can do that. Just curious if the wiring will even support higher res or will new wiring be required and if anyone has a brand of camera to look at or use that will fit the factory spot. Thanks!
  2. Jun 10, 2025 at 7:37 PM
    tallguy240
    Patrick
    I found an Amazon solution. Super easy to install and price was right.
  3. Jun 11, 2025 at 9:44 AM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    /thread
