Extensions O2 sensors catalytic converter 2010+, move em' back? Anyone make them?
Discussion in 'Performance and Tuning' started by Youngfrankenstein, May 1, 2020.
  1. May 1, 2020 at 11:45 AM
    Youngfrankenstein
    Youngfrankenstein [OP] New Member
    2015 4x4 CM SR5
    Hello everybody. Does anyone make plug in, (Molex ends?) extensions for moving factory converters back a couple feet?
    Thank you.
  2. May 10, 2020 at 1:05 PM
    Youngfrankenstein
    2015 4x4 CM SR5
    Hello again? Anyone know about any extensions made? To avoid cutting the originals? Thank you.
  3. May 10, 2020 at 1:05 PM
    Youngfrankenstein
    2015 4x4 CM SR5
  4. May 12, 2020 at 8:27 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    I recommend soldering the wires into the existing o2 sensors. Don’t buy extensions. They never seal correctly and leak water. And your truck runs poorly until you disconnect the plugs and blow out the water. Ask me how I know this;)
    wire
    Solder
    Heat shrink
    Tape
    Split loom
    =good as stock
    5N0W808 and FrenchToasty like this.
  5. May 12, 2020 at 12:40 PM
    Youngfrankenstein
    2015 4x4 CM SR5
    OK. I can do that. I trust you know this from many experiences. Thank you!!!
