Exhaust rust
Discussion in 'Performance and Tuning' started by mungk, Mar 10, 2018.
  1. Mar 10, 2018 at 8:38 AM
    mungk
    mungk [OP] New Member
    Washington DC
    2017 Cement Pro
    can you guys post pics of what your exhaust piping looks like? Mine has 3k miles and looks pretty rusty. About to treat it with ACF-50 and wanted to see what others looked like.
    Tundra Girl likes this.
  2. Mar 10, 2018 at 8:44 AM
    15whtrd
    15whtrd Mr. Blonde
    Where do you live? The exhaust is stainless. Obviously not rust proof but should last a looong time. The welds may have surface rust but nothing to worry about. If it really bothers you, take it off and prep for some high temp paint. I took my stock exhaust off at around 16,000 miles. Almost 0 rust just some discoloration.
  3. Mar 11, 2018 at 9:24 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Stock pipe is 409ss. Muffler and hangers 304ss. Flanges are steel.
    It will all get corrosion with salt.
  4. Mar 15, 2018 at 11:39 PM
    mungk
    Washington DC
    2017 Cement Pro
    This is what mine looks like after 3000 miles and one mild winter. Live in DC. Is this what yalls is looking like?
  5. Mar 16, 2018 at 12:30 AM
    Moss01
    Moss01 New Member
    17 Crewmax SR5 MGM
    Mines looks just like that on my 17. Im just north of you in Baltimore. 18k miles
  6. Mar 16, 2018 at 4:12 AM
    T500
    T500 # The Dark Side
    Alfie
    Neptune, NJ
    2020 Black
    Mine is the same. 24k miles. Live near the ocean.
  7. Mar 16, 2018 at 4:47 AM
    15whtrd
    15whtrd Mr. Blonde
    Damn. That is bad. Mostly surface rust at this early on. They must use some nasty shit on the your roads where you live.
    Pudge and TheBeast like this.
  8. Mar 16, 2018 at 4:53 AM
    Tundra Girl
    Tundra Girl New Member
    Maddy
    New York, Long Island
    2017 Tundra Limited Metallic Black
    TDR Sway Bar
    Min just hit 5k miles and looks like this. Was wondering the same.IMG_20180226_124209944.jpg
    Also I have rust on the hitch attachment :(
  9. Mar 16, 2018 at 5:30 AM
    15whtrd
    15whtrd Mr. Blonde
    I wouldn’t worry about the hitch. It’s a lot of thick metal. You want to look like you use it right? LOL I want to say whatever chemical they’re putting down on your roads is nasty. Our exhaust pipes are stainless. So I actually think whatever crap is getting flung up onto your exhaust pipe is what is rusting, not the pipe itself.
    Tundra Girl[QUOTED] likes this.
  10. Mar 16, 2018 at 9:02 AM
    Rica25
    Ricardo
    Tulare
    Crazy shit out here mine has 120k and 10yrs old still looks brand new
  11. Mar 16, 2018 at 9:26 AM
    TheBeast The Beach
    man even your leaf pack starting to rust. I think it has to do with what they put on your roads.
    15whtrd likes this.
  12. Mar 16, 2018 at 8:57 PM
    Tundra Girl
    Maddy
    TDR Sway Bar
    Anything to think I can clean it with and then protect it with, or prolly not? I'm getting the whole thing ceramic wrapped. I wonder if that can do that also.
  13. Mar 16, 2018 at 9:16 PM
    15whtrd
    15whtrd Mr. Blonde
    To clean I would try a vinegar soaked rag first. Let it sit. Probably really time consuming. They make rust converter for stainless. Not sure if safe for exhaust. Some of it turns black. I would think of removing and spraying with a high temp paint.
    Not sure about ceramic coating.
  14. Mar 16, 2018 at 9:24 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    These exhausts are made in Canada. They might know a bit about snowy conditions.
    15whtrd likes this.
  15. Mar 16, 2018 at 9:32 PM
    15whtrd
    15whtrd Mr. Blonde
    I think it’s not rusting, it’s the contaminants/chemicals from the road, built up on the surface. This crap must have Iron in it.
  16. Mar 17, 2018 at 4:12 AM
    Wolverine
    Wolverine New Member
    Jeff
    Michigan
    2019 SR5 CM Cement
    Fluid Film fellas
    VRC likes this.
  17. Mar 17, 2018 at 4:21 AM
    tye
    tye New Member
    tye
    2016 TRD Pro DC
    Diamondback cover, flowmaster exhaust, n-fab sliders
    Yes it is rusting and it will continue to do so but it should not rust through for over ten years. I put a stainless system on in 2005 and though it is covered in rust there are no holes. Salted roads are the primary cause and there really is nothing to do due to the heat on your exhaust burning anything off
  18. Jul 6, 2018 at 4:24 PM
    Cerebus
    Cerebus New Member
    Philip
    2011 Tundra TRD RW/DC 5.7L, Magnetic Grey
    TRD SuperCharged, Rock Sliders, SkidPlate, 5100's Front, Add-a- Leaf rear, Bedliner, ToolBox.
    I have used a high-temp exhaust system spray paint from Auto-Zone with some ceramic in it, and it helps keep rust in check. Any time I get under the truck I touch up any new discoloration. In addition, I have been maintaining all the undercarriage components, and steering parts with Eastbrook rust encapsulator and or chassis black. Once the rust is under control, just an annual inspection and maintenance keeps the underside looking clean like the outside. I do an undercarriage spray to rinse off any road salt or chemicals periodically.
  19. Jul 6, 2018 at 11:16 PM
    tundras00
    tundras00 New Member
    Try to use undercarriage wash plenty of times when it snows and they throw salt.
  20. Jul 12, 2018 at 9:39 AM
    Ntmid8r
    Ntmid8r New Member
    2018 Tundra TRD Sport
    TBA
    Mine did the same thing on my 16, but not on my 11. Cheaper materials obviously. Such a shame.
  21. Sep 23, 2018 at 5:38 AM
    adm1jvt
    adm1jvt New Member
    2017 Tundra 1894 Special Edition
    As I am sure that our environments is contributing to the rust on our exhaust but I do believe that stainless steel used on the our "top of the line" TRD exhaust was and is sub-par. My previous 2009 Tundra that was 8 yrs old with over 100k miles didnt have as much rust as my less than 1 year old 2017 Tundra with 13k miles has now. Per my conversations with the dealer, it seems that for some reason there is an issue with the TRD exhaust. I have spent countless hours on the phone with Toyota and it has fallen on deaf ears. Makes me think twice next time about Toyota.... good luck, all.
  22. Sep 23, 2018 at 6:46 AM
    tundras00
    You must have a lot of time on your hands to complain about an exhaust hours and hours. I suggest you pick up a German luxury car and see how long you'll be on the phone compared to your Toyota. Everyone bitches and complains, but you really have to see the bigger picture.
    And to boot, you own a 1794 and not a 1894 as per your info. lol
  23. Sep 23, 2018 at 6:49 AM
    ARES
    ARES ARES Fabrications
    God Bless America
    2018 Tundra TRD Cement
    I took my pipes off sanded them down with 400 grit and used rustoleum high temp matte black. Looks good as new now.
  24. Sep 23, 2018 at 6:49 AM
    tundras00
    BTW, I am planning to use FluidFilm this time around to cover the underside of the body.
    15whtrd likes this.
