Exhaust muffler
Discussion in 'Performance and Tuning' started by 559WeekendWarrior, May 30, 2019.
  1. May 30, 2019 at 4:46 AM
    559WeekendWarrior
    559WeekendWarrior [OP] New Member
    Menger
    2010 SR5 5.7L PreFlex Warrior
    Custom Build Tubing 3.5 with 3.7 Trd Intake 2014-2019 with Turbo Head Shield Air Filter, Jet Performance MAF, Throttle Body Spacer With Econoaid Throttle Body Booster Gasket. Exhaust 2.5 Cherry Bomb 7841 single with dual Side frame exit or in front of the rear passenger tire. Pedal Commander plug in play for the gas pedal. Last is leveling kit 3-1 front and rear with 32-33 MT tires.
    Between these two muffler... Which one would be the most quiet. I'm going to be replacing my cherry bomb and go with either one of these two. However on everyone opinion which one has the last effect on power but has the quiet tone. Both of these are 22"-23" long so I'm looking for the best option, even though it's not a name brand but this will do for daily driving. My current one that is on my piping is a cherry bomb, The replacement of the cherry bomb and why. the plate inside has broken off from the weld so it moves around inside unless I take it off and pry it to a corner. During the afternoon to late noon the sounds is not to loud but during at nite it has the loudness where I tend to not like it. This apply on the street, however on the freeway/highway at 65-80mph it's not loud at all. This makes me feel like I'm inside a little Honda with loud exhaust and trying to not tapped the pedal so I won't be pulled over. I'm currently unclear of the loudness because the cherry is the dual 6"-7" and it has the side exit so this makes the piping shorter. But anyways back to the two muffler which one would you go with... Both muffler from the outside is the same however the inside is what different.
    This is how the muffler looks outside
    https://photos.app.goo.gl/vccVRNKiKv8QBeto6
    This is the 1st muffler
    https://photos.app.goo.gl/oQRU7v2Awqd29K2u8
    This is the 2nd muffler
    https://photos.app.goo.gl/443KEchHxTDnxSQFA
  2. May 30, 2019 at 5:28 AM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    @dirtydeeds . Get the eight inch BA muffler and call it a day. Good luck. D
    417Tundra, dirtydeeds and Black Wolf like this.
  3. May 30, 2019 at 5:41 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
  4. May 30, 2019 at 8:34 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Given my experience building tundra exhaust since 2003 I can honestly tell you that a muffler with baffles, or walls inside of it will lose power over stock unless the muffler body is as big, or bigger than stock.
    Look into designs mkre like Borla or magnaflow. Obviously I’m biased to Bamufflers. But there’s a reason that our mufflers are a flow thru design with perforated core.
    When you call Bamufflers you talk to me, the engineer. With experience of building literally thousands of tundra exhust, and experimenting with hundreds of prototypes on tundras, I’m happy to share knowledge first, and sell exhaust second.
    Give a call for more info. 760-877-4234
    ktmsmitty, 417Tundra and Brian0414 like this.
