Exhaust flange hardware - studs or bolts?
Discussion in '2.5 Gen Tundras (2014-2021)' started by AxelsHumanDad, Nov 17, 2019.
  1. Nov 17, 2019 at 6:32 AM
    AxelsHumanDad
    AxelsHumanDad [OP] I am Groot
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    Are these a typical nut and bolt, or a pressed in stud with a bolt head on it? I can't tell from the parts drawings.
    Before I go hacking things apart... :sawzall:
  2. Nov 17, 2019 at 11:54 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Recommend penetrating oil, wrench and impact gun to test the theory, but those fasteners are unlikely to be studs. If they were studs, the head would not be hex head...it would be a smooth pan head style, not pressed in, but welded to the flange. JMO.
  3. Nov 17, 2019 at 12:20 PM
    koditten
    koditten New Member
    Nut and bolt. Can be replaced with SAE 3/8" if you break them(which you will if you don't heat them red hot).
    AxelsHumanDad[OP] likes this.
