Engine suddenly wont turn over.
Discussion in '2.5 Gen Tundras (2014-2021)' started by yampajim, Dec 30, 2019.
  1. Dec 30, 2019 at 5:57 PM
    yampajim
    yampajim [OP] New Member
    2017 Tundra
    I moved my 2017 Tundra about 20 Ft. Came back to move it again and no starter crank. Battery is new. All lights, music, heater come on but starter clicks once. Nothing more. Tried in neutral & in park. No go. Tried jumping from another car & charging for an hour. No go.
    Is there a starter relay or its contacts that can be checked? Baffled
    Rica25 likes this.
  2. Dec 30, 2019 at 6:05 PM
    ssls6
    ssls6 Dr. Awesome
    Richard
    South Park, CO
    2020 TRD Pro CM
    Bakflip, Bedstep, Gulfstate stuff
    Check the tightness of the battery cables first. One click is often a spark jump.
    Rica25 and YardBird like this.
  3. Dec 30, 2019 at 6:05 PM
    Neutron
    Neutron Parrothead
    James
    New Bern, NC
    2020 Tundra Limited CM Smoked Mesquite
    S&B intake, Corsa exhaust, TRD rear sway bar, Spec-D tail lights, wireless center console charger.
    Sounds like Your starter contacts are bad, they are on the solenoid attached to the starter.
    You will need a new starter.
    Crappy spot under the right exhaust manifold
  4. Dec 30, 2019 at 6:07 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    You say your battery is new, could you have ran your old one too long, exhausting your starter and killing it...?
  5. Dec 30, 2019 at 6:39 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Out of warranty?
  6. Dec 30, 2019 at 6:46 PM
    HighonFirewood
    HighonFirewood Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
    Yampa is in your name..is that Yampa Valley Colorado? Just asking because I was up there all weekend, and it was -13 to -15 with the storm (couldn’t even get our snowmobiles working)...got a tundra and a GMC 2500 lifted 8 inches stuck in the snow.
    Jrharvey02 likes this.
  7. Dec 30, 2019 at 7:04 PM
    Sunfish
    Sunfish New Member
    17 4X4 CM Limited
    Try turning the lights on and then hit the key. If your lights go dim the starter is pulling more amps than your battery has. If not it's likely the contacts in the solenoid like stated above. If it sits out all the time make sure the starter is not packed in ice. I've seen them frozen from fording streams where you had to thaw them out to get them to crank
    Randy Morton and Trooper2 like this.
  8. Dec 30, 2019 at 8:12 PM
    Sounds like a loose connection.
    WNY PAT likes this.
  9. Jan 2, 2020 at 6:47 AM
    yampajim
    2017 Tundra
    All connections at battery are good. Even bought a new battery since my existing one showed low power.
  10. Jan 2, 2020 at 6:47 AM
    yampajim
    2017 Tundra
  11. Jan 2, 2020 at 6:52 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    So still just a click? Check starter connection also.
    If still clicking, trying gently tapping the starter with a smallish hammer. It may jar the solenoid loose if condensation built up freezing it and/ or if the solenoid has worn down somewhat.
    Mechanic would test for continuity and current/draw on starter to know what to do next.
    Luck and enjoy those Toyotas. : ^ )))
  12. Jan 2, 2020 at 6:56 AM
    yampajim
    2017 Tundra
  13. Jan 2, 2020 at 6:57 AM
    yampajim
    2017 Tundra
    That would be correct. Does get cold but its not that bad right now. Sorry about your luck in the deep.
  14. Jan 2, 2020 at 6:58 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    It still sounds like the symptoms of a weak battery to me. I believe I would disconnect the battery cables, slow charge the battery, test it with my battery tester.
    https://www.amazon.com/gp/product/B01M0ARG3X/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    Then give it another try before launching off into the possibility of starter issues (big work, big expense, maybe not the problem). These days, brand new batteries can be faulty.
    You don't say what kind of battery you bought. Most batteries these days are an inferior representation of past batteries. Buy yourself a Northstar AGM if you want a real battery.
  15. Jan 2, 2020 at 7:01 AM
    yampajim
    2017 Tundra
    Bought a new battery & cleaned everything. Tried holding the key in start position for 60 secs. Nothing. Tapping on the starter or solenoid seems next to impossible with the manifold & heat shield in the way.
  16. Jan 2, 2020 at 7:13 AM
    JohnLakeman
    To solve this problem, you will have to be open-minded to the idea that your previous efforts may have been ineffective in spite of your best efforts. ;)
    No clicks, no nothing?! No clicks means your battery is probably completely dead. Have you tried a voltmeter to see what voltage indicated?
    Holding the key in start position beyond 1-5 seconds is a bad idea, and accomplishes nothing. If it's going to crank, it will crank (or click) immediately. Holding the key in the start position holds the solenoid contacts closed with current flowing through those contacts longer than intended.
  17. Jan 2, 2020 at 7:18 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Just because you bought a new battery doesn't rule it out. What battery did you put in?
    Double check terminal connection cleanliness and tightness just in case, then hook up a jump starter to it and see if it'll start. If it starts, it's likely the battery. Which means if it's truly new and not just a bad apple, then the alternator might not be charging it enough. Take the battery to an auto parts store and have them fully test it to make sure it's good. If it is, you'll need to test your alternator to see if it's going bad.
    If it doesn't start with the jump starter hooked up, check the relay. If relay is good, make sure all other cables are tight. If they are, it's likely in the starter. You probably have a bad solenoid since you're getting a single click but nothing else, which means you need to replace your starter. Good luck!
  18. Jan 2, 2020 at 7:24 AM
    JohnLakeman
    If a battery is completely discharged, or has a "dead cell" (common failure mode these days), you can't use a jump starter to start the vehicle. There has to be conductivity across the battery, and there has to be enough charge in the battery that it doesn't suck up the entire output of the jump start battery with nothing left for the starter motor.
  19. Jan 2, 2020 at 10:54 AM
    yampajim
    2017 Tundra
    The connections at the new battery are all good & clean. Have not tried to jump it yet with the new battery but I will at lunch today. What relay are you speaking about & where is it located? Thank you
  20. Jan 2, 2020 at 11:25 AM
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    Could I be an issue with the actual key? Have you tried the other key? I thought I read that issue has happened before with gen 3's.
  21. Jan 2, 2020 at 12:44 PM
    bbells
    bbells New Member
    bob
    2016 tundra sr5 5.7l
    Many cars have a switch built in to shut off the engine if the bumper is tapped a certain way. This can also be triggered accidentally other ways. Check for a kill switch. If you don't have one, try a different key.
  22. Jan 2, 2020 at 2:08 PM
    yampajim
    2017 Tundra
    Have to find the other key. Did not hit any bumpers. Anyone know about a relay and where it is located?
  23. Jan 2, 2020 at 3:27 PM
    Jrharvey02
  24. Jan 6, 2020 at 3:59 PM
    yampajim
    2017 Tundra
    So thank you to everyone that tried to help. The starter was "frozen". The mechanic was able to hit it softly with a rod & it turned over. He is perplexed since its such a new truck. He asked if I had gone through deep puddles or water, which I have not. We have recently had -15 deg, but that's normal & we have had this temp already this year with no problems. He is perplexed. He is going to let it get cold again tonight & try it in the morning.
    It it happens again, I am going to spend the $$ on a new starter.
  25. Jan 6, 2020 at 4:28 PM
    FirstGenVol
    East TN
    2002 AC
    If it's a new truck wouldn't that be covered under warranty?
    OR18TRD likes this.
  26. Jan 6, 2020 at 4:55 PM
    Neutron
    Neutron Parrothead
    James
    New Bern, NC
    How many miles on it?
  27. Jan 7, 2020 at 6:39 AM
    yampajim
    2017 Tundra
    The truck is a 2017 & has 32k miles. Its under an extended warranty. Problem is, I live 3 hrs from the nearest Toyota Dealer/Repair. Might be able to use the extended warranty with this mechanic.
  28. Jan 7, 2020 at 6:47 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    It happens...replace the starter and move on.
  29. Jan 7, 2020 at 6:49 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Magnuson Magnum TVS 2650 S/C Sniv's Speed Shop 70mm pulley RCF Throttle Body TRD PRO BBS Wheels TRD Front Sway Bar TRD Rear Sway Bar Fox TRD Pro Shocks Limited mirrors (auto darkening/backup camera/power fold/puddle lights) Limited Grill Mod Automatic Climate Controls Mod Automatic Headlamp Mod Sequoia Transfer Case Mod Sequoia Leather Steering Wheel Mod Sequoia Limited Gage Cluster Mod Sequoia LED Headlamp Upgrade Window Tint 15/70% Fake Manual Transmission Mod 10" BAMufflers Stainless Catback Valhalla Catalytic Converter Shields Engine Block Heater Illuminated Ignition Key Ring Mod Deck Rail System w/cleats Solid Offroad Engine Mounts
    Glenwood Springs (Bighorn Toyota) isn't that far away, unless you have some aversion to them.
  30. Jan 8, 2020 at 3:49 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    That looks like a good tester. I would have bought that if had seen this before purchasing the one I have.
    JohnLakeman[QUOTED] likes this.
