Engine and trans?
Discussion in '3rd Gen Tundras (2022+)' started by navistar82, Oct 7, 2021.
  1. Oct 7, 2021 at 9:07 AM
    navistar82
    navistar82 [OP] New Member
    Is the 3.5 twin turbo and 10 spd transmission used in another Toyota/Lexus vehicle somewhere else in the world or are they a brand new entity for Toyota? Curious if they have any age on the design to be proven reliable like the 5.7 and 6spd.
    Thanks
  2. Oct 7, 2021 at 9:24 AM
    stecky
    stecky Tech Geek
    Dallas, TX
    2021 Nightshade CM MGM
  3. Oct 7, 2021 at 9:25 AM
    Taco-Spike
    Two Trucks
    I think it is used in a Lexus model? Want to LS or LC models off the top of my head
    hANNAbONE likes this.
  4. Oct 7, 2021 at 9:57 AM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    The V35A-FTS has been used in the Lexus LS500 luxury sedan since 2017.
    =JSG= and rocky5100 like this.
  5. Oct 7, 2021 at 11:03 AM
    pnw_rcutv
    pnw_rcutv New Member
    It's been in the Lexus LS500 going on 5yrs now and has been extremely reliable. Also, it's in the LC300 now overseas which has also been recently released. There are some fundamental changes relative to the Lexus variant and they changed part of the oiling system and I'm sure a few other things for truck/SUV duty. The same basic engine applies though. Is it as proven as a 20yr engine, absolutely not. Will it have and has already proven to provide fundamental Toyota reliability, absolutely. The ones that think Toyota doesn't know how to build a turbo engine clearly have never owned or worked on a 1JZ or 2JZ engine which are essentially the holy grail of engines to this day. The V35A is obviously much different but let's cross our fingers the aftermarket takes a hold of these some and opens up the potential.
    Tamadrummer88 and =JSG= like this.
  6. Oct 7, 2021 at 11:17 AM
    navistar82
    Good info on the engine. Is the transmission completely new or is it used elsewhere too? Thanks
  7. Oct 7, 2021 at 1:29 PM
    Coal Dragger
    Kung Fu Dick
    The Lexus LS500 uses a 10 speed automatic transmission too, but I’m not sure if it is closely related to the unit in the Tundra. We can make an educated guess that lessons learned at Aisin Transmission on the Lexus 10 speed which is 5 years into service (or close enough) have been applied to the LC300 and Tundra.
  8. Oct 7, 2021 at 2:33 PM
    906UP
    906UP New Member
    The trans is a new design, one of our customers is a supplier for some of the "hard parts"....gears, carriers, etc. It is built in the US, not imported
    JuicyJ likes this.
  9. Oct 7, 2021 at 3:00 PM
    pnw_rcutv
    I suspect it must be the HD alternative and likely has differences due to the MAX configuration and higher TQ figures.
  10. Oct 7, 2021 at 5:10 PM
    Tundra4Runner
    Tundra4Runner New Member
    2015 4Runner TRD PRO
    I thought I read somewhere that it's the same transmission as the RAM 1500? I could be mistaken though
  11. Oct 7, 2021 at 5:21 PM
    pnw_rcutv
    Definitely not the same ZF8sp from the Rams, these are a all new 10sp similar to the Lexus LS500 which I believe was mentioned to be made by Aisin.
    Cpl_Punishment likes this.
  12. Oct 7, 2021 at 5:21 PM
    Coal Dragger
    Kung Fu Dick
    What does a ZF made 8 speed auto have in common with a 10 speed Aisin?
    Aside from both using automatic transmission fluid.
  13. Oct 7, 2021 at 5:22 PM
    tundra121
    tundra121 New Member
    Hope your mistaken ….after owning 3 rams in a row hopefully Toyota won’t go that low. Sharing anything from Ram would be a mistake!!!
    Cpl_Punishment and TK1979 like this.
  14. Oct 7, 2021 at 7:07 PM
    906UP
    906UP New Member
    Definitely not the same as the ZF/Ram, I worked on that project back in 2012/13. Now the Ford/GM 10 speeds are twins, that one kicked off in early '14. The 10 sp for the Tundra could very well be the Aisin design and be licensed to Toyota, that i dont know for certain but the hard parts are being made in the US... mostly in the KY, TN & WV area
  15. Oct 8, 2021 at 2:43 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Both Ram and Tundra are using Aisin, but different models (of course).
  16. Oct 8, 2021 at 2:45 PM
    FO LO
    FO LO New Member
    17 CM w/ 5.7 and 4.30s
    And titan cummins...
  17. Oct 8, 2021 at 4:26 PM
    pnw_rcutv
    Aisin is only used in the Ram 3500 and it's still a 6sp. The ZF8 is used in just about all other light duty Ram/FCA applications (Hemi, EcoDiesel) and for what it's worth probably one of the most robust and fastest shifting AT available (I've owned two now). Frankly, if the new 10sp Aisin is even close to that then they have a winner. BMW's have the ZF8 shifting so fast most can't tell they aren't dual clutches and you can push copious amounts of power through them.
    sleepybear723 likes this.
  18. Oct 8, 2021 at 4:51 PM
    joesTundra
    joesTundra New Member
    Joe
    2018, Toyota Tundra Limited, TRD 4x4 off road
    You must be new to toyota. They make sure they are the most reliable vehicle made .
  19. Oct 8, 2021 at 4:57 PM
    pnw_rcutv
    Reliable sure, but always the most functional that is debatable? Cause the numerous TSB's and horrible shift characteristics of both the Tacoma and Tundra 6sp aren't anything to write home about. Probably one of the biggest complaints overall. Just saying let's hope the Aisin 10sp is FARRRRRR better than the 6sp that's been around since the 1920's because that thing doesn't know what gear it wants to be in 80% of the time especially if you live in mountainous terrain with elevation changes.
    Gunship Guy, 1UP and sleepybear723 like this.
  20. Oct 8, 2021 at 5:06 PM
    sleepybear723
    sleepybear723 New Member
  21. Oct 8, 2021 at 5:12 PM
    sleepybear723
    I can confirm, the zf8 in my bmw and it’s the best transmission I’ve ever driven. So smooth and always seems to be in the right gear. I rarely know it’s shifting.
  22. Oct 9, 2021 at 4:51 AM
    FO LO
    FO LO New Member
    The tundra 6 speed was geared way to low in first other that that it was fine. The Tacoma's 6 speed is a sloppy reliable mess I guess is the best was to describe it. Toyota chit the bed somethin fierce with the latest gen tacoma transmission and gearing and I'm amazed they have let it go on this long. With all the heat rounds toyota has taken with the taco and tundra transmissiins the new asian direct shift 10at and gearing will be done right. I think.
  23. Oct 9, 2021 at 4:57 AM
    1UP
    1UP Truck Gang
    Surprised your talking so highly of this tech and optimistic. I'd of thought you'd want 3 on the tree. :boink:
  24. Oct 9, 2021 at 5:15 AM
    FO LO
    FO LO New Member
  25. Oct 9, 2021 at 6:29 AM
    Canebrake
    Canebrake New Member
    JP
    West Alabama
    ‘17 SR5 4x4
    I can 3rd this that it’s a very smooth transmission. I had two ZF8s in my stocks M235i have to be rebuilt or repaired under 70,000 miles though. I’ll take a rougher shift if it means better reliability.
    FO LO likes this.
  26. Oct 9, 2021 at 6:38 AM
    FO LO
    FO LO New Member
    My HO cummins aisin 6 speed shifts were like hitting small speed bumps in the low gears but I dont think i could have tore that's trans up if i tried.
  27. Oct 9, 2021 at 6:59 AM
    Canebrake
    JP
    West Alabama
    ‘17 SR5 4x4
    I know it’s a difficult balance automakers have to make between performance and durability. With BMW, when the warranty expires and it hits 50k or so miles, things will go wrong and it will be expensive. Everyone who buys/leases a BMW understands this. In my case it was a two door sports car toy, so it was an acceptable trade off. The straight 6 turbo with the ZF8 transmission is an incredible combination. Fun, but I wouldn’t want to depend on it for work or family.
    That’s not a trade off I want to make in my truck. I don’t know enough about transmissions to say that it won’t work or can’t work reliably in a truck platform. Someone will probably figure it out.
  28. Oct 24, 2021 at 5:48 PM
    joesTundra
    Joe
    go buy your Dodge again
  29. Feb 13, 2023 at 10:01 AM
    mayan
    mayan One pull a day keeps the engine debris away.
    Mayan
    DFW
    2023 SM Tundra Limited
    This new 10 speed sucks it shifts weirdly in the lower gears my opinion higher gears you can't really tell it's shifting but my god does thing like to slip between gears my tach will climb 300-400 rpms between shifts, but sometimes it will shift like a dream I just don't get it anymore and of course when I take it to the dealer they can never replicate what I feel in the truck.
  30. Feb 13, 2023 at 5:10 PM
    FO LO
    FO LO New Member
    in the low gears like when you're in bumper to bumper creeping traffic??
    mayan[QUOTED] likes this.
