Electrical - Wiring a 800W inverter, input needed, please.
Discussion in 'Electrical' started by Arctic Tundra, Nov 6, 2025.
  1. Nov 6, 2025 at 5:02 AM
    Arctic Tundra
    Arctic Tundra [OP] New Member
    Darrin
    2025 Tundra 4x4 SR5 Crewmax 6.5
    Glued rear tailgate lens after I cracked it. SmartCap.
    Opinions please. Planning on installing an inverter (800W). Looking for input on wiring an inverter to my 2025 Tundra. I plan on putting it under the passenger seat. What recommendations do you have for this, please? How long should I get the cables? I am thinking of some 6 gauge. About either 6 or 8 feet to allow for routing. The battery is just on the other side of the firewall. Where should I route the wire through the firewall? Is there a pass through near there that anyone has used?
    Two ways I could do it. One, have a fuse tap hit the contactor relay to power on the inverter when the vehicle starts. However this would mean the inverter is 'always on'. Option 2 below would be to wire in Anderson Powerpole connecters on the wire int to the glove box. Then have the inverter in (or near) the glove box.
    I did check out this post which was very informative - https://www.tundras.com/threads/wir...-the-ignition-solved-writeup-to-follow.25273/
    What I purchased
    Go Power 800 w inverter
    https://amzn.to/4nEV7Kp
    Option 1
    What I plan to purchase...
    Fuse tap
    https://amzn.to/49ypjDE
    Contactor (Trombetta Bear series are the ones I've always used, 100% duty cycle at 225 amps and rated to 600 amp inrush.)
    https://amzn.to/4oXL2cV
    12v 50 Amp Breaker - Bussmann CBC-50HB Circuit Breaker (Type I Heavy Duty Automotive with Stud Terminals and Bracket - 50 A), 1 Pack
    https://amzn.to/4osqDwC
    or
    RED WOLF 50A Amp Circuit Breaker
    https://amzn.to/4pe1lm3
    Option 2
    Alternate install. Quick disconnect using Anderson Connectors
    Anderson Connector 50A, 6AWG - 12AWG Battery Quick Connect 12V-36V Anderson Plug Winch Wiring Kit for Winch, RV, Truck & Marine Applications (2-Pack) -RED
    https://amzn.to/47WuTyt
    Wire/Battery connection - https://www.batterycablesusa.com/
    -Hot wire 2', 6" and 6'
    -Neutral 8'
    connectors to inverter
    battery connection to wire
    wire connection to breaker on hot side
    Breaker to wire on hot
    Contactor wire to inverter (fuse tap)
  2. Nov 6, 2025 at 8:05 AM
    SD Surfer
    Bruce
    So Cal
    Electrical is not my strong suit so I'm of no help, but following with interest.
    What kind of stuff are you looking to run off of it?
  3. Nov 6, 2025 at 6:22 PM
    Arctic Tundra
    Darrin
    Just a Gen 3 Starlink.
  4. Nov 6, 2025 at 9:26 PM
    mtucker
    mtucker New Member
    Escondido CA.
    2008 Double Cab
    Listed in my build thread
    You already bought the inverter, but consider getting a pure sinewave inverter. Your modified sinewave inverter will run most things OK though.
    I'd skip the contactor/relay route and just direct connect your inverter to your battery. If the built-in power switch isn't convenient to get to, then use the remote power switch that go power sells and mount that in a convenient location. https://a.co/d/7nUYGEq
    6AWG is fine.
    Whatever you use for a protection device (breaker or fuse), make sure to mount it as close as reasonably possible to your battery. If you plan on drawing close to 800W off your inverter for more than a few seconds of time, you will want a protection device rated for >50A. 50A*13V = 650W and the inverter isn't 100% efficient so it will waste some power in heat.
    I don't have a 3rd gen so I can't recommend a firewall path.
    Arctic Tundra[OP] likes this.
  5. Nov 15, 2025 at 8:19 AM
    Arctic Tundra
    Darrin
    Thanks Matt. I returned that inverter and purchased a Victron 800W per your recommendation on the Modified Sine Wave. I didnt realise there were options... Appreciate the guidance.
  6. Nov 15, 2025 at 8:20 AM
    Arctic Tundra
    Darrin
    Well, now that I am going to install an 800W inverter I had to alter the breaker. Looking at this one. Does the 48V matter or is it up to 48 and it will work fine with the vehicle 12V system?
    Bussmann CB185-100 100 Amp Type III Circuit Breaker
    https://amzn.to/4i2Ztd7
  7. Nov 15, 2025 at 10:29 AM
    mtucker
    mtucker New Member
    Escondido CA.
    2008 Double Cab
    48V is fine. That is the maximum V rating.
  8. Nov 17, 2025 at 9:57 AM
    SD Surfer
    Bruce
    So Cal
    Good choice. Victron is quality stuff.
