Elec panel question
Discussion in 'Home Improvement' started by Hbjeff, Apr 24, 2022.
  1. Apr 24, 2022 at 6:56 PM
    Hbjeff
    Hbjeff [OP] New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Hi more knowledgeable people
    do i have room for 2 new 220v circuits or just 1? I have 2 spare 110s so if my idiot logic thinks i can move a couple of in use one and free up a “220” if need be? Thanks!
  2. Apr 26, 2022 at 8:38 PM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    Yes, Move the top two "lights" to spares open breakers below then pop a double in the place of the two singles and put a 2 pole in the unused spot at the bottom BUT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! dont do any of that cause that panel looks CRAZY overloaded now, much less adding two more runs. 100 amp main??? Hell I got 200 in house and 200 in the dethatched garage.
  3. Apr 26, 2022 at 8:42 PM
    FrenchToasty
    FrenchToasty The Desert rat, 6 lug enthusiast
    Mo
    The SoAz
    None
    More powa!
    NWPirate and TomC843[QUOTED] like this.
  4. Apr 26, 2022 at 9:10 PM
    NWPirate
    NWPirate Tesla kool-aid connoisseur
    Zach
    WA
    2017 SR5 TRD CM 2004 TRD Snow Goat
    I was going to say the same thing on that 100A panel. You might want to do a load calc anyway.
    What size 2 pole breakers do you need to add?
    Have you looked behind the cover? Those bottom 2 spaces might not have any bus behind it, some covers are universal for multiple panels.
    TomC843[QUOTED] and FrenchToasty like this.
  5. Apr 26, 2022 at 9:12 PM
    FrenchToasty
    Mo
    The SoAz
    None
    Even then, all those double breakers are more than maxed out on that panel, hopefully he never throws parties!
  6. Apr 26, 2022 at 9:18 PM
    Hbjeff
    Huntington Beach
    2010 DC 5.7 2wd
    lol! Im old man Get off my lawn. Kids, turn those damn lights off!
    thanks for the tips guys. Yes there is an unused bus behind the lowest knockouts
  7. Apr 26, 2022 at 9:25 PM
    Ericsopa
    Ericsopa Old man and the sea
    Looks to me like OP has gas dryer and cooking with gas, too. Also no breaker for hot water. So no 220 appliances at all. Not as bad as being made out to be.
    FrenchToasty and NWPirate like this.
  8. Apr 26, 2022 at 9:26 PM
    NWPirate
    Zach
    WA
    Yeah, that's a lot of twin breakers! I wouldn't add any more load, lol.
    TomC843 and FrenchToasty[QUOTED] like this.
  9. Apr 26, 2022 at 9:33 PM
    LML 3500HD
    Pretty sure I would upgrade to a 200A panel.
    I have a 200A panel for inside and a 100A for outside power requirements.
    TomC843 and FrenchToasty like this.
  10. Apr 26, 2022 at 9:34 PM
    Hbjeff
    Huntington Beach
    2010 DC 5.7 2wd
    correct. Everything is gas. Dryer, oven, stove, WH. House is very small. Think an apartment with a yard/driveway
  11. Apr 26, 2022 at 9:35 PM
    NWPirate
    Zach
    WA
    Yeah true, GD, fridge and kitchen recpt probably draw the most.
    Keeping the full load to 80A max, there might be some more wiggle room in that panel.
    What size 2 poles are needed? @Hbjeff
  12. Apr 26, 2022 at 9:36 PM
    Ericsopa
    I should add to my post above that it certainly depend on what is to be on those two 220 circuits. My house has 200 amp panel, and everything on the 220 (well, AC, dryer) are on that panel, plus a 100 amp shutoff to the inside subpanel where the 110 breakers for the house are located.
    NWPirate likes this.
  13. Apr 26, 2022 at 9:38 PM
    Hbjeff
    Huntington Beach
    2010 DC 5.7 2wd
    that im not 100% sure. Spa is gonna be a 50amp
    we don’t have AC, however it may be added in the future. House is only 1300 sf, central ac is a waste imo but the wife wants it. We live 1 mile from the beach. A couple of skylight vents would do the trick if it were my choice
    FrenchToasty likes this.
  14. Apr 26, 2022 at 9:40 PM
    Ericsopa
    Well, with AC added and spa heater, best to upgrade to 200 amps.
  15. Apr 26, 2022 at 9:43 PM
    NWPirate
    Zach
    WA
    Yep, that's a big increase.
    That spa on a 50A breaker will probably draw around 40 amps with everything on.
    TomC843 likes this.
  16. Apr 26, 2022 at 9:44 PM
    Hbjeff
    Huntington Beach
    2010 DC 5.7 2wd
    Good to know. I wouldn’t mind holding off on the ac :p
  17. Apr 26, 2022 at 9:45 PM
    FrenchToasty
    Mo
    The SoAz
    None
    You don’t even want to see my sub panel!!
    bmf4069, TomC843 and NWPirate[QUOTED] like this.
  18. Apr 26, 2022 at 9:47 PM
    NWPirate
    Zach
    WA
  19. Apr 26, 2022 at 9:49 PM
    FrenchToasty
    Mo
    The SoAz
    None
    Mainly it doesn’t have a cover…… it’s in a closet, out of sight………..
    I definitely wouldn’t mind upgrading my panel in the future.
    NWPirate[QUOTED] likes this.
  20. Apr 26, 2022 at 9:50 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    One of these will work wonders if you manage your windows, blinds and know when to turn it on.
    https://www.build.com/quietcool-qc-es-2250/s1328128?uid=3164759&searchId=oBv8dHKpbM
  21. Apr 26, 2022 at 9:51 PM
    FrenchToasty
    Mo
    The SoAz
    None
    TomC843 and NWPirate like this.
  22. Apr 27, 2022 at 4:28 AM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    Upgrade to this
    ColoradoTJ, NWPirate and Hbjeff[OP] like this.
  23. Apr 27, 2022 at 5:29 AM
    NWPirate
    Zach
    WA
    Nice gear.
    Tell me about that open air disconnect on the ceiling, lol. 480V MOD?
  24. Apr 27, 2022 at 5:43 AM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    Hbjeff[QUOTED][OP] likes this.
  25. Apr 27, 2022 at 5:59 AM
    MOTORHEAD
    DAVID
    LOS ANGELES CA
    That is 4160 ac voltage coming from the city power. The other photo is the switchgear that runs out cat power emergency diesel generators. Each one generates 2 million or 2mega watts of power
  26. Apr 27, 2022 at 2:12 PM
    TomC843
    Tom
    Charleston, SC
    Guys that don't live with humidity for a $1000 Alex.
    Hbjeff[QUOTED][OP] and NWPirate like this.
  27. Apr 27, 2022 at 2:13 PM
    alb1k
    Left Coast
    It's good
    Humidoddity? Huh?
    TomC843[QUOTED] likes this.
  28. Apr 28, 2022 at 6:15 AM
    NoRcptn
    NorCal
    2017 Platinum
    Granted it's gotta be totally different since I've never experienced it like it is in the South, but this worked when I lived a few miles form the California beaches. I can't imagine trying to keep anything cool and dry down your way.
    Hbjeff[OP] and TomC843[QUOTED] like this.
  29. Apr 28, 2022 at 7:01 AM
    TomC843
    Tom
    Charleston, SC
    100% percent true. I ment it as a crack on the on my terrible weather were whole house fans and swamp coolers just blow hot sticky air around, no cooling effects when the air is as wet as your sweaty skin. I am 50 years old this September and have never lived without AC.
    Hbjeff[OP] likes this.
  30. Apr 28, 2022 at 7:12 AM
    Hbjeff
    Huntington Beach
    2010 DC 5.7 2wd
    Ive never live in a house with ac
    WVI and TomC843 like this.
