Ease of working on
Discussion in '1st Gen Tundras (2000-2006)' started by Exhumis, Dec 1, 2020.
  1. Dec 1, 2020 at 7:16 AM
    Exhumis
    Exhumis [OP] New Member
    Hi folks, new member with questions.
    How easy are the 1st gen tundras to work on? Seems like there's lots of room for activities under the hood even with the V8. How about under the truck such as trans fluid pan access, etc? I have a suburban and pretty much have to drop the exhaust to drop the trans pan.
    Darkness likes this.
  2. Dec 1, 2020 at 7:29 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Welcome to the forum. I'd consider my mechanical abilities to be fairly skilled and consider my '00 to be toward the 'easy' side of working on things, can't speak for newer versions. Lots of room under the truck and in the engine compartment. Most of the fuel delivery, ECU, and emission systems are fairly simple and OBD2 diagnosable. Suspension is not complicated.
    Ask me again in a year, lol.
    Darkness, Exhumis[OP] and Tundra2 like this.
  3. Dec 1, 2020 at 7:33 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    ... forgot to add... rear wheel bearings are unusually difficult to replace on this model. Requires a special die for the press to get them in and out. Not a great design there.
    Exhumis[OP] likes this.
  4. Dec 1, 2020 at 7:35 AM
    Exhumis
    That's perfect info, exactly what I was looking for. I'm in the same boat as you and will be doing all of my own work except maybe timing belt cuz I heard it's a pita. That's good to know it's fairly easy to work on. Thanks!
    jpink, Darkness and Glock 40[QUOTED] like this.
  5. Dec 1, 2020 at 7:35 AM
    Exhumis
    Well every truck has to have its quirk I guess lol
    Glock 40[QUOTED] likes this.
  6. Dec 1, 2020 at 7:39 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    That's about where I draw the line too.
  7. Dec 1, 2020 at 8:45 AM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    Nailed it right there, OP. (Make your own front-bearing tool for an F350 dually 4X4 and use it just one time before it finds a forever home in the back of your toolbox and comes out only for show-and-tell.)
    This is my first Tundra and I've found it relatively easy to work on so far.
  8. Dec 1, 2020 at 2:57 PM
    Professional Hand Model
    Hand Protectors
    Pretty straight forward truck to work. Lots of engine room. Timing Belt is not as bad as it may seem. Plenty of DIY vids out there, but it does take about 2 days minimum for first timer. It took me 3 days with extras. Could probably do it in 2 days now with experience.
    Wheel bearings most goofy mechanics do not know how to do properly, so plan on investing in the special presses tools and DIY it right the first time in less time.
    Truck is tall enough to crawl under for most work without jacks.
    Parts are available through Toy Dealership Special Programme if yours is participating. Aisin and Denso have their own sites for direct OEM Source when Stealer is too high.
    bassman417 and Stuck in the '00s like this.
  9. Dec 1, 2020 at 3:05 PM
    Kelvin
    Kelvin New Member
    Timing belt is actually pretty easy. Just time consuming. My first timing belt attempt ever was on a 3UZ-FE, only difference between the 2UZ is lower displacement and an e-fan so I don’t have a fan clutch to get out of the way. Things like spark plugs are super easy, 1 hour at most with basic hand tools.
  10. Dec 1, 2020 at 3:19 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    Timing belt is easy if you have done a few in the past and know the general procedure. Just need a special tool for holding the crank pulley and a big torque wrench.
    05-06 years have a sealed tranny so probably don't need to worry about dropping the pan. I just had dealer flush it at 100k.
    Suspension, fuel, sensors and all that have pretty good access. Lots of online how tos as well.
    Welcome from the right side of washington!
    jpink likes this.
  11. Dec 1, 2020 at 3:27 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    05-06 are a little different. Previous years are pretty easy. Here is the downside that no one mentioned- these trucks don't need much work. Not a lot goes wrong in the engine bay.
    Seriously, I have owned mine since the start of 08 and only had two things fail. My brake booster/master cylinder started leaking, it was a bit of a wrestling match but pretty easy. My rear diff broke (because I was duck walking off road like an idiot). That job I paid for. 230k miles, nothing else has gone bad.
    mtntop likes this.
  12. Dec 1, 2020 at 3:35 PM
    Exhumis
    This is all good info. I'm mainly looking at 05-06 due to the increase in hp and the extra gear in the transmission. Is it worth it?
  13. Dec 1, 2020 at 3:41 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    I needed a double cab so didn't have much choice, but glad it has the 5 speed. 4 speeds in general seem a little rough. Especially if you have driven newer 6-8 speed vehicles. I think in general the last year's of a generation are the most solid and more likely to find one in better condition.
  14. Dec 1, 2020 at 4:16 PM
    Exhumis
    Makes sense. I'll be coming from a 94 f250 diesel so anything will ride smoother
  15. Dec 1, 2020 at 4:23 PM
    Stuck in the '00s
    Mikey
    SE Wisconsin
  16. Dec 1, 2020 at 4:28 PM
    Stuck in the '00s
    Mikey
    SE Wisconsin
    Depends on your budget.
    When I found my 04DC I was looking at 06DCs but couldn't afford a couple I liked and wouldn't touch a couple others.
    bassman417 likes this.
  17. Dec 2, 2020 at 7:27 PM
    ajmorenoaz
    ajmorenoaz New Member
    2000 Tundra Sr5
    I’ve done everything myself BUT the timing belt and waterpump the water pump is in the weirdest spot
  18. Dec 3, 2020 at 2:02 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I watched a video of a dude changing out a starter on one of these 4.7 and the entire time I was thinking, why Toyota, why under the intake? He didn't cover the intake openings and I was just waiting for something to fall down in there that he wouldn't see or notice as he was working on getting it removed. Sheesh.
  19. Dec 3, 2020 at 4:51 AM
    Hand Protectors
    Was talking with my Local Stealer Programme parts guy who was formerly a tech and he told me to tape off those intakes when doing the starter. He said all kinds of stuff falls down in there on people that don’t pay attention.
    Kimosabe likes this.
  20. Dec 3, 2020 at 4:55 AM
    artsr2002
    'Yonder
    Absolutely. Anytime you remove the intake, gotta cover or block off those intake ports.
  21. Dec 3, 2020 at 8:13 AM
    Stuck in the '00s
    Mikey
    SE Wisconsin
    I know this to be true.
  22. Dec 3, 2020 at 8:10 PM
    artsr2002
    'Yonder
    This is the way.
  23. Dec 7, 2020 at 7:19 PM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    Just as, or even easier that most stuff on your 94 250...only you won't doing it on the side of the road...at night...far away from the parts store. Just make sure the maintenance has been done, then keep it current.
