Early 2nd gen Transmission Cooler for 2021?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Gilliac, Dec 29, 2024.
  1. Dec 29, 2024 at 7:05 PM
    Gilliac
    Gilliac [OP] New Member
    Gil
    2021 Sequoia
    Rock Auto offers a knockoff of the same cooler Toyota used on the 2008 to 2013 Tundra for $133. Has any one used this on a later model Tundra? If it would fit, it seems like it would save a lot of effort on fabbing mounting brackets for a generic cooler.
    See: More Information for SKP SK918248
  2. Dec 29, 2024 at 7:11 PM
    blenton
    blenton New Member
    Good question. There are a few write ups on installing an aftermarket unit in later model trucks using a generic cooler; the only “hurdle” is fabricating a mount for it, depending on your fab skills. I’d be curious how close this unit would be to bolting right up. All else you would need would be some hose and fittings, maybe a few screws (and thermostat if you want..).
    I’m tempted to order one and see if it fits my sequoia..
  3. Dec 29, 2024 at 7:14 PM
    I don't know what that is but it looks like it's just a cooler itself. There are many other parts needed....lines, fittings, clamps, etc. I would recommend getting the full kit from @Genuine Cooling Systems.
    batman900 likes this.
  4. Dec 29, 2024 at 7:50 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    The expensive part of adding a cooler isn't really the radiator itself. It's the OEM parts. You absolutely need the OEM thermostat. Then if you choose to use the OEM hose connections and hard lines add more cost. From there then it's using aftermarket rubber hoses and your choice of radiator and how you chose to mount it. @Genuine Cooling Systems as mentioned offers everything in a convenient kit with a clean looking mount and a good set of directions and video on YouTube. The radiator you posted will definitely work to cool the fluid, the chances of it mounting right up are slim though.
  5. Dec 30, 2024 at 1:04 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    GSC is for the birds at over $1000 - try this super low cost OEM solution - do not use non-OEM parts for something so so critical.
    Oh and do not bother making a mount - mount it straight up against the AC condensor - that is what is most effective and what what most cooler makers suggest to do - coolers are All about Air Flow - it is Maximized up against the condensor at high and low speeds. Luck all.
    https://www.tundras.com/threads/diy-trans-cooler-for-300.146998/page-2#post-3801435 (see posts 46 / 50 and 51 in particular with the links to other info threads too.
