Dumb question
Discussion in 'Wheels & Tires' started by justfortun, Sep 3, 2020.
  1. Sep 3, 2020 at 6:05 AM
    justfortun
    justfortun [OP] New Member
    James
    Boston
    2016 SR5
    If I replace my wheels, will the lugnuts remain universal?
    This isn't really isnt about my Tundra, but I just purchased 2019 TRD offroad wheels for my mom's 2006 Lexus GX 470. It's in New Hampshire and I'm with the wheels in Massachusetts, so I can't spot check, but going to drive up and put them on this weekend. I'm trying to mitigate all possible snafus.
    a lug is a lug is a lug?
  2. Sep 3, 2020 at 6:10 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Should be the same. If they're aftermarket kind then you will need those smaller acorn type lugs, but for the TRD which is pretty much OEM, they should be good to go with the OEM lugs.
    justfortun[OP] likes this.
  3. Sep 3, 2020 at 6:20 AM
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    what he said ^^ stock lugs usually won't fit with aftermarket wheels but since its an OEM wheel you shouldn't have a problem using stock lugs
