driveline problems?
Discussion in '2nd Gen Tundras (2007-2013)' started by kriptnite, Aug 30, 2017.
  1. Aug 30, 2017 at 6:33 PM
    kriptnite
    kriptnite [OP] New Member
    Aaron
    2007 tundra sr5
    Driveline slack?having a issue when coming to a stop I feel like I have been hit from the rear and when I take back I feel a bump in the rear again,don't notice it when pulling a load?just when you come to a complete stop then take back off any ideas?all joints in driveline seem to be tight it's almost like the driveline is sliding forward and backwards seems to be worse when its hot?:ballchain::ballchain:
  2. Aug 30, 2017 at 6:39 PM
    Rear end?...ring n pinion? How many miles on? Lots of heavy towing?
  3. Aug 30, 2017 at 6:44 PM
    kriptnite
    Aaron
    2007 tundra sr5
    It's got 200k on it not sure about the history of the truck,I was told there was a tsb on this issue and there was some that had complete drivelines replace to fix issue?like to know more info on it before paying out 1k for new driveline and it not fix the problem
  4. Aug 30, 2017 at 7:03 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    kriptnite[OP] likes this.
  5. Aug 30, 2017 at 7:05 PM
    At one time there was a TSB on this exact problem you're describing. I'll see if I can locate it
    Edit: This should be it
    TSB 0148-11
    ColoradoTJ likes this.
  6. Aug 30, 2017 at 7:14 PM
    Link for reference.
    Patriot likes this.
  7. Aug 30, 2017 at 7:31 PM
    kriptnite
    Aaron
    2007 tundra sr5
    Thx that seems to be the problem,if the problem is just the slip part of the shaft needing greased could you not break it down and just grease it but I guess if that's all it is then dealers would just do that vs a new shaft?unless it's more time consuming?
