Driveline grease
Discussion in 'General Tundra Discussion' started by BlueFalconActual, Sep 2, 2016.
  1. Sep 2, 2016 at 9:35 AM
    BlueFalconActual
    BlueFalconActual [OP] Field Day Inspector Extraordinaire
    Kevin
    29 Palms, CA
    Tundra-less
    What kind of grease are y'all using for the driveline? I'm about to go to AutoZone and get some since I know the dealer probably didn't do it and now the nearest dealer to my new house is 80 miles away.
  2. Sep 2, 2016 at 9:39 AM
    LML 3500HD
    I use Mobil 1 full synthetic.
  3. Sep 2, 2016 at 2:07 PM
    15whtrd
    15whtrd Mr. Blonde
    I use the red Lucas sticky stuff.
    TXRailRoadBandit73 likes this.
  4. Apr 30, 2017 at 6:42 AM
    Bannock452
    Bannock452 New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    I know this is a little older thread but I just picked up this Lucas oil stuff from Walmart. NLGI #2 rated. Did all my 5 zerks in the driveline for the first time.
    I had to scrape off the black paint to reveal the zerk hole.
    15whtrd and BlueFalconActual[OP] like this.
  5. Apr 30, 2017 at 7:08 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Man, I forgot I made this thread. I eventually got some Mobil 1 synthetic mainly because it was the only synthetic stuff they had in stock and because ColoradoTJ recommended it. Even though the dealer told me they greased my driveline when they changed the oil, I noticed all the zerks were still covered with black paint. Now I refuse to go to the dealership for maintenance, even if it is free for the first two years.
  6. Apr 30, 2017 at 7:44 AM
    LML 3500HD
    Just to put your mind to ease, we use Mobil 1 grease on all of our multi-million dollar equipment at work. Good stuff with minimal bearing issues for a 24/7 operation.
  7. Apr 30, 2017 at 8:10 AM
    15whtrd
    15whtrd Mr. Blonde
    Exactly what happened to me and that's why I have never been back.
  8. May 1, 2017 at 7:12 AM
    MrWrench
    MrWrench New Member
    2017 White Tundra limited
    Spray on bed liner, Bak mx4
    I couldn't imagine why they wouldn't grease the u-joints while the oil is draining. Truck is up in the air anyways. Would only take a few minutes. One of the easiest ways to tell if a joint is going bad. All the bearing caps gotta purge grease. It's better than a broken u-joint and the damage that can happen from a driveshaft just whipping around
    BlueFalconActual[OP] likes this.
  9. May 1, 2017 at 7:18 AM
    Yeah a kit from Lucas actually i saw it at Home Depot small hand greaser came with couple tubes with red grease
  10. May 1, 2017 at 7:54 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    It's extra effort and he probably figured I would never check. If he wanted to be slick about it, all he would have to do is scrape the paint from the zerks.
  11. May 1, 2017 at 8:04 AM
    MrWrench
    MrWrench New Member
    Scraping the paint from the zerk fitting takes more effort than hmgreqsing them. I do hate scraping the paint from the zerk fittings. I use a small pick the break off the paint and peel the rest off by hand
