Downhill auto downshift
Discussion in '2.5 Gen Tundras (2014-2021)' started by 18tundrasport, Feb 10, 2018.
  1. Feb 10, 2018 at 9:38 PM
    18tundrasport
    18tundrasport [OP] New Member
    PA
    2018 tundra dc sport 4x4 super white
    Lund step bars, afe filter, Trd flow accelerator
    I can' tell how when I'm going downill the trans downshifts automatically. How does it know when to do that or can I do it manually somehow without going into s mode.
  2. Feb 10, 2018 at 9:40 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Were you using cruise control?
  3. Feb 10, 2018 at 9:40 PM
    Based off driving patterns
    Black Wolf likes this.
  4. Feb 10, 2018 at 9:57 PM
    18tundrasport
    PA
    No cruise control
  5. Feb 10, 2018 at 10:01 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    Smart transmission....and saves on wearing out your BRAKES !!!!
  6. Feb 11, 2018 at 5:47 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Hmm? Never noticed that mine downshifts when I coast down a hill (unless your speed decreases to the preset down-shift points), if you coast down a steep, long incline and don't loose speed by doing so it shouldn't shift/
    With cruise control on and set it is a different story, it will downshift while trying to maintain the preset speed. My previous truck (F-150) also had adaptive cruise and actually applied the brakes instead of downshifting, I think that is a better way of doing it because it was more precise, Toyota may get it right with the next Tundra since they all copy ideas from each other.
  7. Feb 11, 2018 at 5:49 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I think with my truck it happens going downhill after I touch the brake.
    If I don't touch the brake I don't think it does it.
    cjscinta and 15whtrd like this.
  8. Feb 11, 2018 at 6:46 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Most Automakers have had to include 'auto- downshift', "going down a steep enough grade"(with brake-tap) into vehicles mainly because todays "drivers" wouldn't dream of touching the shifter except for D-P and R. I'll NEVER understand Tundra owners and their refusal to use the Sequential Shifter in these trucks:notsure:
    15whtrd likes this.
  9. Feb 11, 2018 at 7:24 AM
    18tundrasport
    PA
    I tried it today same hill I tap the brakes 1-4 times and the trans sometimes downshifts. I thought I read somewhere three taps and it kicks in but that didn' work. It seem there is no ryme or reason. :notsure:
  10. Feb 11, 2018 at 7:54 AM
    CMB
    CMB New Member
    Cecil County MD.
    That's because the plastic "brain" can't begin to reason when you need to downshift, into what gear and for how long. THAT'S why the S Mode is so much more efficient. In these days of "Do it for me", Smart Technology, a Manual Shift Mode may require too much effort but I enjoy driving my truck so much more, when I can control what gear I'm in for load, road conditions and speed. Guess I'm a relic from the past!:D
    15whtrd likes this.
  11. Feb 11, 2018 at 11:08 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    @18tundrasport
    Yes, you are! You are also correct about the S mode, just like on any other truck it is a big help especially when towing.
  12. Feb 11, 2018 at 12:15 PM
    CMB
    CMB New Member
    Cecil County MD.
    Yes Sir, we tow 500 miles each way to Canada every year for vacation. By staying in 'S' , I can make a good bit of the drive in Cruise Control. Towing our boat I'll stay mostly in 5 th gear, sometimes dropping down into 4th but after "cresting" the hills, I'll move up into 6th. Helps keep me 'in touch' with the trip and keeps the Torque Converter locked-up. Much less heat build-up, staying out of 'D', so no needless shifting at every bend and rise in the road. I do have a couple advantages though. A 10" BA Catback and a IPT Valve body with Shiftkit helps to keep me totally informed as to what's going on with my truck.
    15whtrd likes this.
  13. Feb 11, 2018 at 12:22 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I didn't know that they make different valve bodies and shift kits for a Tundra. I thought that was only available for more "old school" cars; I have that stuff in my 69 Chevelle.
  14. Feb 11, 2018 at 12:31 PM
    CMB
    CMB New Member
    Cecil County MD.
    John Lombardo out of NJ owns IPT Transmissions, order his upgraded unit and return yours when install is complete. He'll customize it for your uses. I don't regret getting it for a moment. His contact # is 1-866-828-7267.
    15whtrd likes this.
