Door Locks
Discussion in 'General Tundra Discussion' started by MrDMaineTRD, Dec 22, 2020.
  1. Dec 22, 2020 at 4:13 AM
    MrDMaineTRD
    MrDMaineTRD [OP] New Member
    Dana
    2020 TUNDRA TRD
    NONE
    Discovered on my 2020 Tundra LTD TRD OffRoad that if truck is running and I exit vehicle, lock with key (push button start vehicle) that I can not unlock door by any means, key, FOB or touch door handle. Where did I go wrong? I had to use lock out kit to gain entry.
  2. Dec 22, 2020 at 4:23 AM
    rebmo
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    Why lock with a key? Just touch the door handle to lock the truck. It will also unlock using the door handle. Touch the sensor area with the slots on the door handle. Reference the owner manual for instructions. If for some reason you have to lock with a key you may have to manually unlock with a key?
  3. Dec 22, 2020 at 4:37 AM
    MrDMaineTRD
    Dana
    2020 TUNDRA TRD
    NONE
    Tried locking with FOB and touching door handle while running, didn't work. So I locked with key, as I had on previously owned Tacoma. The problem was that it would then not unlock with key.
  4. Dec 22, 2020 at 4:42 AM
    GODZILLA Hail to the King, Baby.
    Wyoming
    2023 Solar Octane TRD Pro TACOMA, 2022 Honda CB500X
    Trying not to mod it
    That was the one thing I didn't care for on my WRX with the push button start. You couldn't lock it and leave it running. I'm sure there's some kind of safety worry that manufacturers are trying to avoid, but it's an irritant.
  5. Dec 22, 2020 at 3:07 PM
    rebmo
    Rural SE Wisconsin
    Maybe they’re trying to prevent people from driving away with the fob outside the vehicle. You could do remote start but that shuts off after 10 min. How did you unlock if it didn’t unlock with the key? Are you running it to keep a pet warm/cool or?
