Door check?
Discussion in '2.5 Gen Tundras (2014-2021)' started by ToyotaTundraMike, May 11, 2020.
  1. May 11, 2020 at 4:50 PM
    ToyotaTundraMike
    ToyotaTundraMike [OP] Not A New Member
    2015 Tundra
    Anyone have to replace one of these little bastards? Assuming that it’s pretty straightforward once you remove door panel?
    if you zoom in you can see the crack in the mid section where the pin is. Finally had enough of it making a loud popping noise every time I open the door....
    @Roman got a link for these? Front driver door...
  2. May 11, 2020 at 5:06 PM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Simple. Couple 10mm nuts that you’ll see if you stick your head in the jamb there. Slides right out (into) the door. Be sure to start the bolt back into the body by hand. Cross threading that one gets ugly.....
  3. May 11, 2020 at 5:22 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I replaced both of them on my 2007... be very careful with the two nuts on the check itself - use a magnetized 10mm if possible.
  4. May 12, 2020 at 5:30 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    I just ordered an OEM one from eBay. Mine busted in a wind storm weeks ago.
  5. May 12, 2020 at 5:45 PM
    ToyotaTundraMike
    2015 Tundra
    Pretty sure that’s what got me as well. Opened door with wind blowing and it snatched it right out of my hand. I’ll have to check out eBay
  6. May 16, 2020 at 7:56 PM
    r1-superstar
    DB
    UTAH
  7. May 16, 2020 at 8:04 PM
    r1-superstar
    DB
    UTAH
    I removed the panel and had my kid hold it up while I worked under it. Removed the speaker and took the door check off. 10 min job
  8. May 16, 2020 at 8:22 PM
    hrv2017
    hrv2017 New Member
    Hector
    2017 Toyota Tundra Double Cab
    I had my passenger break during a SUPER windy day. Talked to my service manager when I took the truck in for service and they replaced it and said it was under warranty. Not too bad for me.
    ToyotaTundraMike[OP] likes this.
  9. May 17, 2020 at 5:43 PM
    r1-superstar
    DB
    UTAH
    That's awesome they did that for you! I have a service appt scheduled in two weeks and asked them to look at it. I figured that since it broke on my own accord, that I fixed it on my own dime.
