Dome Fuse Blowing
Discussion in '1st Gen Tundras (2000-2006)' started by Sain6815, Apr 14, 2019.
  1. Apr 14, 2019 at 7:16 AM
    Sain6815
    Sain6815 [OP] New Member
    2005 Tundra DC Limited 4wd
    hey all,
    I recently had an issue where my audio amplifier (after market) power wire had a broken fuse block. The power cable grounded out to the brake booster and smoke went everywhere and the truck died. (Side note: The aftermarket alarm, amplifiers and head unit were all installed by a previous owner and not installed very well.)
    I turned it off quickly, and disconnected the positive cable.
    Luckily... the truck started right back up. Only now, i keep blowing my dome fuse. The only result i can see is that my dome lights and turn signals don’t work.
    I’ve metered the dome fuse socket and i have continuity to my battery ground. So I’m sure there’s a short.
    Any advice for trouble shooting would be helpful.
    I’m trying to trace the dome wire and check out the path to look for bare wire that is grounding out. I’ve read the electric diagram manual but i can’t find color codes or a path for the dome wire.
  2. Apr 14, 2019 at 7:18 AM
    Sain6815
    I’m assuming the dome circuit received more damage since it’s got constant 12v and turning the ignition off wouldn’t have affected the short.
  3. Apr 14, 2019 at 8:10 AM
    GavinG83
    GavinG83 New Member
    Gavin
    Wilmington, NC
    2000 Tundra SR5
    I would look behind the dash if it is that bad it could even be something behind the radio
  4. Apr 14, 2019 at 8:36 AM
    Sain6815
    Ok thanks. The radio actually still works. So the power there is good. I did pull it yesterday and it looked fine.
