does this look screwed up?
Discussion in 'Suspension' started by thedonn, Jan 17, 2022.
  1. Jan 17, 2022 at 4:21 AM
    thedonn
    thedonn [OP] New Member
    i was outside all day working in my yard and at the end of the night looked at my truck and saw it squatting. it had 8 40lb bags of salt in it by the tailgate and absolutely looked like crap. i removed the bags and drove it around the neighborhood and although it looked much better (pic of truck facing left) it only actually measured 1 inch higher at the bottom of the wheel well. i guess the incline has a lot to do with it because to me the pic with lots of squat looks like the suspension is broken.
    this is a new truck to me with 60k miles. It has just recently had new 6112s put on the front at 1.9+ and new 5160s put on the rear - stock height in rear. i will probably add a cap plus a decent amount of gear when i go on vacation. also occasionally tow a landscape trailer from 3-5k total. mostly i don't want it to squat when im taking the family to the beach and if i can help it I don't want it to ride like a dump truck.
    Please let me know what i need - all new leaf springs, add on springs . i dont know what the stock springs are rated for or what i need for +3-400 lbs...im not opposed to airbags but i want to make sure the truck is matched up to what i do. thank you in advance.
  2. Jan 17, 2022 at 4:32 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    An alt rock band called Powerman 5000 had a hit called "This is what it's like when worlds collide".
    In your instance the song is re-titled "This is what it's like when you load the bed of a leveled truck". Add air springs or ditch the +1.9 on the front axle.
  3. Jan 17, 2022 at 4:34 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    so it's kinda leveled. so when you add weight to the bed, it will make it squat. thats why trucks have the natural rake of them....to accommodate the loads it will take. i'd lean towards add-a-leaf springs to help or the air bags. air bags are faily easy and cheap to install. if you get the on-board air compressors to air them up without stopping at a truck stop or back home, they're nice, but will bump your price up.
    Saltyhero13 likes this.
  4. Jan 17, 2022 at 4:50 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    2021 Tundra DC
    Not sure at this point.
    Never understood the leveled look, but like others said, you’re lifting up the front due to the weight of the components up front.
    When you don’t lift the rear, it’ll result in the squat. That’s the reason for rake.
  5. Jan 17, 2022 at 6:11 AM
    Bradleybb
    Bradleybb New Member
    Georgia
    2021 CM TRD OR
    Transmission cooler TRD REAR SWAY RCI front skid
    Roadmaster active suspension/ HD , added this to mine no harsh ride,
    Had add a leafs and airbags these didn’t do it for me
    MadMaxCanon, 2mchfun and Tundratoofun like this.
  6. Jan 17, 2022 at 6:45 AM
    AJGallo41
    AJGallo41 New Member
    Aj
    MN
    2016 Tundra Crewmax 5.7
    Level Kit 275/70r18 BFG KO2's
    A 2" front level isn't going to actually level your truck, there should still be rake of about an inch. That rear driver wheel well looks suspiciously lower than the other side. I would find a level surface and take measurements of each wheel well to see what it's actually sitting at since the incline isn't helping.
  7. Jan 17, 2022 at 6:55 AM
    thedonn
  8. Jan 17, 2022 at 7:58 AM
    Bradleybb
    Georgia
    2021 CM TRD OR
    have the HD set ,tow a camper 1 to 1.5 squat , no squat with few hundred lbs in bed , 800lbs concrete once
    call the company ask for 10% off they’ll give it ,
    2mchfun likes this.
  9. Jan 17, 2022 at 8:19 AM
    2mchfun
    2mchfun Yeah it'll pull it, just don't expect to stop!
    Roadmaster active susp HD kit, Dobinson's HD 5+2 springs, love it. Very minimal squat with a ton or slightly more in the bed. I use yellow sumo springs for bump stops, so there is no solid bottom out point on my truck.
    Bradleybb likes this.
  10. Jan 17, 2022 at 9:48 AM
    Kanobi13
    Kanobi13 New Member
    Thats alot of sag for 320 lbs
    eick and pvn.beluga like this.
  11. Jan 17, 2022 at 10:12 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Unfortunately IMHO these trucks just don’t look good leveled...at all. The lines on the roof really do amplify the “sagging” look especially on which angle you are looking from. I installed some CB 1 inch shims to my stock Tundra. I love the front look and the way the truck rides after getting the alignment set to CB specs however it always looks like it has a saggy ass…drives me nuts. So much so that I ordered the 1 inch CB shackle to bring me back to factory rake…
    r1-superstar likes this.
  12. Jan 17, 2022 at 6:10 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I have the dobinsons leaf springs, regular duty, which is 330lb extra capacity. I recently towed a stump grinder at the very front of the trailer, and it only squatted about an inch. The factory leaf springs are incredibly weak and sag with minimal load.
    If you wanna see some real squat. Here's my 7.3 with 4260lbs of gravel in the bed today ( about 200lbs over payload, he loaded a little too much) Other than ride quality, you'd never know it was back there, during acceleration or braking. Gotta pick up another load tomorrow.20220117_122305.jpg
    PermaFrostTRD likes this.
  13. Jan 17, 2022 at 6:25 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    Reg Cab Gang
    Has anybody ever measured the wheel wells to see if they are at the same level with the body line front to back? Most trucks arent and those fender measurements are worthless.
    Trucks sag with weight. Leveling kit didnt help. Just drive the damn thing.
  14. Jan 17, 2022 at 6:29 PM
    2mchfun
    Fine truck you got there! Wish I bought a 94 and kept it pristine until now. Sure screwed up!
    Sumo91[QUOTED] likes this.
  15. Jan 17, 2022 at 6:33 PM
    Sumo91
    TN
    Thank you sir. That's her "good side" lol my neighbors tree fell on the bed in 2020. Put a big dent in it. Gonna flat bed it in the future if I can't find a bed. My buddy has an 03 f350 single wheel 4x4 for parts. Gonna use it to convert mine to 4x4. Gonna take my time with it. But it'll be a great project. My tundra is almost complete so I'll be able to spend more time on my 7.3
    2mchfun[QUOTED] likes this.
  16. Jan 17, 2022 at 6:37 PM
    2mchfun
    Check around at companies that swap to service beds. They often have ten or more beds sitting on skids out back brand new. They often get busy doing other things and those just sit until someone asks.
  17. Jan 17, 2022 at 7:05 PM
    Sumo91
    TN
    I've checked all over. These old beds are hard to come by these days in good condition. Most companies that swap service beds have newer trucks.
  18. Jan 17, 2022 at 7:12 PM
    2mchfun
    They are out there, and I will check a few places around here when I get around. Sometimes the trucks were wrecked with the service body so the original beds never were put back on for the trade up. Won't promise, and I don't get around daily much nowadays, but I have many oil patch connections up this way.
  19. Jan 17, 2022 at 7:55 PM
    Sumo91
    TN
    I appreciate it man!
  20. Jan 17, 2022 at 8:19 PM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    Yep I knew that sag well. I fixed the issue with Alcan leaf pack 500# over stock, and CB +1 shackles. Fixed the problem. I did this three years ago and still running strong. CB shackles make a world of diffirence.
  21. Jan 18, 2022 at 3:26 AM
    thedonn
    I have measured the distance from the bottom of the wheels well to the ground - is that what you are referring to?
  22. Jan 18, 2022 at 6:33 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    Holly crap I've never heard of them before either. Not to hijack your thread...but since getting rid of my 4" blocks last year (I have a 7" BDS lift) and going with OME springs + Coachbuilder shackles (3" iir?), I've had a noticeable ~1" to 1 1/2" rear sag. I thought I just maybe had to adjust the shackles. I have a tool chest in bed chock full with tools & recovery stuff...I have no clue how heavy it is but I know it's real heavy. It's likely what's causing the sag.
    These things might fix the sag, and help out with hauling as well. Thanks for posting this link @thedonn !
  23. Jan 18, 2022 at 7:20 AM
    Mr_Ed
    Mr_Ed New Member
    Ed
    2018 Limited 5.7
    None
    Just a few days ago, I put six 40# bags of salt near my tailgate with two 53# propane bottles and got nearly the same look. But that's a ton and half plus right at the tailgate of a half ton truck. I sort of expected it ;)
    I wonder how it would have looked with the weight nearer the cab.
  24. Jan 18, 2022 at 7:21 AM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    SumoSprings work great for sag. They replace the rear bump stops. Easy install.
    RRR1C0 and biebs96 like this.
  25. Jan 19, 2022 at 5:55 AM
    thedonn
  26. Jan 19, 2022 at 6:04 AM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    Stop waiving your impressive payload pictures around here!! Don't you know us Tundy owners suffer from payload envy and are obsessed with payload door jamb sticker porn??
  27. Jan 19, 2022 at 7:21 AM
    Sumo91
    TN
    :rofl: :rofl::rofl:
    Wanna trade door jamb stickers? it'll increase your payload permanently :spy::gossip:
  28. Jan 19, 2022 at 7:32 AM
    2mchfun
    Yeah, I have yellow on my truck. However, prior to upgrading leaf packs the Sumo Springs were right at the frame which limited axle articulation. I bought a second set and cut them down about 2" to be able to swap them easily for off road articulation when desired. Simply throw the hi lift under the hitch, droop it a liitle and swap in minutes. So aside from that, yeah Sumo Springs are a great affordable squat problem solver.
  29. Jan 19, 2022 at 7:38 AM
    i couldn’t care less what the door jamb sticker says. If it puts your truck on the bumpstops, you’re probably hauling too much.
  30. Jan 19, 2022 at 7:40 AM
    2mchfun
    Be careful with shackles, they need to really be matched to the springs and bump stop combination. Simply adding a longer shackle without a taller bump stop allows the applied load to push the spring into negative arch or beyond it's design limitations. Result, flattened springs.
