Does rim width affect tire height?
Discussion in 'Wheels & Tires' started by Shaff777, Aug 26, 2020.
  1. Aug 26, 2020 at 5:47 PM
    Shaff777
    Shaff777 [OP] Rocking the Tundra since 2010
    Justin
    Boise
    2020 cement SR5
    Boss 2.5 Aluma kit. SPC UCA’s Color matched front surround Scs Ray 10 wheels. Cooper AT3 XLT’s 295/70/18
    Hey guys,
    I’m pretty new here, so sorry if this has been addressed elsewhere. I’m looking at mounting a 295/70/18 on my 2020 tundra. New wheels arrived today and are 9 wide ( SCS ray 10’s)
    The listed tire height is 34.3 inches, ( Toyo AT3) but I’m wondering if that is lowered when running a wheel that is 9 wide vs stock 8 tundra wheel.
    I’ll be running a boss aluma lift so it doesn’t really matter for fitmemt- I’m really just wondering for trimming requirements. Thanks so much, I’ve learned so much from this forum already!
  2. Aug 26, 2020 at 6:05 PM
    Zero One Actual
    What lift do you have if any?
  3. Aug 26, 2020 at 6:33 PM
    IIRC tire size is measured on an unloaded tire. The height will be slightly shorter once the tire is mounted and inflated as the sidewalls push out.
    https://m.tirerack.com/tires/tiretech/techpage.jsp?techid=200
    Wynnded and iHacker like this.
  4. Aug 26, 2020 at 7:36 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I thought narrower rims decrease the height a pinch as more side wall is eaten up in the bulge of the tire.
  5. Aug 26, 2020 at 7:42 PM
    Zero One Actual
    Additionally if you look at specs those heights and widths are at 80 PSI in the tire when they do the measurements.
  6. Aug 26, 2020 at 10:19 PM
    Shaff777
    Justin
    Boise
    2020 cement SR5
    Boss 2.5 aluma kit in front / 1.5 shackles in back
  7. Aug 26, 2020 at 10:24 PM
    Shaff777
    Justin
    Boise
    2020 cement SR5
    Tundra234[QUOTED] likes this.
  8. Aug 27, 2020 at 6:13 AM
    Zero One Actual
    Look at the 285/75R18 size also. I have had that size in the Cooper AT3 XLT and the new Toyo AT III. You will get the height you want and it is a little bit narrower so you don’t have to trim or chop anything.
