Does anyone make a rear window screen for our trucks?
Discussion in '2.5 Gen Tundras (2014-2021)' started by IowaGuy, Oct 18, 2021.
  1. Oct 18, 2021 at 6:34 AM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I did a search and couldn't fins anything. It would be cool if there was a screen on the rear window so that I could leave it open and not have flies, bugs and skeeters get in.
    PermaFrostTRD likes this.
  2. Oct 18, 2021 at 7:56 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Following for ideas
    GODZILLA likes this.
  3. Oct 18, 2021 at 7:59 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Following ! :thumbsup:
  4. Oct 18, 2021 at 8:49 AM
    IowaGuy
    In Process
    It would be nice to have one and it might not be to difficult to make but not having it look redneck is the issue. Maybe someone here can figure out how to bend some screen trim molding and make it work.
  5. Oct 18, 2021 at 8:56 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
  6. Oct 18, 2021 at 8:57 AM
    50Shades
    50Shades Sin City Tundras
    J
    West Coast
    2021 Tundra SR5 CrewMax Trail Edition 4x4
    I believe OP wants the whole rear window, not a slider window screen. he has a crewmax
  7. Oct 18, 2021 at 9:32 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Oof, good luck on that one
    50Shades likes this.
  8. Oct 18, 2021 at 9:35 AM
    50Shades
    J
    West Coast
    maybe future Tundras will have a whole back window that has a mesh screen that slides up and down too. hint hint wink wink, Toyota.
  9. Oct 18, 2021 at 9:37 AM
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    I would use house window screen, steel or fiberglass. Rivet, staple or glue Velcro onto it. Attach to the headliner and back of cab with matching Velcro. I did that for a TrailManor trailer, they don't have screens on the entry door. Worked fine, and that was with many cycles, it's a trailer entry door so a lot of cycles. Tundra application would be more permanent.
  10. Oct 18, 2021 at 9:46 AM
    2mchfun
    2mchfun Yeah it'll pull it, just don't expect to stop!
    Get a 3d printer fired up and it could happen.
  11. Oct 18, 2021 at 10:17 AM
    IowaGuy
    In Process
  12. Oct 18, 2021 at 10:21 AM
    IowaGuy
    In Process
    Or this except shaped for our trucks
  13. Apr 9, 2022 at 10:28 PM
    WiddleWadder
    WiddleWadder New Member
    2020 limited CM OR
    cap, drawers, organizers, roof racks
    Might be kind of rigged, but could just get a fiberglass screen section, cut to fit, and sew in these "sew in magnets" every 6-8" or so. Is not going to look good going down the road, but I'm thinking of this more as a camping type setup, at the beach, i.e., when stationary.
    https://www.kjmagnetics.com/products.asp?cat=189
  14. Apr 10, 2022 at 11:05 AM
    eagleguy
    eagleguy New Member
    Has anyone ever put the decorative screening (like tint) on the rear sliding window without it coming off when putting the window? I am looking to put an EAGLE portrait on the rear glass.
  15. Apr 10, 2022 at 12:59 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Here’s my idea for you.
    Make a cardboard template that basically matches the glass. Ideally, the template could be positioned in the open window, and fitted down into the window opening. Slightly raising the rear window would then seat the top of your template into the top window channel so that it seals. Trim until it’s fitted perfectly.
    Get a sheet of ABS plastic. Cut the ABS into the shape of your template. Then, cut inside your template leaving about a 1-2 inch frame. Repeat, so you will have two flexible ABS frames that match the shape of the rear window.
    Get some vinyl window screen. Cut it to a bit oversize compared to the frames. Mount this (stretched fairly taut to avoid sags) to one half of the frame. I would think about using an adhesive that will join vinyl and ABS. Mount the other half of the frame, so you have the screen sandwiched between the 2 frames, and the whole thing is glued together. You should wind up with a fairly solid framed screen that is about a quarter of an inch thick or less, and should slip down into your window channel, so that when you bump the glass up a bit, it’ll press your new frame up into the top channel and provide a snug fit. Trim away any excess screen.
    You won’t be able to drive with anything like this. I think the air pressure would just wreck it.
    Toyotoholic and PermaFrostTRD like this.
  16. Apr 10, 2022 at 6:53 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Go to home depot and get some screen material, cut it to shape. Use the velcro on the outside of the window trim. Probably would want to add some extra adhesive to the velcro on the screen material but this would be a cheap route with minimal cost.
    VisiScreen 36 in. x 84 in. VS1 Series Charcoal Replacement Safety Screen Door Mesh
    https://www.homedepot.com/p/VisiScr...ent-Safety-Screen-Door-Mesh-VS1B3X7/206977416
    SKU# 206977416
    VELCRO Brand 20 ft. x 1-1/2 in. Industrial Strength Tape in Black
    https://www.homedepot.com/p/VELCRO-...trength-Tape-in-Black-VEL-30118-USA/304727482
    SKU# 304727482
  17. Apr 11, 2022 at 5:05 AM
    Coastboater
    Coastboater New Member
    Wheels & Tires, Power Running Boards
  18. Apr 11, 2022 at 5:48 AM
    Dawoofles
    Dawoofles New Member
    Cheyenne, WY
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank)
    Breezeguard makes a screen for the rear side windows.
  19. Apr 11, 2022 at 7:03 AM
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    Without my Crewmax in the driveway anymore to check I would think one could be secured in the rear the way in channel ventvisors go in the sides? Double sided
    Tape on a lip of a frame, slip up into channel, leave window closed for a day?
  20. Apr 11, 2022 at 7:14 AM
    2mchfun
    Just add a lithium 2nd battery under the hood and wire the climate control/vent fan to it. Cabin filter will catch the bugs. A Renogy dc to dc charger could recharge the lithium while driving easily. This gives more than just ventilation, you can run a fridge, lights, and much more with no risk of having a dead starting battery if you design the system correctly.
  21. Apr 12, 2022 at 2:29 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Randy Morton and panicman like this.
