Does anyone have a NuCamp Cirrus 620 camper?
Discussion in 'Towing & Hauling' started by eowade, Feb 14, 2021.
  1. Feb 14, 2021 at 1:03 PM
    eowade
    eowade [OP] Restore The Republic!
    Eric
    2019 Voodoo Blue Tundra TRD Pro
    Smittybuilt 10klb winch, 295/70/18 Recon Grapplers, Remote Start, WeBoost, Mifi, Philosin 13.3 inch rotatable HU, Center Console wireless charger, Nilight hood, ditch, and bumper lights on 8-gang switch
    My wife and I are considering a Cirrus 620 camper for our Tundra for comfortable overlanding. It weighs less that 1500lbs. Does anyone here have experience with one? Thoughts?
    Moses05, jeremyd and MTRock like this.
  2. Feb 14, 2021 at 1:13 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Looks heavy...
    usaf.2012 likes this.
  3. Feb 14, 2021 at 1:27 PM
    vanapagan
    vanapagan New Member
    $38K for the camper? I'd buy a $5K cargo trailer and go wild customizing it for my needs and still have money left over.
  4. Feb 16, 2021 at 8:33 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    1500 pounds and 40k, has to be a better option? I was very intrigued when I first saw it though.
    vanapagan and Cpl_Punishment like this.
  5. Feb 16, 2021 at 9:00 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    That will take all of, and may already exceed your payload. There are few slide in campers that are light enough for 1/2 ton truck use. Huge $ too for what it is. You could get a sick off road capable travel trailer for same or less.
  6. Feb 16, 2021 at 10:14 AM
    eowade
    Eric
    This camper is under 1500lbs and is specifically made for 1/2 ton pickups. Cost in TX is $30-35k
  7. Feb 16, 2021 at 10:16 AM
    eowade
    Eric
    Guys, please keep in mind, the goal is to be self-contained and off road capable.
    jeremyd likes this.
  8. Feb 16, 2021 at 10:16 AM
    frichco228
    Thats cool. But 1500 is over the payload of most Tundras.
  9. Feb 16, 2021 at 10:31 AM
    I_Am_Thee_Walrus
    I_Am_Thee_Walrus New Member
    ‘21 Tundra TRD Off-Road
    I’m not trying to be that guy but.... that 1500lbs is dry without any fuel, water, food, clothes, etc, etc, etc. need one that’s under 1200lbs and you’ll be closer to what you need.
  10. Feb 16, 2021 at 10:32 AM
    Bammer
    Monroe, CT
    Cirrus 620
    Overall Length
    12' 8"
    Overall Width
    8' 2"
    Overall Height
    8' 2"
    Primary Sleep Area
    60" x 76"
    2nd Sleeping Area
    30" x 78"
    Interior Height
    6' 4"
    Fresh Water Tank
    18 gal
    Gray Water Tank
    12 gal
    Black Tank
    5 gal (Cassette)
    Gross Weight (Dry)
    1,500 lbs
    Plus fresh water 8lbs/gallon X 18 Gallon capacity = another 144 pounds, plus gear and supplies. WAY OVER PAYLOAD !
    Made for 1/2 tons, but not a Tundra
  11. Feb 16, 2021 at 10:41 AM
    eowade
    Eric
    This is key info. Even though the Ridge Grapplers E1 rated tires are LT rated, the added stress of higher truck weight during off-road with lower tire pressures combined with much higher center of gravity, may be asking for trouble too.
    I appreciate the input, guys. I tend to err on the side of safety, and heed good advice!
    Catmann1972 and Bammer like this.
  12. Feb 16, 2021 at 11:03 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Please take a picture of the sticker in the driver's door jamb of your truck showing the payload capacity for us.
  13. Feb 16, 2021 at 11:12 AM
    Warreng
    Warreng New Member
    Check out Kimbo campers. Think they are 900#
  14. Feb 16, 2021 at 11:17 AM
    Branden
    Branden New Member
    Branden
    TN
    2020 Black SX
    I like it. I would definitely add the ad the Ac unit.
  15. Feb 16, 2021 at 11:37 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Just checked out the KIMBO, pretty sweet.
    Warreng[QUOTED] likes this.
  16. Feb 16, 2021 at 1:03 PM
    eowade
    Eric
  17. Feb 16, 2021 at 1:22 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Your payload capacity is 1230 lbs. That means the weight of you, all your passengers, all your gear plus the fully loaded camper has to be less than that. So even a camper that weighs 900 pounds is going to put you over unless you have very little gear. (Also, you should probably confirm that payload capacity by weighing the truck to see if the curb weight is actually 5970 lbs or if it's heavier).
    There is no way to safely and legally increase your payload capacity other than making the truck lighter. Tires are just one aspect of it.
    timdske, usaf.2012 and saybng like this.
  18. Feb 16, 2021 at 2:09 PM
    I_Am_Thee_Walrus
  19. Feb 16, 2021 at 2:11 PM
    frichco228
    Also, anything you add to the truck like the winch, heavier bumpers, wheels, tires-that are heavier than what the truck left the factory with need to be deducted from the available payload
    Here is a camper about 500lbs less than the one you listed, also less $- https://www.fwcjh.com/raven-full-size-truck-5-8-be
    saybng and Cpl_Punishment like this.
  20. Feb 16, 2021 at 2:14 PM
    saybng likes this.
  21. Feb 16, 2021 at 2:40 PM
    timsp8
    NY
    Others already mentioned the payload issue. You cant trust manufacturers. There will always be fine print saying you have to confirm your truck can hold it. Lance has 2 that they specifically say fit the tundra, both are 1700 and 1800 lbs dry. Only a 2wd regular cab would have that much payload. And then you wouldn’t be carrying very much gear or water.
  22. Feb 16, 2021 at 8:53 PM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    That thing looks pretty sweet! But at 1500 pounds dry, plus 200 pounds for your water and waste tank, add you and your wife let's say 350, now add camping gear of 100 pounds. That adds up to 2,150 pounds and I am probably being conservative. That puts you 900 pounds over payload. GAWR is probably over also.
    The only 1/2 ton I know that will be able to carry that is stripped down 2wd Ford with their trailer package or whatever they call it. No crew cab 1/2 ton will have the payload to be able to "legally" tote that around.
    timdske, Cpl_Punishment and usaf.2012 like this.
  23. Feb 16, 2021 at 10:10 PM
    usaf.2012
    usaf.2012 New Member
    AK
    2010 Black CM Tundra RW
    10" BAMuffler // Bilstein 5100s all around & front on Mid setting // Toytec shackles // BHLM
    1500 or what their website list at like 1491...same difference.
    Your upgraded tires don't increase your GAWR.
    That looks sick, but still coming in at 1,000 lb dry it puts one over their GVWR.
    If I was going to do the overland thing I would look at putting a rack with a Tepui tent on it. This one, https://tepui.com/products/thule-tepui-ruggedized-autana-3, is spec'd at 192lbs. It also would leave your entire bed available for any other gear you may need while out on the trail and even payload available to use towards upgrades such as a winch or susp mods.
    Cpl_Punishment likes this.
  24. Feb 17, 2021 at 4:42 AM
    eowade
    Eric
    Considering how Toyota clearly hasn't made payload a big priority, it's looking like our best bet to be able to overland, and still have some nice all-weather protection, and glamping (wife likes to be pampered) will be an off-road trailer. I greatly appreciate everyone's contributions to this thread so far.
    Bammer likes this.
  25. Feb 17, 2021 at 5:09 AM
    Bammer
    Monroe, CT
    Keep us posted, always interesting to see what choices people make and why..:thumbsup:
  26. Feb 17, 2021 at 7:58 AM
    knoxville36
    Knoxville, TN
    Yes I agree. There are some pretty cool small trailers out there. Depending on how small you want to go. GEO Pro makes a pretty cool trailer that might for the bill.
    BTW, I feel you on the wife. I am in the market also and wanted something very small. Looks like I might be picking up this trailer this weekend if this tells you anything......7128C9B0-7B04-4747-965A-E833AA1CA97F.jpgA77B9FEB-374E-442E-BC4D-058F14C69DC0.jpg
  27. Feb 17, 2021 at 8:37 AM
    Jmn
    Jmn New Member
    Same approach here. Trying to build a combo with RTT + TT.
    Logic would be that on a long trip (3 weeks+), you pull the TT to some nice accessible campgrounds and book a spot for 2/3 nights. During these 3 nights, you drop the trailer and go camping off road with the truck equipped with the roof top tent + camping gears anytime you want too.
    I did the maths and I will be around +300lbs above payload when the TT is on (quite small TT, around 350lbs dry tongue weight, plenty enough for trips we have in mind).
    I am planning to upgrade with Alcan leafs springs, Coahbuilder shackles and timbrens. I already have E rating tires.
    TT will be pulled few weeks a year while the camping stuff will stick the year around in the truck ..
    Sharing in case it gives you some ideas :)
    Edit :: Oh and I already ordered the transmission cooler kit :)
    Medinasmoke likes this.
  28. Feb 17, 2021 at 9:55 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I'm trying unsuccessfully to convince my wife that a trailer with bunks, a couch and a separate bedroom up front is too big and heavy. So of course she's mad at me for buying the wrong truck.
  29. Feb 26, 2021 at 12:33 AM
    aggie_tundra
    aggie_tundra Always Tired
    2021 2500 Custom
    I was in the same boat. Needless to say the Tundra is gone and the pretty much perfect floorplan travel trailer is sitting in the driveway.
  30. Feb 26, 2021 at 3:30 AM
    timdske
    timdske Another Old Guy
    Fort Worth Texas.
    2019 MGM SR5 4x4 Tundra TSS Offroad
