Do your 33s Rub
Discussion in 'Wheels & Tires' started by B’sTundraTRDPro, Nov 3, 2018.
  1. Nov 3, 2018 at 4:55 PM
    B’sTundraTRDPro
    B’sTundraTRDPro [OP] New Member
    16 Tundra Trd Pro
    Wheels, grill, starter, headlights,tail light, 3rd light, bed cover.
    just installed 33s and they are rubbing even with the front fender guard off. They only rub when fully articulated. How have you solved if you have 33s.
    Mine are 33 12.50 22s
    OR18TRD and TXRailRoadBandit73 like this.
  2. Nov 3, 2018 at 4:58 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Your wheel offset and tire width are what's causing it. Try maxing out your caster
    BuckWallace, equin and OR18TRD like this.
  3. Nov 3, 2018 at 4:59 PM
    Welcome from Texas
    MGM CRÜE
  4. Nov 3, 2018 at 5:02 PM
    B’sTundraTRDPro
    16 Tundra Trd Pro
    Your speaking a different language. Sorry i am a nube, what should i do in laymen’s terms?
    OR18TRD likes this.
  5. Nov 3, 2018 at 5:11 PM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Mine rubbed the skid plate slightly at full lock. I bent the edge up about 90 degrees and solved the issue. Yours may have a better skid than mine though.
  6. Nov 3, 2018 at 5:20 PM
    15whtrd
    15whtrd Mr. Blonde
    2AE46D5B-608B-48A1-8ACA-7A0F3A2DFCBE.jpg 5E193058-69AB-4F6D-ABC8-0600A7F4C008.jpg https://www.tundras.com/threads/official-tundra-wheel-and-tire-setups-pics-and-info.95/
    Most likely due to your wheel offset and the tires being extra wide. You may need to do the front fender liner MOD. Which is heating up and pushing in the liner and or unbolting it drilling a new hole and bolting it back up. Also unknown if you need to do a body mount chop. Castor is in your alignment and that can be a factor in the rub as well.
    aperezsh and OR18TRD like this.
  7. Nov 3, 2018 at 6:38 PM
    B’sTundraTRDPro
    16 Tundra Trd Pro
    Awesome, thanks for the help!
  8. Nov 3, 2018 at 6:44 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Mine do not. 275/60/20 on stock wheels.
  9. Nov 3, 2018 at 7:27 PM
    B’sTundraTRDPro
    16 Tundra Trd Pro
    Thanks man, no i just got the wheels, what is your favorite color, i wanted white but was not available.
    15whtrd and OR18TRD like this.
  10. Nov 3, 2018 at 7:30 PM
    B’sTundraTRDPro
    16 Tundra Trd Pro
    Nice, she’s a beaut. Congrats!
    OR18TRD likes this.
  11. Nov 4, 2018 at 8:23 PM
    blackz151
    blackz151 New Member
    nick
    Mine rubbed 33x12.50x22 but it all depends on the offset of the wheel
