Do you let your engine idle?
Discussion in 'General Tundra Discussion' started by T-Rex266, Feb 25, 2016.
  1. Feb 25, 2016 at 5:35 PM
    T-Rex266 [OP] Elon approved Staff Member
    With it being the winter, there has been times where I let it warm up 15 mins or so before I hop in and go.
    Idling in the winter is not unheard. However, this article says different.
    So, do you idle your engine before hoping in?
  2. Feb 25, 2016 at 5:49 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Magnuson Magnum TVS 2650 S/C Sniv's Speed Shop 70mm pulley RCF Throttle Body TRD PRO BBS Wheels TRD Front Sway Bar TRD Rear Sway Bar Fox TRD Pro Shocks Limited mirrors (auto darkening/backup camera/power fold/puddle lights) Limited Grill Mod Automatic Climate Controls Mod Automatic Headlamp Mod Sequoia Transfer Case Mod Sequoia Leather Steering Wheel Mod Sequoia Limited Gage Cluster Mod Sequoia LED Headlamp Upgrade Window Tint 15/70% Fake Manual Transmission Mod 10" BAMufflers Stainless Catback Valhalla Catalytic Converter Shields Engine Block Heater Illuminated Ignition Key Ring Mod Deck Rail System w/cleats Solid Offroad Engine Mounts
    My remote start is set to shut down after 10 minutes. That hasn't happened yet.
  3. Feb 25, 2016 at 5:51 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    I idle it enough for oil to circulate, about 30 or so seconds, then off to the races.
  4. Feb 25, 2016 at 6:01 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    30-60 seconds in my tundra. No warm up at all in my other cars I don't care so much about.
  5. Feb 25, 2016 at 6:15 PM
    AMRE2ME2
    AMRE2ME2 New Member
    2016 DC 4x4 Limited TRD
    It also depends on where you live and how cold it is outside. Most nights here at 8400ft., it's around 0-20 degrees when I leave. I do let my truck warm up for 5-10 minutes. One thing that article completely left out was getting the oil to warm up before turning that engine up to 4000 rpms. That will do more harm to the cylinder walls then anything else.
  6. Feb 25, 2016 at 6:17 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    I usually let it warm up for about 5 minutes before I pull off. Probably continue doing what I do as I've never had any problems with any of my other vehicles.
  7. Feb 25, 2016 at 6:23 PM
    LML 3500HD
    Two minutes max for me. Cylinder wash is no joke and have seen it coming from the diesel world.
  8. Feb 25, 2016 at 6:28 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    Well...it doesn't get too cold in Florida lol but I let it idle 30-45 seconds or so also.
  9. Feb 25, 2016 at 6:30 PM
    tibadoe
    tibadoe New Member
    Joe
    Gladys
    2014 SR5 DC 4x4
    30 - 60 seconds (depending on the temps) to get the oil flowing through the engine and it's time to go. Idling is also bad for a catalytic converter.
    ColoradoTJ likes this.
  10. Feb 25, 2016 at 6:33 PM
    tibadoe
    tibadoe New Member
    Joe
    Gladys
    2014 SR5 DC 4x4
    I believe they covered that towards the end of the article: "Of course, hopping into your car and gunning it straightaway will put unnecessary strain on your engine. It takes 5 to 15 minutes for your engine to warm up, so take it nice and easy for the first part of your drive."
  11. Feb 25, 2016 at 6:38 PM
    Once the engine is at operating temps, would idling matter then?
    @LOTSOFTOYS
  12. Feb 25, 2016 at 6:50 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    When it's cold out, I let mine idle for 5-10 before I take off. When it's warm, usually two minutes or so.
  13. Feb 25, 2016 at 8:34 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    From reading that I've done years ago, there's no significant harm done as long as your cooling system can handle it. And you're just wasting gasoline. Most figured that turning the vehicle off after one minute was a reasonable amount of time to balance any extra gasoline used on restart. FWIW
  14. Feb 26, 2016 at 3:54 AM
    Hopendreams
    Hopendreams New Member
    glen
    12 TRD Regular cab
    There are many other important considerations. Rear end gear oil, transmission fluid, hydraulic oil in the shocks, rubber characteristics, metal shrinkage and stress on o rings and gaskets in places other than the engine. Give it 15 seconds or so for oil pressure to come up, which is instantaneous anyway, at any temp. Move it to 30 seconds for temps above 0 degrees and up to a minute for everything else. If it should be below -15 degrees....move. lol
  15. Feb 26, 2016 at 4:26 AM
    GQ 66
    GQ 66 (Input clever saying)
    Lake Jackson, TX
    2014 CM Limited
    Tinted Tails, hard wired passport escort, Magnaflow 50 series,
    I let mine idle long enough for the fan to turn off and then I'm off.
  16. Feb 26, 2016 at 5:21 AM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    I've seen that article before, just someone trying to stir up discussion and sell advertising on their website, driving easy and idling keep your rpms low and are practically the same thing. For every article like that there are probably 10 that say the opposite.
  17. Feb 26, 2016 at 5:22 AM
    Nor7
    I'll be getting a remote start soon just so I CAN idle it before I get in (and so I can run the A/C to cool down the truck in this Texas heat).
  18. Feb 26, 2016 at 6:06 AM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    I let my vehicle idle for a 20 30 second or so. Like someone said before, let the oil make it all the wah to the heads before being mean to it:)
  19. Feb 26, 2016 at 6:20 AM
    chphilo
    chphilo Tundra addict
    Western PA
    His claim is that idling does not warm up the engine quickly. I personally don't see any difference in the rate of temperature rise between idling and driving. (disclaimer: I did not measure it with stop watch. It's according to my butt-o-meter, haha.)
    Nor7 likes this.
  20. Feb 26, 2016 at 7:41 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    If there isn't snow to deal with, and I'm not in some kind of hurry, this is what I do as well. That fan is loud...
    GQ 66[QUOTED] likes this.
  21. Feb 26, 2016 at 8:32 AM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    Yes, usually let her idle for 1 to 5 mins in the winter time. 30 seconds in warm weather. Only when its super cold (for VA) do I let her idle for longer then 5 mins but that's more for the engine then my comfort. I'm more concerned with getting the oil pumping threw my engine and up the my cams and rockers than anything.
  22. Feb 26, 2016 at 9:33 AM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    Remember, the 5.7L has 32 valves and 4 cams way up high. Winter time in north mid west US, up thru Canada, and AK can be pretty brutal. Daily. Well below zero. You definitely want that engine warmed up for a few. Not to mention the heater/defrost. [​IMG]
  23. Feb 26, 2016 at 10:19 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    This is where i am at as well on the coldest of winter mornings.
  24. Feb 26, 2016 at 11:30 AM
    TruckLife900
    TruckLife900 I'd rather B hunting
    2013 White SR5
    Same here ^^^^^^^^^^^^^^^^^^^^^^
    "So unless you're rolling in a 1970s Chevelle" I wish... I do warm up my carb motorcycle :p
    FirstGenTundra likes this.
  25. Feb 26, 2016 at 12:42 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    I usually wait until the RPMs drop down to idle after I turn it on and it's been off for a while.
  26. Feb 26, 2016 at 1:13 PM
    applesquirel
    applesquirel New Member
    james
    Clarksville Tn
    2012 platinum tundra!!!
    none yet
    Coming from the subaru world where i would have to let it idle for at least 5 min before it would start to act right I think i will continue to at least let it warm up for 2. I like to know that the oil is doing its job. Thats my 2 cents lol
  27. Feb 26, 2016 at 2:35 PM
    AMRE2ME2
    AMRE2ME2 New Member
    Some of these posts would make more sense if we knew where you lived. Put your state in your profile.
  28. Feb 27, 2016 at 6:58 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    At least 30 seconds as I get buckled in but more if I've gotta clear the windows, with 0 - 20 synthetic oil not worried too much because it gets flowing right away
  29. Feb 27, 2016 at 8:58 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    My motorbike is EFI and the manufacturer says not to "warm it up", my '70 carbed El Camino will drive off with about the same warm up as my Tundra.:D
  30. Feb 27, 2016 at 9:16 PM
    DBL TAP
    DBL TAP Light 'em up
    USA
    I run my just long enough to bring the idle down from 1100 to 800. Not a bad idea to run an oil analysis occasionally if you're concerned about cylinder wash and excessive wear. I use Blackstone Labs.
    Wynnded likes this.
