Do NOT plug space heaters into power strips
Discussion in 'Off-Topic Discussion' started by T-Rex266, Nov 29, 2017.
  1. Nov 29, 2017 at 6:01 PM
    T-Rex266 [OP] Fuck Cancer Staff Member
    MotoTundra and SouthBoundSteve like this.
  2. Nov 29, 2017 at 6:08 PM
    jfrd30
    jfrd30 Lead, Follow, or Get the Hell Out of My Way
    2013 TRD Tundra
    Yeah......Bad idea! Don't do it
    SouthBoundSteve likes this.
  3. Nov 29, 2017 at 6:31 PM
    Post all you want!
    4x4_Angel and SouthBoundSteve like this.
  4. Nov 29, 2017 at 6:36 PM
    FlashCulprit
    FlashCulprit ColoradoTJ's whipping boy/Gino's illegitimate son.
    Joe
    Salt Lake City, UT
    2010 Super White SR5 TRD 5.7 4x4
    What about using a space heater on a non GFCI receptacle, but using an adapter? Am I defying death right now? :goingcrazy:
  5. Nov 29, 2017 at 6:40 PM
    Damn. Just goes to show you how sometimg so small can start something so big.
    Any info on his background?
    FlashCulprit likes this.
  6. Nov 29, 2017 at 6:43 PM
  7. Nov 29, 2017 at 6:58 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Three years ago my neighbors house directly across the street caught fire and was a total loss. Her high school freshman son was away at a friends house but left a space heater plugged into a power strip and that was the cause of the fire. His room was a dump and he is a teenage know it all dropout with an attitude. This was not their first house fire either... They say about 11 years ago at another house it caught fire too.
    I watched the fire happen live from small to when it blew up into a rage of fire as soon as the firefighters cut a hole in the roof. Smallish house and a lot could have maybe..maybe been saved if they had not caused the fire to explode by cutting the roof open. Never understood why they feed the fire like that on smaller houses.
  8. Nov 30, 2017 at 5:03 AM
    TundraTss
    TundraTss The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    Darwinism.
  9. Nov 30, 2017 at 5:13 AM
    Daze823
    Daze823 New Member
    Donnie
    Fayetteville, NC
    2015 White TRD Pro
    Toyo all weather mats
    Surge protectors are a big focus of Safety Programs, recommendation is not to plug anything in them that heats, cools, or has a motor (except a computer with a cooling fan). Also, don't plug other surge protectors into surge protectors.
  10. Nov 30, 2017 at 5:15 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    well......that aint a good idea.
  11. Nov 30, 2017 at 5:17 AM
    Tomcat
    Tomcat Ever see a motorcycle outside a shrinks office?
    2010 SR5 4X4 5.7 20" wheels Metallic Gray
    Bakflip
    Wow....I thougot power strips were meant to prevent fires. When they get overloaded they cut the power. Also the breakers in the circuit panel are supposed to cut power When overloaded. So exactly what is the benefit of a power strip other than additional plugs.
  12. Nov 30, 2017 at 5:22 AM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    how many fires are started by space heaters plugged into wall outlets?
    Tomcat likes this.
  13. Nov 30, 2017 at 5:29 AM
    Tomcat
    Bakflip
    The guy in the video says this power strip cut off but you can see the burn marks. Yep that is exactly what they are designed to do.
  14. Nov 30, 2017 at 5:38 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    a lot less than fires started by heaters plugged into power strips. ;);););)
  15. Nov 30, 2017 at 6:31 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    It's also a good idea to replace old extension cords once in a while. This cord was about 25 years old. I woke up to a loud banging noise and lights flashing in the utility room, both were caused by the arcing that melted the connection. There was a small fire, but fortunately nothing was close by that was easily flammable. Several cords went into the trash after this.
    T-Rex266[OP] and gosolo like this.
  16. Nov 30, 2017 at 7:38 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Daze823[QUOTED] likes this.
  17. Nov 30, 2017 at 8:57 AM
    Daze823
    Daze823 New Member
    Donnie
    Fayetteville, NC
    2015 White TRD Pro
    I'm no expert, but I believe surge protectors are designed to prevent power spikes from getting to electrical devices (I.e. Lightning strikes), I don't believe they are designed to limit a constant power flow.
  18. Nov 30, 2017 at 9:08 AM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    Looks like the datacenter for the 7-11 group I used to work for...
  19. Nov 30, 2017 at 10:49 AM
    chadjamesr
    chadjamesr New Member
    Chad
    Atlanta
    2016 Tundra Platinum 4x4 Crew Cab
    Fox 2.5 w/ DSC Remotes F&R Coach Builder +3 Shackles RW Wheels w/285/75/17 Terra Grappler G2 Interior and exterior changed to LED Retrofit headlights with DS2 4.0 Morimoto LED fog lights Morimoto 40" LED bar in front bumper Retrax PRO Tonneau cover RCI front skid plate Crystalline tint on all windows and windshield P&P Rock sliders and full skip plates
    I'm actually in the portable space heater business as I work with a factory in China that produces product for Wal-Mart, Home Depot, Lowes, Amazon, etc. Although typically most space heaters don't cause any problems, it is just a matter of odds until one fails. Using them on an extension cord or power strip is just asking for problems. In my professional opinion, stick with non-oscillating models as the oscillating system increases the chance of a failure. Also stay with the ceramic (PTC) type heater or the oil filled heaters. Neither of these get hot enough to start a fire, although the cords will still catch fire if used with extension cords or power strips. Never leave them on unattended either. Granted insurance my pay for everything if you have a fire, but you can't replace everything with any amount of money.
    HBdirtbag and T-Rex266[OP] like this.
  20. Dec 1, 2017 at 11:53 AM
    jfrd30
    2013 TRD Tundra
    What War Eagle said!!!
