Do not buy a cast filter wrench
Discussion in '2.5 Gen Tundras (2014-2021)' started by Stumpjumper, Jan 14, 2019.
  1. Jan 14, 2019 at 10:19 AM
    Stumpjumper
    Stumpjumper [OP] Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I had the dealer do my first 5 oil changes so I don't know how tight the filter cap is from the factory. I have run into some that are real tight from the factory but never after a dealer service a vehicle. Did my first oil change on the Tundra on Sunday. I was all prepared with filters, Fumoto valve, filter wrench and metal cap. Not knowing any better I bought a cast filter wrench. The oil filter cover was on so tight that I broke the cast one and the filter cover. Luckily Advance had a better one. When I tried again I had a 2' cheater bar and my neighbor had to hold my legs. I guess the dealer was afraid that the cover would vibrate off. It certainly was not going to do that with 100+ ftlbs of torque.
  2. Jan 14, 2019 at 10:49 AM
    MajorC
    MajorC New Member
    Major
    2007 Tundra SR5
    The wrench has nothing to do with it. The problem is your dealer. Oil changes are done at dealerships in the "Oil Bay Department." In other words, the guy who just got promoted from washing and vacuuming vehicles. Makes $1.00 over minimum wage. Oil Filter housing should be torqued by hand to 18.5 lbs. If you don't have a torque wrench that means tighten by hand with no tool as hard as you can till you fart. Most likely your housing was torqued down by a pneumatic air wrench which was set to NASCAR lug nut standards when Oil Change Boy gave you a free tire rotation with your speedy oil change. My daughter recently had her oil changed on her Tacoma at the dealership and I found a red rag and a plastic drink bottle with the drain plug housing cap jammed in behind the manifold. I bet your oil drain plug (9.5lbs torque) is driven home, too. You can actually deform you oil pan by over tightening the nut. Hope this helps.
  3. Jan 14, 2019 at 10:53 AM
    Tundrablue
    Dave
    Ohio
  4. Jan 14, 2019 at 11:00 AM
    Pineneedle789
    Pineneedle789 New Member
    I keep hearing oil filter being over torqued horror story.
    I just did engine oil and diff fluid change on my 2019 1k miles (lol).
    But, I have been maintaining my previous tacoma for over 10 yrs.
    This is just my experience. It may not be true but here it goes.
    When changing oil, drive vehicle for 30 mins or so before attempting. Oil filter has that rubber seal. During hot and cold cycle when using for 6 month plus, them rubber seals kinda welds into housing.
    If you heat it up good by driving 30 mins before wrenching filter, it comes out alot easier than when you try cold.
    Just my experience again.
    MajorC, CMB and Law323 like this.
  5. Jan 14, 2019 at 11:14 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Same. That’s why I refuse to let other people change my oil. I to had to use a cheater. 18ft lbs, 9 on the center cap.
    MajorC and Tundrablue like this.
  6. Jan 14, 2019 at 11:16 AM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    "...hard as you can till you fart."
    :rofl::D
  7. Jan 14, 2019 at 12:06 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Ahh, yes. The good ol' tighten-it-'til-you-fart torque method. Been using it for years now with 100% reliability.
  8. Jan 14, 2019 at 12:10 PM
    Ronin
    Ronin Hoof Hearted
    Bill
    2019 CrewMax 5.7 Tanker
    All fun and games til you SHART :fingerscrossed:
    MajorC, Darkness, Vr0ck and 7 others like this.
  9. Jan 14, 2019 at 12:16 PM
    Philogynist
    Philogynist New Member
    NY
    The MotivX oil filter wrench/socket tool appears to be a cast unit. Can anyone confirm?
  10. Jan 14, 2019 at 12:34 PM
    Tundrablue
    Dave
    Ohio
  11. Jan 14, 2019 at 12:36 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    2026 Lunar Rock CM TRD OR
    My MotivX appears to be cast but I've had no problems with it.
  12. Jan 14, 2019 at 12:46 PM
    justfortun
    justfortun New Member
    James
    Boston
    2016 SR5
  13. Jan 14, 2019 at 1:25 PM
    15whtrd
    15whtrd Mr. Blonde
    Keep that cast filter wrench and put a big hose clamp around it. These were my first thoughts. In all seriousness I don’t think many will have a problem with their cast wrench, it’s more because the dealer tightened the crap out of it. If it was installed properly the tool should not break.
  14. Jan 14, 2019 at 4:46 PM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    Didn't have a problem with the wrench I used (borrowed a friend's), but man was that cap on tight.
  15. Jan 14, 2019 at 5:19 PM
    Professional Hand Model
    Hand Protectors
    Also, one should lube the rubber ring on the filter with fresh oil before screwing it on by hand. This helps when it needs to be removed.
    MajorC, 15whtrd, Ronin and 1 other person like this.
  16. Jan 14, 2019 at 5:20 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Reminds me of when I had to have my wife's Camry towed to the dealer after I tried everything I could to get the oil filter housing off. I didn't break my tool but I snapped both the tabs off that the tool goes around. In return that cracked the housing so I couldn't even fill up the car with oil and drive it there... After fighting it long enough I gave in. Couldn't believe how tight it was.
    Guess who was the last one to change the oil... That's right, the dealer. They got an ear full but it didn't really help my case. That was an expensive oil change and my last at the dealer.
    MajorC and BTBAKER like this.
  17. Jan 14, 2019 at 5:29 PM
    tacomawv
    tacomawv New Member
    Richard
    It took every thing I had to get the cap off on my wife's Lexus. 36 inch breaker bar. 4.6L The same as my truck. The wrench is still on the cap. I can't get it off. I had to buy a new one to change the oil in my truck.
    BTBAKER and mdavis like this.
  18. Jan 14, 2019 at 6:04 PM
    Stig
    Stig New Member
    The lesson here is never let the dealer change your oil unless you will never do it yourself. I wonder if the dealer is even changing filters if it's that tight.
  19. Jan 14, 2019 at 6:12 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Scud, Philogynist and Ronin like this.
  20. Jan 14, 2019 at 6:21 PM
    Ronin
    Ronin Hoof Hearted
    Bill
    First time ever to agree with a “Stig” post
    BTBAKER and 15whtrd like this.
  21. Jan 14, 2019 at 6:27 PM
    15whtrd
    15whtrd Mr. Blonde
    Ronin[QUOTED] likes this.
  22. Jan 14, 2019 at 6:29 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    The relationship between the oil filter and the fart filter is fascinating.
    Trooper2, MajorC[QUOTED] and 15whtrd like this.
  23. Jan 14, 2019 at 6:29 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    The oil drain plug was fine. I put a Fumoto on so no more worries there. One thing I recommend (especially with cheaper wrench) is use a socket in it instead of using just the rachet end in hole. Not sure if I want to spend money for a skid plate with access panel. I am thinking about just cutting access hole in OEM but figuring out where to cut might be a problem.
    MajorC and classiccat like this.
  24. Jan 14, 2019 at 6:58 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Yea, I played around with that thought myself. Then I called a metal fab place who wanted a minimum of 175 to cut the hole and make a cover. Then I came to my senses and got in on the RCI group buy. Now I have a sweet skid and my oil changes will be really simple!
  25. Jan 15, 2019 at 3:13 AM
    Stig
    Stig New Member
    No worries. I usually just troll here. The other forum has much better members with less pointless banter ;)
    Edit. Actually, that goes for all other forums I've been on
    plumber802 likes this.
  26. Jan 15, 2019 at 3:38 AM
    Berettafan
    Berettafan New Member
    2017 CM
    I bought the pro skid just to make oil changes easier on me. No plans to let dealer do my oil changes.
    That filter cap can be a bit tight though.
  27. Jan 15, 2019 at 4:05 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Can't do that anymore, too old to EVER trust farts again!:D
  28. Jan 15, 2019 at 6:20 AM
    waynescaggs
    waynescaggs No more of that .
    Wayne
    Idaho
    2019 tundra Crewmax Limited
  29. Jan 15, 2019 at 6:40 AM
    WrigglingWilly
    WrigglingWilly Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
    The shard is 32 pounds, you went too far. You just want a duck-like quack for 18 pounds.
    MajorC and Ronin[QUOTED] like this.
  30. Jan 15, 2019 at 12:26 PM
    Ronin
    Ronin Hoof Hearted
    Bill
    Actually of the many helpful posts I've read here this may be the Best! However I eat a lot of tacos so I might be prone to under-torqueing at 8 lbs. or less :taco:
    WrigglingWilly, Trooper2 and 15whtrd like this.
