Do I need to add leaf springs
Discussion in 'Suspension' started by BubbaTun1794, Oct 13, 2021.
  1. Oct 13, 2021 at 11:13 AM
    BubbaTun1794
    BubbaTun1794 [OP] New Member
    '16 Tundra 1794
    I just picked up the Bilstein 8112/8100's with SBC UCA's
    I did not buy leaf springs.
    I want to lift the truck around 2.5"-3".
    The shop that is going to install the shocks are recommending I add leaf springs for several reasons.
    1- supposedly cant raise the rear unless I have additional leafs, so only front would be raised to match factory rear.
    2- much better if you want to add weight to back such as bumper, roof tent set up etc...
    3- enhances ride quality
    Does this make sense. Any advice greatly appreciated.
  2. Oct 13, 2021 at 12:04 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    You can install rear leafs that will lift- icon, OME and others out there, you can install add a leaf, you can looking into roadmaster active suspension (1 to 1.5 lift) and there are several leaf spring shackles that will lift the rear an inch to two inches. So there are several options available.
  3. Oct 13, 2021 at 2:56 PM
    BubbaTun1794
    '16 Tundra 1794
    Thanks for the advice.
    I think I am going to go with the Icon RXT.
    Now my dilemma is I am being told two different opinions on how to lift the rear to get it to 2 3/4 inch lift.
    The person who sold me the shocks recommended adding adjustable shackles. Set at 1 inch and have the shocks set at 1 3/4 to get to the 2 3/4. Said the shock works better if it isnt extended to the 2 3/4 right out of the box, it will perform at all times closer to the bypass level, if that makes sense.
    My mechanic is saying that doesnt make sense and to forgo shackles and just do the 2 3/4 lift from the shock.
  4. Oct 14, 2021 at 9:17 AM
    frichco228
    What your mechanic is saying is to install the lifted coilovers in front and leave the rear of the truck stock height. That will leave you a little nose high if you keep the front coilovers at the higher preset height. To level the truck, you would want to add an inch or so lift to the rear and as I said before shackles or add a leaf will do that for you.
    excelsuspension likes this.
  5. Oct 14, 2021 at 2:26 PM
    BubbaTun1794
    '16 Tundra 1794
    I am looking for a level stance
  6. Oct 14, 2021 at 2:30 PM
    BubbaTun1794
    '16 Tundra 1794
    The plan is to add a rooftop tent for overlanding/camping. My mechanic suggested I add the leaf springs now vs. waiting to do it down the road. My goal is to get the tent in aroung 4-6 months.
  7. Oct 14, 2021 at 2:34 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    So the OEM rake is approx 1" so let's say you lift the front 2.5". In order to level the truck you are going to want to lift the rear approx 1.5". There's a few ways to complete this.
    New leaf pack - Icon RXT is the one that I point most customers too for cost to performance ratio. Was discussed above by @excelsuspension .
    Lift Shackle - Coachbuilder makes the most common one for around here. You'd probably be looking for the +2" shackle which gives about 1.25" of actual lift. You could go with a +3" shackle as well for a bit more lift.
    Blocks - Please. No.
    Since I saw that you are adding a tent and rack to the back I strongly recommend getting a new leaf pack.
    Tundra18overland and Saltyhero13 like this.
  8. Oct 26, 2021 at 1:37 PM
    BubbaTun1794
    '16 Tundra 1794
    Another question and thanks for the advice so far.
    The place that is going to install for me is recommending I do a diff drop. They quoted me $120 in labor. This is in addition to the labor to add the shocks, do the lift and and the leaf pack. Does this make sense??
