Do 2nd gen bumpers fit on 3rd gen?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Schatziontheroad, Jan 23, 2020.
  1. Jan 23, 2020 at 4:55 PM
    Schatziontheroad
    Schatziontheroad [OP] New Member
    Mack
    2014 tundra double cab 5.7 4wd sr5
    Steel wheels, tow mirrors, lots of fluid film!
    Hey guys, first post.
    Avid Toyota fan here. Big fan of functionality.
    I’ve seen a few used ranch hand style front bumpers from 2nd gen/2007-2013 tundras.... wondering if they would fit my 2014?
    Particularly looking at a “frontier” bumper.
    thanks!
  2. Jan 24, 2020 at 3:43 AM
    Schatziontheroad
    Mack
  3. Jan 24, 2020 at 4:56 AM
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    Some do, some do not... Depends on the shape of it. This 2014+ fit on my 2010 with minimal modification.
    vhstejskal likes this.
  4. Feb 9, 2020 at 4:49 PM
    Schatziontheroad
    Mack
    What does "minimal modification" entail?
  5. Feb 9, 2020 at 5:32 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    It depends on the bumper, but the mounting points will match up.
    If you are getting a ranch hand that was made for a second gen and it looks like the one below, yes it will fit. See the plastic valance above the bumper? That's where the bottom of your 3rd gen grill is.
    687474703a2f2f62756d706572737570657273746f72652e636f6d2f696d616765732f4d39323535393931342e706e67.jpg
    Now, if you find a second gen bumper like the one below, it won't fit your third gen. This is because the plastic valance needs to be removed on a second gen in order for the bumper to fit. There is nothing to remove on your third gen to make it fit.
    Hope that helps.
  6. Feb 11, 2020 at 8:20 AM
    1BadTundra
    Clinton
    Too Much to List
    For me, It was using the "spacer mod" to bring the bumper out far enough that it wasnt tucked under the upper valence above it. Then some "massaging" to get it perfect.
  7. Feb 11, 2020 at 8:28 AM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    How do you feel about using an angle grinder to cut/add clearance?
  8. Jul 9, 2020 at 8:04 PM
    I'm looking at getting the same bumper that 1BadTundra has on his in the post above.
  9. Feb 8, 2021 at 3:25 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Opening a reverse can of worms here.
    Does the 3rd gen rear bumpers fit the rear of 2nd gens , im mainly looking at tire carrier options I only see them 3rd gen in a style I like.
  10. Feb 8, 2021 at 3:27 PM
    I have not seen any that fit. The body is different and some of the mounting points are different as well I believe.
