DLR and Turn mod
Discussion in '2nd Gen Tundras (2007-2013)' started by fairclothr1, Aug 20, 2018.
  1. Aug 20, 2018 at 10:02 AM
    fairclothr1
    fairclothr1 [OP] Here and There Member
    Ryan
    2009 Sand Mica Tundra TRD
    Plasti Dipped grill and badges. Shorty antenna.
    So, I have been wanting to put something under my headlights on that panel that just seems bland. Found some DLR/Turn lights that look like they will work well, link below. But, I need some help. Does anyone know of a way to have the DLR on in white, then it turn off when the turn signal is on and have the amber blink with the signal? I realized this may not work after buying it b/c the DLR is integrated in the signal. Any help will be great!
    https://www.amazon.com/dp/B0732SZXCN
    Cheers!
  2. Aug 20, 2018 at 10:10 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    There should be three wires off of these leds switchbacks. Yellow wire for should connect to the turn signal power wire. White wire should connect to your drl or headlight power wire. Black wire is the ground wire. That’s should be about all you have to do for wiring.
  3. Aug 20, 2018 at 10:13 AM
    fairclothr1
    Ryan
    Right. And, thanks for the reply!
    My question is more whether the DLR actually turns off when the turn is triggered, or, is it just not "on" b/c it's the turn signal. There are 3 wires coming out of the turn signal bulb housing, but, wasn't sure if someone could point me to which was turn and which was DLR on my 09.
  4. Aug 20, 2018 at 11:49 AM
    1UPPER
    TEXAS
    Flux capacitor!
    There are videos of the led light you posted on the Amazon reviews link. The drls turn off when the turn signal is engaged.
  5. Aug 20, 2018 at 5:24 PM
    fairclothr1
    Ryan
    So I just put a tester on the 3 wires going into the turn signal on the truck. The white/black is ground, the red is turn and blinks and is constant for the DLR. The purple never seemed to light anything up. I was hoping the DLR would be one of the 2 wires and the blink would be the other. Seems to not be the case. I believe the kit I purchased assumes there are 2 different wires for DLR and turn. I just don't want it to light up as white and amber when the turn light is on. Looking for other options for this mod to be wired properly. Thanks.
  6. Sep 2, 2018 at 7:27 AM
    11SilverPlatinum
    11SilverPlatinum New Member
    Dave
    2011 Platinum Tundra
    Plastidip emblems, Pace Edward bed cover w/lumber rack, remote start, TRD intake and exhaust, TRD front and rear sway bars, color match grill surround, LED headlight upgrade.
    Did you ever resolve your wiring issue? I am interested to find out what you ended up doing.
    I would like to add some sort of LED DRL and possibly a turn signal to my 2011 as well.
    Looking forward to seeing where you mount and how you mount as well. Keep us posted.
  7. Sep 2, 2018 at 7:49 AM
    fairclothr1
    Ryan
    I did not I got the lights and they were terribly ugly, so sent them back. Cheers!
  8. Sep 2, 2018 at 7:54 AM
    11SilverPlatinum
    Dave
    Good to know. If I ever get anything figured out, I will post pics and a write up.
