DIY: Upgrade to Power Fold Mirrors - IN PROGRESS
Discussion in 'General Tundra Discussion' started by csuviper, May 29, 2018.
Thread Status:
Not open for further replies.
  1. May 29, 2018 at 1:34 PM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Below is the install as completed on my 2012 5.7L Rock Warrior Crew Max. Should be the exact same process for all 2007+ Tundras however wire colors could vary between different years and models. I do not have confirmation on this.
    Since there was bits and pieces of information i decided to create my own connector diagram to make it easy for someone to tie in the wires correctly. See attached.
    Parts List:
    • (12) TE Connectivity 1123343-1 (Mirror pins and auto-dim) - sourced from digikey.com
    • (??) TE Connectivity 175265-1 (Mirrorswitch pins) - sourced from digikey.com
    • (1) 12 feet of 4-conductor/22AWG wire - sourced from Amazon
    • (1) Set of mirrors with power fold functionality - sourced from local craigslist
    • (1) Mirror switch that includes the power fold button - sourced from ebay
    Tools Required:
    • Wire stripper
    • Phillips screwdriver
    • Wire clothes hanger
    • Plastic removal tool
    • Utility knife
    • Needle nose plyers
    • Soldering iron
    • Solder
    • Electrical tape
    1. Remove the stock mirror switch and replace with the new mirror switch with power fold button.
    2. Remove the door cover. This consists of two Philips head screws, push connectors, electrical connector and door lock cables.
    3. Remove the speaker.
    4. Use the wire clothes hanger to feed the wires through the door rubber garment from door to cab.
    5. .......
    Here is a great video that will walk you through the whole process. Use this with the attached connector wiring diagram that i created and this will be easy to complete.
    https://www.youtube.com/watch?v=W1H47F2KP3Q
    Here is another reference that i used to create the DIY:
    http://www.tundratalk.net/forums/tu...ll.html#/forumsite/20555/topics/439441?page=1
    DaMaN, JOZ20, Sas and 1 other person like this.
  2. May 29, 2018 at 1:35 PM
    csuviper
    Broomfield, CO
Thread Status:
