DIY Painting Front and Back Bumper
Discussion in 'Detailing' started by THertzog, Apr 18, 2019.
  1. Apr 18, 2019 at 9:20 AM
    THertzog
    THertzog [OP] New Member
    I have a Black 2016 Tundra that I want to get rid of the god awful chrome bumpers on the front and back. I have thought about buying custom painted OEM ones, but I like the idea of saving money and doing it myself.
    Has anyone successfully painted these themselves with plasti dip or something else and had success? Are there any good write up's on the best way to do this to get it to match the color the best? Is plasti-dip a good way to go about it? Will it match the glossy black on the truck?
    New here, any advice would be great.
    Thanks!
    NUDRAT likes this.
  2. Apr 18, 2019 at 9:34 AM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    I think lots of people have had issues with getting anything to stick to the chrome.
    And as far as I can tell, the cost/time to prep the chrome adequately usually adds up to “why not just buy the finished product”.
    Can’t wait to see how it turns out and holds up if you do DIY it though!
  3. Apr 18, 2019 at 9:38 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Many have Plastidipped and can look good. Always temporary IMO.
    Key is prep, need to find a good primer for chrome. I think there is some stuff out there. Once primered paint away.
  4. Apr 18, 2019 at 9:54 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Plastidip holds up fine as long as u clean it good and do light coats at a time. I used 1 can for the front and 1 can for the back just kept doing coats with a 10-15 min drying period. I’m going on a year and I’m not complaining at all
    Les7311 likes this.
  5. Apr 18, 2019 at 9:56 AM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    I put some Monstaliner (paint/brush on bed-liner) on my bumper ends and it has held up AWESOME!! Not a single chip, scratch or blemish on them and I've wheeled my truck HARD.
    Step 1 - 85 grit sand paper on a random orbital
    Step 2 - Tape off the fogs and sensors
    Step 3 - Spray on Bulldog Adhesion Promoter
    Step 4 - Mix up the Monstaliner (it's a 2-part "epoxy")
    Step 5- 1st coat of liner
    Step 6 - 2nd coat of Monstliner
    This stuff is TOUGH Highly recommend.
    Ostrich, Patch999 and ManoTundra like this.
  6. Apr 18, 2019 at 10:00 AM
    Porkchop Express
    Porkchop Express Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
    My dad painted mine with OEM 202 code black. The prep work was really key - POR 15 epoxy sealer and then POR flat black primer, then 202 black with clear coat.
    10TundraSR5 likes this.
  7. Apr 18, 2019 at 10:21 AM
    THertzog
    This looks great! Where did you get the paint? I am assuming I would have to purchase online?
    Les7311 likes this.
  8. Apr 18, 2019 at 10:23 AM
    THertzog
    This looks super sick. I might want to do this, as I have a front grill guard that has the same finish on it. BAD ASS!
  9. Apr 18, 2019 at 10:26 AM
    DividedSky
    Jeff
    Best was the cost!! Maybe $60 all-in (ok, maybe $70 if you include the paint brushes etc) If you want less texture, use a smooth "cabinet" roller from Lowes/Depot.
  10. Apr 18, 2019 at 10:35 AM
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    I went the plastidip route and it’s held up fine. The only touch up I have had to do was when I got a little too close with the power washer. It will work until I get all the other mods done I want.
  11. Apr 18, 2019 at 10:52 AM
    Porkchop Express
    Cody
    2017 Tundra CM
    I have to be honest , my dad is a professional painter by trade and he had everything in his garage at his house. You can buy all this stuff from Industrial Finishes , but I dont know the cost.
    I will say take your time on the prep work and pay attention to the nooks and crannies - that is where the paint will start to peel off and chip away.
  12. Apr 18, 2019 at 11:02 AM
    THertzog
    You plasti dipped the fender flares in your profile pic? How did you get the gloss look?
  13. Apr 18, 2019 at 11:05 AM
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    Wiped with alcohol the 4 coats of PD and 4 coats of glossifier in the bumper caps. The fender flares are painted. Out of town right now but will pm you a pic of how the caps turned out. It’s not a match but looks good enough to me.
  14. Apr 18, 2019 at 11:33 AM
    THertzog
    Awesome man thank you!
    Patch999[QUOTED] likes this.
  15. May 7, 2019 at 7:22 PM
    Seabashh
    Seabashh New Member
    2012 Tundra Crewmax
    Even tried Steel-it? Works pretty amazing if you ask me
