DIY: Chrome Shift Console Bezel Removal : Vinyl Carbon Fiber Wrap
Discussion in 'General Tundra Discussion' started by Koke, Jul 28, 2017.
  1. Jul 28, 2017 at 1:37 PM
    Koke
    Koke [OP] New Member
    2014 SR5 Tundra TSS
    First DIY, well actually second. I did the steering wheel chrome accents & shot the whole removal on video. I just haven't gotten around to cutting it yet. This one is a fairly easy job. I wasn't able to locate any resources that explained how to take the chrome bezel piece off the center shift console. After an hour and given around I decided to just go for it and try what I thought was how it was connected. After the semi heart attack I got from this wicked plastic snapping sound, it only took about 45 minutes. I always hate when people don't show what the final looks like until the bottom, so all those are first.
    So the center console pops off just using a plastic pry tool. Unscrew your shifter & then you can probably use a plastic spatula, just nothing that will tweak the finish. Pull that up & take a peek at all the filth you probably have accumulated. I went off cleaning mine b4 the pics, I saw a thread where this dude with a pretty good helping of OCD was going into vapor lock over the dirt in the pics.
    To make this:
    Do this:
    Theres a few slotted tabs which are obvious how to remove,
    but the top & bottom are plastic welded where these little stamp patterns are. I used an old discount card cut into strips to wedge in there to get a bit of a gap. Take a THIN flat head, get it close to the weld & pry it up. You're gonna hear a pretty nasty snap.
    They "should" just break at the weak point & leave a little hole.
    In my opinion, this is the best stuff to wrap with.
    It is really forgiving. You need to use some heat to get the vinyl to relax. Believe it or not, for things this small i'll use a candle. Like I said, this piece is really pretty easy to do. Only thing you don't want to do is stretch the vinyl too far as it will be very evident in the carbon look pattern.
    It will be a tight fit reinstalling. Probably will have to trim any bunched up corners. I just super glued the plastic broken tabs... they aren't going anywhere.
  2. Jul 28, 2017 at 1:41 PM
    Added to the DIY list :thumbsup:
    Bob likes this.
  3. Jul 28, 2017 at 7:23 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    At first I thought you were removing the vinyl wrap
  4. Jul 28, 2017 at 7:55 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Looks great!
  5. Mar 3, 2018 at 9:24 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Nice looks awesome
  6. Apr 9, 2020 at 7:28 PM
    DoctorBAH
    DoctorBAH New Member
    Big D
    2017 Tundra Limited 4x4 - black
    - Billstein 5100 Ride-Height Adjustable front shocks, set to ‘level’ the truck (raised the front approx. 2-inches). - K&N Cold Air Intake (#77-9036KP) - Bakflip G2 tri-fold hard tonneau. - Flowmaster, Series 44, 2-in/2-out. - Slightly bigger 275-60/20 Firestone Destination All-Terrain (33-inch). - Husky X-Act Contour Floor Liners. - GTR Lighting Gen 3 LED Ultra Series headlight bulbs. - GTR Lighting switchback LED bulbs for DRL, Blinkers and Parking lights. - Philips X-tremeVision LED Fog Lights - Vehicle OCD™ (Organized Console Device) ($25 Amazon, awesome). - The Stubby radio antenna. - Philips Bright White Vision LED Back-up Light (921/T16) (12789LPB2) for rear high mount cab lights (awesome). - SYLVANIA 168 T10 5W White LED Bulbs for tag/license plate lights. - Carbon Fiber Door Sill Protectors. - TRDbeast door handle decals and center console emblem. - Tailgate letter inserts, carbon fiber. - Blacked-out chrome “TUNDRA” on front doors. - Tow Hooks painted red (+5 hp).
    Where’d you find that shift knob?
