DIY camper shell low profile rack
Discussion in '2.5 Gen Tundras (2014-2021)' started by tinman10101, Jul 2, 2019.
  1. Jul 2, 2019 at 11:09 PM
    tinman10101
    tinman10101 [OP] Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    So I want a low profile aluminum rack for my camper shell but as you know, the low profile ones are a pretty penny. I saw this post while surfing online for ideas and thought it was pretty bad ass. What do you guys think? .. Maybe someone here knows who this guys is. Regardless I might try this.
    https://imgur.com/gallery/NKKKy
    FYI THIS IS NOT MY POST NOR DO I CLAIM IT TO BE. ;)
    The modular TNutz is new to me so I gotta figure out the hardware and exact measurements and how to order it to make it work. :confused:
    Jmad1997 likes this.
  2. Jul 2, 2019 at 11:15 PM
    Jmad1997
    Jmad1997 New Member
    There is also a thread on TW on a homemade aluminum rack. The guy purchased custom length crossbars from Tnutz and had the ends threaded. Then went to a local metal yard and got some 1/4” aluminum I believe and made a cardboard template of how he wanted them to took and cut them with an angle Grinder and drilled holes where he wanted crossbars. He had a track system on his shell and used some scrap square tubing and cut out both ends at an angle and it bolted right up to the camper shell tracks. Or you can also use the smitty bolt universal roof rack mounting feet with slight modification and some guys were getting good results. I will be tackling this soon after I get some camper shell roof rack tracks installed.
    tinman10101[OP] likes this.
  3. Jul 2, 2019 at 11:19 PM
    tinman10101
    Tinman
    2016 MGM Crewmax
    Thanks so much for the info. I'll check it out on TW. This might be something I can see myself doing. :thumbsup:
  4. Jul 2, 2019 at 11:19 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Get 80/20 aluminum cross bars the length. You need then 3in aluminum flat bar for the sides and some 1.5” square stock for the legs with angle cuts. About to order my stuff next week and build it. Be about $300 maybe a little less when it’s all said an done
  5. Jul 2, 2019 at 11:21 PM
    tinman10101
    Tinman
    2016 MGM Crewmax
    Thanks Ty. Could you post some pics once you are done? Would love to see how yours come out.
    xtyfighterx[QUOTED] likes this.
  6. Jul 2, 2019 at 11:21 PM
    xtyfighterx
    Ty
    North Idaho
    You can also save money and go the uni strut route.
  7. Jul 2, 2019 at 11:21 PM
    xtyfighterx
    Ty
    North Idaho
    Yes sir will do. Follow my build to I’ll have it posted there first I’m sure.
  8. Jul 2, 2019 at 11:32 PM
    Jmad1997
    Jmad1997 New Member
    The plus side to Tnutz cross bars is most roof rack accessories such as prinsu and rhino rack will work with it. No more custom fab other than the rack. This would make for a good weekend project.
  9. Jul 3, 2019 at 12:06 AM
    tinman10101
    Tinman
    2016 MGM Crewmax
    Thanks @Jmad1997 ... I just realized that looking at the Prinsu Rack it uses cross bars very similar to the Tnutz extrusions like you said. All that is different are the laser cut side rails and additional channels on the cross members. and of course ... Prinsu bragging branding. ;)
    Jmad1997[QUOTED] likes this.
  10. Jul 13, 2019 at 1:01 PM
    flinky14
    flinky14 If I'm the wife, who says no to new mods?
    Genna
    Alberta
    2019 Tundra CM Platinum 4x4
    -TRD Dual Exhaust - 3m - UV front window tint/rear limo tint -TRD Oil Cap -Toyota Bed Mat - TRD Pro Grille - ARE canopy (sliding Windoors, pop down sliding front window, headliner, rack rails) -OEM Toyota Remote Starter -Baja Designs Sport Fog Lights -TRD door sill protectors -Ronin Factory short antenna
  11. Jul 15, 2019 at 9:21 AM
    bradleykd
    bradleykd New Member
    Brad
    Kentucky
    2016 Limited-BLACK
    I made my rack that mounts to my bed rails from 80/20 stuff. It will still run you a pretty penny.
