DIY Ammo Can Fire Pit
Discussion in 'Outdoors' started by helidave, May 28, 2022.
  1. May 28, 2022 at 8:40 PM
    helidave
    helidave [OP] Hellacopter
    flagstaff
    2015 DC 4x4
    Mag 2650 w/76mm pulley, ADS suspension, 35's, misc overlanding doo-dads and lights
    Seen a couple of these around and it seemed like a nice convenient way to have a fire during fire bans without lugging around my big round portable fire pit, but I'm cheap so I didn't want to spend $175+ for a lavabox or whatever.
    edit: need to find a different hose that can handle the heat better than the rubber one.
    parts:
    50 cal ammo can
    hose with adjustable regulator
    3/8 od copper tube (https://www.amazon.com/dp/B07JFQXL5Z?ref_=cm_sw_r_cp_ud_dp_QDB1HJMQY7JAZDY0YMYY)
    3/8 tube to 1/2" male npt fitting (https://www.amazon.com/dp/B07JQ78LV3?ref_=cm_sw_r_cp_ud_dp_7JSYN91HDB1WYMRRACE2)
    1/2" female npt to 3/8 male flare fitting (https://www.amazon.com/dp/B0041NPBYW?ref_=cm_sw_r_cp_ud_dp_1HDC8XDAVYD8GP92RD6B)
    expanded metal mesh (https://www.homedepot.com/p/Everbil...n-Plain-Expanded-Metal-Sheet-801417/204225783)
    3/4" washers (home depot)
    1" aluminum angle and 1/4-20 hardware for legs (home depot)
    Total cost under $100 and I have enough copper tube and mesh left over to make 1 or 2 more.
    firecan1.jpg firecan2.jpg firecan3.jpg firecan6.jpg firecan5.jpg firecan4.jpg
  2. May 28, 2022 at 9:30 PM
    Wahayes
    Wahayes Older I get the wiser I realize my dad was
    Will
    2017 tundra limited
    325/60r20 falken at3w, 2.25 dobinsons ,20x9 +20 fuel torque wheels, leer xr100, bmc
    Can you cover the steps of how you built it?
    Occidentalis likes this.
