Ditch Lights - Switch Wiring
Discussion in 'Lighting' started by nick_sher03, Jun 29, 2017.
  1. Jun 29, 2017 at 6:34 AM
    nick_sher03
    nick_sher03 [OP] New Member
    Nick
    2017 White Tundra CM TSS
    Hey everyone, so I finally got around to installing my Rago Ditch Light brackets and lights last night.
    Right now I have a fuse tap on order. My question is, where should I should fuse tap at to have the switch illuminate with all of the other switches, basically off during the day..? Right now I am not using the 4th wire of my switch at all, therefore the switch is always lit up.
    Picture for those on the ropes about ditch lights. I love everything about them, when searching for pictures and information I could never find anything Tundra related, always Tacoma stuff.
    I'll get an additional picture or 2 tonight with them illuminated.
  2. Jun 29, 2017 at 7:52 AM
    nick_sher03
    Nick
    That sounds like a good idea. I'll look tonight for a light blue wire coming off a neighboring switch. Makes sense though, considering those all illuminate once the headlights come on. Did you use a posi-tap?
    NewImprovedRon likes this.
  3. Jun 29, 2017 at 7:56 AM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    Off topic but had a question for you. Do you get a lot of glare off of the hood with these lights? I want to install these but aim them almost straight rather than out to the sides. Looks like you have them slightly turned out but still lighting out in front of the truck.
    Thanks,
  4. Jun 29, 2017 at 9:34 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    I think I would flip the bolts. Have a bad bounce and that bolt will be in the paint really quick.
  5. Jun 29, 2017 at 9:59 AM
    kicnit
    kicnit New Member
    14 Tundra TRD DC
    De-badged
    Was just going to say that actually.
    Kyle
  6. Jun 29, 2017 at 10:13 AM
    nick_sher03
    Nick
    Great IDEA! I will probably try that out.
  7. Jun 29, 2017 at 10:14 AM
    nick_sher03
    Nick
    No glare at all actually! I do not know what effects you would encounter with different colors or anything. For me and the white, no glare on either side. What you do see is from the sun, I was in parking garage at the time.
    MatthewPTguy likes this.
  8. Jun 29, 2017 at 1:12 PM
    Njmike13
    Njmike13 New Member
    2021 PRO Lunar Rock
  9. Jun 29, 2017 at 1:49 PM
    nick_sher03
    Nick
    Is the wire more of a teal color? Picture of the back side of the panel.
  10. Jun 29, 2017 at 1:49 PM
    nick_sher03
    Nick
    As you can see, I tried one of the blue wires, but didn't get any results.
    Top left.
  11. Jun 29, 2017 at 2:59 PM
    nick_sher03
    Nick
    I ended up using a volt meter, turns out I had the right wire. I am now good to go. Thanks for all of the help.
    Future note, do not cross the wires coming from the harness to the switch. I was working off of a video for the wiring. Turns out it was wrong for the Tundra.
    For the Freedom LEDs: WHITE to GREEN, BLUE to RED closest the GREEN, BLACK to BLACK. Second RED goes to Darker BLUE next to the purple there. On the factory switches anyways..
  12. Jun 29, 2017 at 6:29 PM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    I wondered how these would look on a CM. I am not a fan I think they are too small on such a large rig. But I'm glad you like em and they do make great light.
    nick_sher03[OP] likes this.
  13. Jun 29, 2017 at 6:31 PM
    Tracker
    Tracker New Member
    Shane
    Color blind guy looking for the blue wire
  14. Jun 29, 2017 at 7:54 PM
    nick_sher03
    Nick
    Top left in the picture.
    Bottom most switch on the panel. Wire furthest to the edge. That's the illumination wire.
    Best way to check it is shave a bit and use a volt meter to see if 12 volts are there when you turn the headlight switch on. Check it for 0 volts when the lights are turned off.
  15. Jun 29, 2017 at 7:55 PM
    nick_sher03
    Nick
    Thank you. Agreed that they are not for every body. I'm not a light bar guy and these were extremely economical compared to a light bar.
    Be advised these little guys pack one hell of a punch!
  16. Jun 29, 2017 at 8:13 PM
    Tracker
    Tracker New Member
    Shane
    I'm not a light bar fan either. They square off the nice curves of a beautiful truck. I still like the old school circle lights. I may do a small light bar on my future bull bar since it won't stand out too much. I bought some square creeds like the ones you just mounted and I'm going to mount them to my frame facing to the sides of the truck when I get time. Kids keep telling me I don't get that time.
  17. Jul 13, 2017 at 11:50 AM
    stefan702
    stefan702 IG: 702stefan_
    Randy
    Las Vegas
    2015 Tundra TRD Offroad
    IG: 702stefan_
    Did you drill a hole in that plastic to run the wire from the light itself or go behind that little flap at the very end of the plastic? I've never wired shit and this thread makes it seem possible for me haha
  18. Jul 13, 2017 at 11:54 AM
    nick_sher03
    Nick
    I just went around and tucked it away. I didn't drill one piece. And when I ran through the fire wall grommet, I used a blade to cut a very small section on the top left side. Then taped the wire to my antenna and fished it through haha.
    It really is simple. If you have any questions just let me know.
  19. Jul 13, 2017 at 11:56 AM
    stefan702
    Randy
    Las Vegas
    IG: 702stefan_
    Thanks dude! The antenna sounds like a great idea!! :)
  20. Jul 13, 2017 at 12:46 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    It won't touch your paint, the bracket moves up and down with the hood. He has them bolted in the proper way.
  21. Jul 13, 2017 at 12:52 PM
    Backslider
    Tooele, UT
    I have these on a CM, I think they're perfect and actually get compliments on them often. I have the side shooters and they pretty much light up a 1/2 circle from the center to the front of the truck. The light output on these pods is amazing.
  22. Jul 13, 2017 at 1:48 PM
    gan
    gan New Member
    Rgv Texas
    2021 Black Tundra Pro
    I had these on my 4 runner, I am planning to add them to my tundra, just waiting for the next group buy.
    Backslider likes this.
  23. Jul 13, 2017 at 1:54 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Almost no glare on the hood.
