Dirty Transmission Fluid!
Discussion in '3rd Gen Tundras (2022+)' started by Malinois38, Oct 30, 2025.
  1. Oct 31, 2025 at 11:39 AM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    Why would Toyota go to the expense of a thermostat if it wasn't needed? The only reason would be because there was a financial incentive - either fuel economy (CAFE), sales (not a selling point), or reliability reputation (future sales).
    Queue overcooling debate.
  2. Oct 31, 2025 at 11:41 AM
    NimbusDog
    NimbusDog New Member
    Tampa, FL
    TRD Pro
    I no longer have a restrictive thermostat. So long!
    eddiefromcali likes this.
  3. Nov 1, 2025 at 10:25 AM
    NimbusDog
    Tampa, FL
    TRD Pro
    Totally agree. Just ordered my filter and some stainless hose clamps.
    75tranzam[QUOTED] likes this.
  4. Nov 2, 2025 at 11:43 AM
    Dozer466
    Dozer466 New Member
    2022 Tundra TRD Pro
    Westcott 3/1, 37" Toyo's, Smartcap
    How often do the filters need to be replaced?
  5. Nov 2, 2025 at 12:05 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA 1 7/8 Longtubes, Snivs 1.88 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT Trans/valve body, 4.5inch intake with 10x2 SABM, FIC 880/930cc injectors, 450 Walbro, Direct Port W/M injection, GM 95mm TB, DW fuel regulator, E-fan, Remote engine air/oil cooler, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    From what I've gathered from different forums is every atf change 24-30k miles or yearly. I don't do drain/fills but complete fluid change every 2 years regardless of mileage. I just picked up a filter for install with my rebuilt transmission.
    http://www.emergingent.com/magnefine/faq.htm
    75tranzam likes this.
  6. Nov 6, 2025 at 8:46 AM
    NimbusDog
    Tampa, FL
    TRD Pro
    Thanks for the info guys! Super easy to do.
    Gaper, AND, kkkk2023 and 1 other person like this.
  7. Nov 6, 2025 at 10:19 PM
    Retroboy1989
    Northern Utah
    Have you guys encountered the drain plug on the transmission being really soft? I have had mine off a couple times now and the internal hex is staring to deform. I've kept to the 30 ft lbs and always use a 6mm hex fully inserted.
    It's bad enough that I don't want to reuse the plug again after I next remove it.
    The 3rd gen is too new, but I am wondering if anyone has found a suitable aftermarket or alternate part number.
    jstone88 likes this.
  8. Nov 7, 2025 at 9:25 AM
    NimbusDog
    Tampa, FL
    TRD Pro
    Waiting for these to be on sale...
    https://ppepower.com/collections/to...-tundra-2023-2025-sequoia-awr10l65-heavy-duty
  9. Nov 7, 2025 at 10:26 AM
    Retroboy1989
    Northern Utah
  10. Nov 13, 2025 at 9:11 PM
    Retroboy1989
    Northern Utah
    Here is the part number: 90341-12034 for the softest metal drain plug in the world. I've only had it out maybe 3 times and the 6mm is rounding.
  11. Feb 4, 2026 at 12:16 PM
    75tranzam
    75tranzam New Member
    Midlothian, Va
    2024 Midnight Black 1794 Limited Edition #751
    Did the same in mine and you are correct, it was super easy. I'm a big guy but it was easy to crawl under the truck and access the line, snip it, snip it again to account for the size of the filter, install filter and ss clamps, and I was done in about 10-15 minutes.
  12. Feb 4, 2026 at 12:23 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Its there to warm up the trans faster to optimal efficiency temp. However normal driving blows way past that temp
    jstone88 and eddiefromcali like this.
  13. Feb 4, 2026 at 12:38 PM
    eddiefromcali
    eddiefromcali New Member
    2022 Tundra Platinum
    100% Stock
    Yup, for those of you reading this. Dont do the bypass if you dont have an adequate external cooler
  14. Feb 4, 2026 at 12:43 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    2017 Tundra Platinum CM 2016 4runner SR5P 2026 4runner TRDORP
    I do a drain and fill once a year for the last 3 years. The 3rd time the fluid came out good. Just do it once a year and not worry about mileage. I also tow a 6k trailer.
  15. Feb 4, 2026 at 1:38 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    My normal city driving gets the trans to 203. With the thermo pinned it stays around 170
  16. Feb 4, 2026 at 1:48 PM
    eddiefromcali
    100% Stock
    3rd gen?
  17. Feb 4, 2026 at 1:51 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Says he has a 2nd. I have to remember to check profiles or what forum it's posted under as a lot has changed with 3rd Gen.
  18. Feb 4, 2026 at 1:52 PM
    eddiefromcali
    100% Stock
    I saw it but didnt want to assume. 3rd gen transmissions run hotter apparently
  19. Feb 4, 2026 at 5:18 PM
    #49
    AND
    AND New Member
    Washington, PNW
    Is there any fluid loss when installing either of these. I have both parts sitting on my work bench but I don’t have any trans fluid.
    Thanks in advance
  20. Feb 4, 2026 at 8:33 PM
    #50
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    2nd. However I can’t read unfortunately, there was another discussion about 2nd recently too. It does seem however that toyota has carried over their trans temp theories to the 3rd
    eddiefromcali[QUOTED] likes this.
  21. Feb 5, 2026 at 5:16 AM
    #51
    75tranzam
    Midlothian, Va
    For the filter it was a tiny amount, I didn't even have to add any since it was such a small amount.
    AND[QUOTED] likes this.
  22. Feb 6, 2026 at 4:58 PM
    #52
    bailey bulldog
    bailey bulldog New Member
    So the PPE wouldn’t be good just to add?
  23. Feb 6, 2026 at 5:46 PM
    #53
    eddiefromcali
    100% Stock
    Not from what Im seeing. Ive seen temps exceed those i saw with the oem t-stat.
