Dirty Transmission Fluid!
Discussion in '3rd Gen Tundras (2022+)' started by Malinois38, Oct 30, 2025.
  1. Oct 30, 2025 at 11:57 AM
    Malinois38
    Malinois38 [OP] New Member
    Pa.
    2022 Platinum Hybrid WCP
    So, I just had my second transmission fluid service done at 63k & it was very dirty. Had the first done at 30k. I tow a 7k camper a decent amount. The Tundra calls for 30-60k intervals. I’m doing 30k & it doesn’t seem to be enough? Anyone else towing & seeing the same??
    Should note that the towing has been great, no issues at all.
    CaptRussia253 likes this.
  2. Oct 30, 2025 at 12:03 PM
    You had the fluid tested and it came back as dirt or sand or silica? Or it just looked dark? Sealed transmission shouldn’t be getting “dirty”.
    mqqn, =JSG= and Breathing Borla like this.
  3. Oct 30, 2025 at 12:25 PM
    Dozer466
    Dozer466 New Member
    2022 Tundra TRD Pro
    Westcott 3/1, 37" Toyo's, Smartcap
    Are they just draining the pan and replacing what was drained? I did a full replacement to Amsoil and it was still really dark after two drain and fills. The third it finally lightened up and the final everything was nice and red.
  4. Oct 30, 2025 at 1:20 PM
    Malinois38
    Pa.
    Was done at my local Toyota dealership. I did not speak to the tech in person. Assuming drain/fill.
    The message from the tech that it was dirty & should consider changing more frequently.
  5. Oct 30, 2025 at 1:22 PM
    eddiefromcali
    eddiefromcali New Member
    2022 Tundra Platinum
    100% Stock
    Frist drain will always be dark. Nothing "dirty" about it
  6. Oct 30, 2025 at 1:23 PM
    Malinois38
    Pa.
    This was #2 drain for me.
  7. Oct 30, 2025 at 1:34 PM
    Malinois38
    Pa.
    Here is the specifics on the transmission service:
    TRANS FLUID EXCHANGE
    PERFORM TRANSMISSION FLUID EXCHANGE. USE FLUID EXCHANGE
    MACHINE TO REMOVE AND REPLACE ALL FLUID IN TORQUE
    CONVERTER AND TRANSMISSION. REPLACE DIFFERENTIAL FLUID
    IF APPLICABLE.
    PERFORMED TRANSMISSION FLUID EXCHANGE. USED FLUID EXCHANGE
    CONVERTER AND TRANSMISSION. REPLACED DIFFERENTIAL FLUID
    WHERE APPLICABLE.BROUGHT TRANSMISSION FLUID TO PREDETERMINED
    TEMPERATURE AND SET FINAL FLUID LEVEL AT FILL PLUG.
    banjo1981 likes this.
  8. Oct 30, 2025 at 1:35 PM
    eddiefromcali
    100% Stock
    if first one was a simple pan drain, you had another 8qts of "dirty" fluid in there. You have to drain and fill like 12qts+ to get most of the old stuff out. There was nothing "dirty" about that fluid other than initial wear material which isnt bad...thats why these trans arent serviceable.
  9. Oct 30, 2025 at 1:35 PM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    There are lots of threads on here about how hot the 10 speed gets while towing or in 4wd. Best guess is that your fluid is getting toasty as compared to someone who just uses the truck to drive to work.
    That said, I've read color is not a reliable indicator of health for trans fluid.
    I tow myself and hope to see this truck last a long time. It wasn't cheap, but I bought an AFE cooler kit and installed it on my truck. What made it more expensive is that only used the kit for the cooler itself and then stainless brackets. I bought my own braided AN hose kit.
    Malinois38[OP] likes this.
  10. Oct 30, 2025 at 1:55 PM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    Heat degradation and coolers are well covered, look into them.
    A real filter would certainly increase the longevity of any modern automatic transmission. Great little article here which certainly applies.
    https://www.motortrend.com/how-to/129-1002-automatic-transmission-and-power-steering-filters
    We deal with worn valve body parts in the old 2nd gens all the time now, this wear would be significantly reduced, or could have been nearly eliminated with proper filtration from early on in the transmissions life cycle. The lifetime and extended drain BS eats these things up by giving contaminants long term exposure to parts that would prefer truly clean oil.
    kkkk2023, Mdl and blenton like this.
  11. Oct 30, 2025 at 2:05 PM
    JDAZ
    JDAZ New Member
    NJ
    2022 Lunar Rock TRD Limited
    Chrome Delete, TRD Pro Grill with BD light bar & OEM switch Beatsonic Amp Undercover armor flex cover
    The filter in the pan is an actual paper filter, not a strainer. I changed that when I got my higher mileage 22, along with all 11qts of fluid. Kind of assumed it had never had a D&F. I did a write up on it. I will do another exchange at 100k as I do tow a 7K+ TT
    Jowett likes this.
  12. Oct 30, 2025 at 2:10 PM
    Retroboy1989
    Northern Utah
    I didn't know this. I'll have to add this to my maintenance plan down the road.
    I am running a magnafine type filter after my new cooler.
  13. Oct 30, 2025 at 2:13 PM
    Jds685
    Jds685 2nd Tundra
    CT
    2024 Tundra i-Force Max 1794
    This sounds like more than a drain/fill, but instead a full flush. If that's the case for both the first and the second services, I'm surprised the color is that dark.
  14. Oct 30, 2025 at 2:57 PM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    The old strainers on the A750F and prior series transmissions use a metal screen that won’t capture much, just the large junk that could take out the oil pump. The newer design is a plastic felt depth type filter material and still rated for the life of the transmission. The micron rating is certainly better than the old screen, but still probably quite large, much above where it needs to be in order to slow or eliminate wear.
    Dissected filter w/ 106k miles from a 2011 AB60F truck that lead an easy life. Fluid looked nice at 93k when I bought it, just a little dirty, possibly had one pan drain @ 60k. No issues with trans performance, but the C1 Accumulator had significant wear, the boost valve minor. Eventually they would seep off enough pressure to the point of issues. Point being, this part won’t do the job.
    kkkk2023 and Mdl like this.
  15. Oct 30, 2025 at 3:00 PM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    Here's my first FF comparison at 34k miles. With one tow on it, 7200 lb trailer. The rest were commuting miles.
    Where do you go to get all the fluid pumped out? I'd be interested in that.
  16. Oct 30, 2025 at 3:20 PM
    Retroboy1989
    Northern Utah
    I'm a big fan of an annual drain/fill. It keeps the fluid with fresh additives and a portion of the accumulated debris goes out with the fluid.
    1794forme likes this.
  17. Oct 30, 2025 at 7:10 PM
    NimbusDog
    NimbusDog New Member
    Tampa, FL
    TRD Pro
    So after viewing this, I got thinking... Could easily put one down underneath where the thermostat is. Question is, which line does fluid flow in and which flows out?
    You can see the OEM trans tstat in this video and the rubber hoses connecting it..
    Thoughts?
    Woocawachie likes this.
  18. Oct 30, 2025 at 7:36 PM
    JDAZ
    JDAZ New Member
    NJ
    From my write up
    NimbusDog[QUOTED] likes this.
  19. Oct 30, 2025 at 10:33 PM
    ColoradoTJ AMSOIL Snob Staff Member
    Ford F-350, Roush Mustang, Jeep Crawler
    Do you know when a dealership technician is lying?
    Their mouth is moving.
    Unless you are doing this service yourself or the tech is giving you a sample to send in for testing, I personally wouldn't believe a damn thing they are saying.
    I have had a dealership service advisor tell me that my transmission fluid was very dirty and should be changed immediately. Oddly enough a few weeks earlier I had installed my PPE Allison double deep pan. Over two gallons came out and almost three went in. The fluid that came out looked brand new. The only thing I could think of is the tech pulled the engine dipstick instead of the transmission dipstick because they wouldn't lie...:rolleyes:
    Dealerships like to validate even more service than what is needed.
  20. Oct 31, 2025 at 3:33 AM
    Bulldog6
    Bulldog6 New Member
    ‘25 Lunar Limited
    I had a tech show me a sample of really really dirty diff fluid and suggest a service. This was shortly after re-gearing, so I wanted to crack it open myself and have a look. I drained it and upon inspection, it was clear the tech lied. I don’t know where he got the sample, but it wasn’t from my diff.
    raylo, BlackNBlu and NimbusDog like this.
  21. Oct 31, 2025 at 3:44 AM
    NimbusDog
    Tampa, FL
    TRD Pro
    I could write a few pages of my experiences of catching dealers in lies... But I'll just drop one of my favorites...
    Buddy of mine had a Honda Accord, 2009 or so. Lives in a apt, so he came to my house to do some maintenance. We changed the plugs, new brake pads on all 4 corners, cabin air filter, engine air filter, and oil & filter change. The very next day his battery died. He had gotten from the dealer (hold the comments, I know, I know) less than 1 yr prior. So he took the car back to the Honda dealer for the battery replacement under warranty. They did a "complimentary multi-point inspection" , and craziest thing, he needed new pads and rotors and a cabin air filter too!!!
  22. Oct 31, 2025 at 6:19 AM
    I have had several bad ones myself. Two at Dodge & Toyota, one at Chevy dealership.
    Really good experiences:
    at the two GMC dealerships in my city.
    The south side Chevy dealership was good.
    Lexus was next level. I even started taking my tundra to them.
    Subaru is very good.
    This shocked me. Ford. I recently had experienced some issues with my Mustang popping certain codes that didn't make sense with the supercharger. Ford service reinstalled a Roush tune. That fixed everything and now the car really rips.
  23. Oct 31, 2025 at 7:11 AM
    Retroboy1989
    Northern Utah
    The dealer replaced a couple radiator hoses on my 2025 Tundra under warranty. The coolant reservoir was empty when I got home and it took nearly 1/2 gallon to fill.
    Because I am leery of any car repair, I checked the coolant level before I left the dealer and it was between L and F.
    I guess they didn't take the time to burp it?
  24. Oct 31, 2025 at 9:48 AM
    eddiefromcali
    100% Stock
  25. Oct 31, 2025 at 10:11 AM
    75tranzam
    75tranzam New Member
    Midlothian, Va
    2024 Midnight Black 1794 Limited Edition #751
    Eddie, what brand and where did you get the transmission fluid filter?
  26. Oct 31, 2025 at 10:14 AM
    eddiefromcali
    100% Stock
  27. Oct 31, 2025 at 10:21 AM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    The Magnefine is discussed at the link in post #10.
    NimbusDog, 75tranzam[QUOTED] and Mdl like this.
  28. Oct 31, 2025 at 10:42 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA 1 7/8 Longtubes, Snivs 1.88 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT Trans/valve body, 4.5inch intake with 10x2 SABM, FIC 880/930cc injectors, 450 Walbro, Direct Port W/M injection, GM 95mm TB, DW fuel regulator, E-fan, Remote engine air/oil cooler, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    Right on point. It's overkill but I do a full fluid change every year. Some shops call for a 24k change for the AB60. Grabbed a Magnafine filter for my new transmission.
  29. Oct 31, 2025 at 10:51 AM
    75tranzam
    Midlothian, Va
    I'll buy one and put it on along with pinning the thermostat open, can't hurt to do either it seems.
    kkkk2023 and NimbusDog like this.
  30. Oct 31, 2025 at 11:31 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Back in the day we used remote mounted filters for the transmission. B&M and others still make them. But the Magnafine is a good inline filter
