Dirty Deeds injectors
Discussion in '1st Gen Tundras (2000-2006)' started by Cody06tundra, Nov 12, 2019.
  1. Nov 12, 2019 at 8:25 AM
    Cody06tundra
    Cody06tundra [OP] New Member
    Cody
    2006 Tundra Crew Cab SR5 4.7L
    So I want to purchase the 12-hole 330cc injectors and I'm wondering if they are plug-and-play or do you have to recalibrate the ECM to accommodate the higher fuel flow?
  2. Nov 12, 2019 at 8:32 AM
    Cfincke
    San Antonio
    Give Keith aka @dirtydeeds a call, he is a wealth of knowledge. Dont be surprised if you wind up talking to him for 30 minutes or more.
  3. Nov 12, 2019 at 8:37 AM
    Professional Hand Model
    Hand Protectors
    FrenchToasty and Rex Kramer like this.
  4. Nov 12, 2019 at 8:43 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Are you SCed? I thought on the site it only reccomended the 250-270cc for 06.
    I just did mine, after you have the battery disconnected for a time period the ecu will reset and need to relearn parameters and driving habbits(shift points) but you will also experience misfires due to lack of fuel/pressure when you first restart the truck.
    What I would do if I was to do it again, disco the battery, do the injectors, at the same time clean the MAF and throttle body(a tech told me this is important, especially when the computer it trying to relearn) then connect the battery and only cycle the key to on to build fuel pressure; I had to drive mine 10 miles or so before I felt I had proper fuel pressure, the whole time untill then you could definitely feel it missing.
    I would then clear any codes that might of come about from misfires, and then disconnect the battery again so it relearns with no codes and proper fuel pressure.
    She drives great now!
    bmf4069 likes this.
  5. Nov 12, 2019 at 8:45 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    What are the real world daily driver benefits you get from this mod?
  6. Nov 12, 2019 at 8:55 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    :popcorn:
    Darkness likes this.
  7. Nov 12, 2019 at 9:32 AM
    Hand Protectors
    Quick answer: Shifting points seem more precise. No searching delay on downshift/deceleration. Doesn't make sense because the transmission is separate. Maybe has to do with ECM readings, but not sure exactly.
    Reason I originally did this was an exercise in experimentation. I wanted to clean my existing injectors, but that was a 3 day minimum turn around time. Buying brand new injectors was crazy expensive. So, I tried these remans after talking with Keith who has a 2002 as well IIRC. The cost of remans was very fair and equal with just pro injector cleaning. I had the knowledge base from him so gave it a go. Took about 5 hours. Do not do these for MPG gain. Its more for a modern shifting point feel.
  8. Nov 12, 2019 at 10:05 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Those 330cc injectors are for if you only run straight ethanol iirc and I don't believe they are plug n play. However the 250cc for non vvti and 270cc for vvti are plug n play
