Dirty Deeds BA mufflers VS TRD Pro exhaust
Discussion in 'Performance and Tuning' started by LAPlatinum, Oct 13, 2020.
  1. Oct 13, 2020 at 2:18 PM
    LAPlatinum
    LAPlatinum [OP] New Member
    Hi everyone
    Yes I know you've all seen this thread before but i gotta ask. What are your thoughts and experiences with these two systems? Looking to upgrading the stock muffler on my tundra. Been hearing alot of good things about the BAmufflers but a little hesitant because not sure if its legal and wont affect the emissions when smogging comes around which is why im also interested in the TRD exhaust. Let me know what are your opinions, thanks!
    Rica25 and YardBird like this.
  2. Oct 13, 2020 at 2:22 PM
    timsp8
    NY
    Rica25, YardBird and LAPlatinum[OP] like this.
  3. Oct 27, 2020 at 8:19 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    I’ll find out before long!
    I just installed DDs 10” exhaust. It appears to bolt up to the CAT, so emissions shouldn’t be affected.
    It is awesome, and very quick to install.
    I will hang onto my stock exhaust JUST in case...
  4. Oct 28, 2020 at 6:51 PM
    TKNorthwest
    TKNorthwest New Member
    Washington
    2018 Limited Crewmax 4x4
    I'm pretty positive BAmufflers are fine for emissions
    Rica25 likes this.
  5. Oct 30, 2020 at 3:25 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    The resonator is the biggest benefit to the dirtydeeds ones. That 1800 rpm drone is bad enough on the stock '14+ muffler and I can only imagine what it's like with the TRD glasspacks. Then again I have sensitive hearing or at least that's what the annual hearing tests I go through say. I put a resonator from Keith on mine behind the factory muffler and at some cruising speeds it's so quiet I cannot hear the engine. At all. It's very eerie. Just the driveline whirr and the wind buffeting behind the mirrors.
    Rica25 likes this.
  6. Oct 30, 2020 at 3:31 PM
    Hoologan
    Hoologan New Member
    California
    18 Cement Limited Crewmax TRD
  7. Oct 30, 2020 at 3:52 PM
    CNE0207
    CNE0207 New Member
    Arvada, CO
    2020 Cement CM Limited
    @dirtydeeds can clear up your emissions ? I run his standard system on my 2020... it’s f’in awesome!
    Rica25 likes this.
  8. Dec 7, 2020 at 8:01 PM
    tundraatx
    tundraatx 2008 Limited Double Cab, 5.7L
    Austin, TX
    1) Bought with 225k miles on it, a Westin bullnose bumper, and OEM tundra steps 2) Current Mileage 238k Mods: 1) Dirty Deeds BA Mufflers 8 inch with resonator (as of Feb 2021) - Had the 10 inch with resonator - Prefer the 10 inch without resonator - deeper sound hear it more in the cab 2.) Ranch Hand Summit Front Bumper/Guard 3) Ranch Hand Summit Bumper 4) Billstein 5100s all around 5) TRD front and rear sway bars 6.) Rough Country wheel to wheel steps 7) Pioneer 8400 NEX Wireless ApplePlay 8) Backup Camera: e-raptor 9) LED white lights replaced in headlights, fog lights, inside cabin, and exterior lights 10) Linex (unbranded by Central Texas Truck Coatings) 11) OEM Toyota side panels and generic panel on tailgate Maintenance/Repairs: 1) Valve covers, belt tensioner, alternator belt - $415 2) Evaporation fuel canister and filter replacment $1547 *This was a Toyota TSB for 07-08 AFAIK. Toyota covered in first 3 years of ownership. Mine failed after 13 years of daily regular driving use. Not bad at all. 3) Pioneer Unit - had to ship to Pioneer to replace Output IC - $45 (shipping) free under 1 year warranty fix 4) Pioneer Unit - Electrical feed back coming through speakers when accelerating. Fix was to check all wiring/tighten up/ make connections good again $42. 5.) Rear passenger door actuator replaced. Part was $287 with tax on ebay from Toyota dealer free shipping. 6.) Rack and Pinion, tow mirrors, shocks install, lifetime alignment - $1884.36
    Call Keith. He’ll answer all of your questions super helpful guy! Helped me go with the 10 vs 8 in case I end up towing one day plus a little quieter for the neighborhood.
    Rica25 and CNE0207 like this.
  9. Dec 18, 2020 at 7:40 AM
    Freakenrage
    Freakenrage New Member
    2013 Tundra DBL cab RW
    Two XS batteries D3400 NVX 10 farad cap Samsung tablet Arc KS 600.2 sub amp Arc 4050 CXLR 4 channel amp Sinfoni Quartorigo Mids and Highs (front) Deaf Bonce Sylverster Mid (rear) Sundown Audio tweeters (rear) SMD fuse holders SMD Output Meter (SMD-OM-1) SMD Output Meter (SMD-OM-1) SMD Voltage Meter (SMD-VM-1) Two JL Audio Powerwedge 10TW3-D4 2-Ohm Zero ga big three K&N CAI 3-Trumpet Train Air Horn Kit 150dB Access Cover Hood Guard AMP power steps Westin Bull Bar Bully Dog GT+T tuner 35/12.5/17 Steel grill Hammerhead rear bumper Coachbuilder 3" Shackles Coachbuilder steering stops and Tie rods Linex bed coating Morimoto Headlights and fog lights
    I had the TRD exhaust and removed it after a couple of years and bought Keith's setup. So much happier with it and could tell a difference in the response. Wish I did it from the beginning.
  10. Dec 18, 2020 at 7:47 AM
    ptat
    ptat New Member
    Does anyone know if I have the stock non-TRD exhaust, can I put the in the replacement system? I know I'll have to buy the TRD Tailpipes (Part # PTR03-34106). I'm fine with doing that.
    Would that be all I need if I want the DD TRD replacement system?
    Rica25 likes this.
  11. Dec 18, 2020 at 8:34 AM
    Freakenrage
    Are you looking to go to the dual exhaust? I went from the TRD dual back to a single DD for performance. I did have to use a stock tailpipe that I added a TRD black chrome tip to.
    Rica25 likes this.
  12. Dec 18, 2020 at 8:35 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The best answer to this question:
    do you want duals or stock tailpipe. Some people really want the duals
    Rica25 likes this.
  13. Dec 18, 2020 at 11:27 AM
    ptat
    ptat New Member
    Yep. That's what I'm mainly after. I've been researching and found out that the TRD exhaust has a drone on the freeway and lose out on some low end torque. The DD TRD replacement system takes care of both of those things.
    Freakenrage[QUOTED] likes this.
  14. Dec 18, 2020 at 11:37 AM
    MentalBill
    MentalBill Mental in every state.
    Bill
    Oahu
    2015 Tundra Limited and 2018 Honda Civic
    I bought the TRD for my truck and not happy. Drone the live long day.
  15. Dec 18, 2020 at 12:37 PM
    17TundraDCEd
    17TundraDCEd New Member
    Ed
    SE Pa
    2018 White SR5 Crewmax
    Rear Sway Bar
    Had TRD duals, BAM 8 (single outlet) and BAM 12 (single outlet). BAM 12 - which is what I currently run - is my favorite.
    Jtundra81 and TundraPJ like this.
  16. Dec 18, 2020 at 12:45 PM
    Rica25
    Ricardo
    Tulare
    I'm from California as well have had the 8 inch Dirtydeeds muffler for 3 yrs now and have been awesome. No issues with emissions
    dirtydeeds and Sunfish like this.
  17. Dec 18, 2020 at 6:12 PM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Same.
    Freakenrage[QUOTED] and Rica25 like this.
  18. Dec 20, 2020 at 5:49 PM
    TundraPJ
    TundraPJ New Member
    JP
    DFW, Texas
    '19 SR5 TRD Off-Road
    Fox TRD Pro Shocks BFG KO2’s Dirty Deeds 14” BAMF n-fab nerf bars
    You don’t happen to have a video/sound clip of the 12” system do you? I finally killed the drone on the stock system with the DD resonator, now starting to get the itch for something a tad throatier ...
    Airn890 and Rica25 like this.
  19. Dec 21, 2020 at 3:53 AM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    I don’t have video/sound, but I’ll see what I can do.
    Rica25 and TundraPJ[QUOTED] like this.
  20. Dec 21, 2020 at 6:45 AM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    Rica25 likes this.
  21. Dec 21, 2020 at 7:19 AM
    TundraPJ
    TundraPJ New Member
    JP
    DFW, Texas
    Thanks, my search skills failed me, but I really appreciate you digging it up and posting!
    Rica25 likes this.
  22. Dec 21, 2020 at 7:21 AM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    No problem.
    Rica25 likes this.
  23. Dec 21, 2020 at 8:28 AM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    Rica25 likes this.
  24. Dec 21, 2020 at 9:16 AM
    Elduder
    Elduder New Member
    Now that Ive had the OE TRD dual, the TRD dual with DDs budget replacement (no mufflers, x-pipe), and recently the DD budget single system (no muffler) I can say I've noticed this. The OE TRD will work for pretty much most people, its mild and sounds good. The dual without mufflers and a x pipe was by far my favorite. The x pipe tones down just enough drone and adds a really nice tone. It also popped and crackled like crazy, on demand even.
    The DD budget single system make noticeably more power than the dual did. The truck feels lighter and just feels more robust and just about any power range. It also drones, enough to be too much for most people. I think at some point I might go to the dual long system Keith makes because it incorporates a x pipe.
    Rica25 likes this.
  25. Dec 28, 2020 at 11:49 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Give Keith Carty of Dirty Deeds Industries a call and talk to him. All of our standard systems pass CA smogs (which is probably the strictest on emissions). 760-877-4234.
    Thanks, Shawna
