Diode Dynamics SS3 SAE Pro fog lights installed. Update 4/17/21. Now with SS3 Max.
Discussion in 'Lighting' started by Danman34, Dec 13, 2019.
  1. Apr 7, 2020 at 4:27 PM
    #271
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Yep just a small flat head screw driver and you can easily move the liner from the end cap. Takes just a minute to remove that liner. Your gonna want it off cuz you gotta aim the lights to so depending what you go with. The SS3s don’t have an adjustment screw like oem that’s easy to adjust with it on it the truck it has screws that you loosen on both sides so just get them a little snug aim your light pull them off and tighten. Unless you have really small hands you can adjust those on the truck. The only way around not messing the the liner is to remove the fog light bezel and everything as one piece through the the front of the end cap. It’s pressure fitted in there with a couple tabs. Just use a small screwdriver again and pry the top then bottom and the whole assembly will come out through the front.
    CaptainGrumpus likes this.
  2. Apr 7, 2020 at 5:36 PM
    #272
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    Thanks for the great write up!
  3. Apr 9, 2020 at 1:37 PM
    #273
    Ltd17
    Ltd17 New Member
    17 Quicksand LTD
    Y'all are horrible to my bank account. I'm gonna go with pros, but I cant decide between yellow or white. Still have stock halogen bulbs, but will soon change them to led bulbs.
    Can anybody sway me one way or the other on color?
  4. Apr 9, 2020 at 1:43 PM
    #274
    BrandonL812
    BrandonL812 New Member
    Brandon
    2017 Sequoia LTD
    Rx350 retrofitted, Morimoto Led fogs. interior and exterior leds swap. TRD drop in filter. Carbon filter delete. Led DRL panels. TRD Shift knob.
    Depends. You want aesthetic first then performance or vice versa.
    Aesthetic: go with white, it will match other white leds. Those 6k ish cool white.
    Then follow with performance. The pro white will still give you lots of output.
    Performance:
    Do you want that amber yellow for fog, rain, snow? Harsh weather?
    Remember, white light is pretty bad in harsh conditions. Especially rain and snow.
    Best thing is you can swap out lense color to suite your need.
  5. Apr 9, 2020 at 1:54 PM
    #275
    Ltd17
    Ltd17 New Member
    17 Quicksand LTD
    Im definitely getting the fog pattern. At first I wanted white since a lot of driving is back roads and I'd rather light up the sides more in case of critters. I have recently been leaning towards the yellow though after seeing pictures of the output and considering harsh weather.
    Will the yellow still light up the sides of the road well?
  6. Apr 9, 2020 at 1:59 PM
    #276
    BrandonL812
    Brandon
    2017 Sequoia LTD
    Yes. It does. I have the sport on the wife's rav4. Was following her home one night and i kept thinking, that fog pattern is so wide. Because we drive a lot of 2 lanes highway and at night, i wanted the yellow in case we get caught in bad weather. The led headlights were good for dry season, but once rain and snow hits, it makes it really hard to see the roads line. The white reflects back too much.
  7. Apr 9, 2020 at 2:04 PM
    #277
    BrandonL812
    Brandon
    2017 Sequoia LTD
    You should look at page 8, post #235. That's the yellow output on the wife's rav4.
    If you havent watch this vid about the lense swap, you should. It will give you an idea on how the color will look with different lense color.
    https://youtu.be/16Wqr4cxOEI
  8. Apr 9, 2020 at 2:16 PM
    #278
    Danman34
    Danman34 [OP] New Member
    Danny
    2018 White Tundra TRD Sport
    The yellows will provide far more useable light for all conditions. The output difference between the white and the yellow pros is not that much. I think the yellow provides a more distinctive look and still puts down a tremendous amount of light on the roads. My yellow pros will light up wall to wall on a 5 lane interstate.
  9. Apr 9, 2020 at 2:27 PM
    #279
    Ltd17
    Ltd17 New Member
    17 Quicksand LTD
    Okay. I'm thinking yellow is gonna be the way to go. Just went down a rabbit hole of fog light videos and the yellow looks like a better choice for me.
    Thanks for your help everybody
  10. Apr 9, 2020 at 2:31 PM
    #280
    Cfincke
    San Antonio
    I have the ss3 pros in yellow and like them a lot. Remember if you do not like the yellow you can install the while lens and have a 4000 Kelvin white fog light vs the standard 6000 kevin white light.
  11. Apr 9, 2020 at 3:10 PM
    #281
    CaptainGrumpus
    Maine
    I went for the ambers because of the snow and fog here in the northeast.
    Major likes this.
  12. Apr 9, 2020 at 3:44 PM
    #282
    wwinslett
    wwinslett New Member
    Will
    Birmingham AL
    2016 Tundra CM Magnetic Grey
    6112's Toytec Shackles Method NV on Ridge Grapplers 295/70/18
    Yellow. I love mine
  13. Apr 11, 2020 at 3:01 PM
    #283
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    I didn’t get the pro but am happy. Took advantage of lightwerkz 15% off. Wanted to order straight through diode but website said they were out of stock. Switched over from caliraisedled so now I gotta sell those lol...here’s some shots and comparisons
    7F145192-A004-4E51-986C-C366C575964F.jpg 6A5FD8E2-9542-4ADE-8EB3-1F33B8A54809.jpg 359015FE-0DA2-487E-B1DD-8F0622E0AA90.jpg 670DC046-B51A-4C8E-8B3C-A9B3D9FD70BC.jpg
  14. Apr 11, 2020 at 4:11 PM
    #284
    BrandonL812
    Brandon
    2017 Sequoia LTD
    The caliraised look kind of greenish yellow. I much prefer the ss3.
  15. Apr 11, 2020 at 4:14 PM
    #285
    paradizecityz
    Richmond, TX
    Could be my camera or filter lol
    I also put the yellow laminx tint on it as well
  16. Apr 11, 2020 at 5:08 PM
    #286
    Danman34
    Danny
    Probably why it looks green. 6k leds and yellow make greenish color. This is where the DDs shine because they use a 4K led so the yellow filter gives a pure yellow light with minimal lumen loss.
  17. Apr 13, 2020 at 10:03 AM
    #287
    CaptainGrumpus
    Maine
    So I got them installed yesterday and of course I broke the bracket on the driver side. Ended up pulling of the whole liner and gorilla glued the bracket back to the liner. I then waited a few hours for the gorilla glue to setup but I didn’t give it enough time and it came off during reinstallation. In the end I used some double sided tape, reinstalled everything and was able to snug up those 2 bolts. Seems strong and good enough for me.
    when I did the passenger side, I was able to pull the light out thru the front and install it that way. After doing the driver side I realized that there was no blue clip on my ‘18. Wish I had figured that out before doing the driver side somehow.
    Thanks again for all the help. Off to the next mod now. RCI skid plate.
  18. Apr 14, 2020 at 5:51 AM
    #288
    CaptainGrumpus
    Maine
    I decided to put together a video, albeit a very “amateur” video, showing a few things I learned while installing my SS3’s. Hope it helps someone lol.
    https://youtu.be/VY2qvQQ-huU
  19. Apr 14, 2020 at 8:53 AM
    #289
    paradizecityz
    Richmond, TX
    I'm guessing it was just me winging it but was confused on which bracket was left and right. After seeing your video, I think I put them backwards....oh well LOL
  20. Apr 14, 2020 at 9:02 AM
    #290
    CaptainGrumpus
    Maine
    As long as everything is secure and the lights are aimed properly then you are probably good to go. I drove to work today and they didn’t fall out so I think I’m good
    paradizecityz[QUOTED] likes this.
  21. Apr 14, 2020 at 9:13 AM
    #291
    CobySon
    CobySon New Member
    2017 White Tundra Platinum
    18 inch Method wheels 33s BFG KO2, front leveling kit only, painted front grill, LED interior lights, backup, puddle lights.
    Nice rino in the background:monocle:
  22. Apr 14, 2020 at 1:47 PM
    #292
    Danman34
    Danny
    haha. It’s our company mascot and part of our logo.
  23. Apr 14, 2020 at 6:11 PM
    #293
    BrandonL812
    Brandon
    2017 Sequoia LTD
    Good eyes. Guess noone else notice the rhino either?
  24. Apr 26, 2020 at 10:05 AM
    #294
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    Yupp. Mine had the blue clips.
    NewImprovedRon likes this.
  25. Apr 26, 2020 at 10:13 AM
    #295
    Major
    Major TTC #0181
    Josh
    NC
    Stock.
    How's my cut off? :monocle:
    BrandonL812 and Luckydog like this.
  26. Apr 27, 2020 at 3:11 PM
    #296
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    Is there anyone using the flood lights as ditch lights? If so, how do you like them? Pros & Cons?
    Thanks in advance.
  27. Apr 28, 2020 at 8:00 AM
    #297
    Ltd17
    Ltd17 New Member
    17 Quicksand LTD
    Got mine installed last week. I'll have to get a night picture. These are awesome and light up everything I need to see. I also went in through the front of the bumper and pulled the bezel out. I did have to reach up from below to cut free the slack in the wire
    Luckydog and Danman34[OP] like this.
  28. May 18, 2020 at 6:26 PM
    #298
    Damie Street
    Edsel
    South Carolina
    What's a good site to get a set of Diode Dynamics? I was looking in lightwerkz and the price seems pretty reasonable.
    Thanks
    Edsel
  29. May 18, 2020 at 8:26 PM
    #299
    paradizecityz
    Richmond, TX
    That's where I got mine
    Damie Street[QUOTED] likes this.
  30. May 21, 2020 at 1:54 PM
    #300
    BrandonL812
    Brandon
    2017 Sequoia LTD
    Guys,
    Lightwerkz is running Memorial day sale. 20% off Diode dynamics product, plus free shipping.
    All 2nd gen tundra guys need to jump on this NOW. Diode dynamics has released the bracket for our front bumper. I just got mine for our sequoia. $256 shipped for the PRO version. You cannot beat this price. Get it while it's hot.
